Update to Zway 3.2.0 crashed system
Re: Update to Zway 3.2.0 crashed system
Are you on Raspbian Stretch or Buster? The last build do not work with Stretch. We are looking in this issue.
On Buster, do need logfile? Where to find?
Directly after updating to 3.2.0 the commands
sudo /etc/init.d/z-way-server start
sudo LD_LIBRARY_PATH=./libs ./z-way-server
helped to start the Z-way server.
Now the following error message is generated:
sudo: ./z-way-server: Befehl nicht gefunden
lionelcosta
Found the solution - here: https://forum.z-wave.me/viewtopic.php?p=90995#p90995
Thanks a lot!
I don't know why, but it worked - system is live again! Thanks to mosquitto.
Sorry for the inconvenience. We have made our home work and are now testing the new v3.2.1 that is fixing errors introduced in v3.2.0. For the test purpose (while it is not in the repository yet) please use two commands:
PKG=z-way-3.2.1_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKGRe: Update to Zway 3.2.0 crashed system
Thanks for your efforts: The system is running again (on 3.2.1)
However, there some effects in the expert mode which are quite strange:
- It is no more possible to select device descriptions (e.g. for Fibaro devices like FGS-222) --> so all device specific configurations of parameters is no more possible (only using generic parameters with get/set)
- for some of the devices (e.g. Fibaro Implant or Fibaro Roller Shutter) the worksheets "configuration" and "association" are completely blank, no settings are possible at all.
How to fix these two issues?
For device descriptions go in ZDDX folder and run ./UpdateXMLs.sh
This is a bug and will be fixed in the next release.
The blank screen is certainly due to missing ZDDX
Where to find the ZDDX folder?
Thanks again,
the XMLupdate fixed the issues.
For other users:
pi@raspberrypi:/opt/z-way-server/ZDDX
For other users:
