Upgrade to Z-Way v3.2.2
seattleneil
Re: Upgrade to Z-Way v3.2.2
Post by seattleneil »
Except for the mosquitto issue, I don't see a problem that would prevent the z-way-server process from starting automatically on a reboot. If the problem still persists, further troubleshooting by @Poltos may be your best option.
The mosquitto issue has been previously discussed in the forum. The following steps should solve the issue.
1. Verify package repositories are correct - run:
cat /etc/apt/sources.list.d/z-wave-me.list
You should see the following:
deb https://repo.mosquitto.org/debian buster main
deb https://repo.z-wave.me/z-way/raspbian buster main
2. If the mosquitto entry is missing, run:
wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
sudo apt --fix-broken install
3. Verify mosquitto package has been installed - run:
dpkg-query -l mosquitto
ii mosquitto 2.0.12-0mosquitto1~buster1 armhf MQTT version 3.1/3.1.1/5.0 compatible message broker
4. If you don't see the mosquitto package installed (it should have been installed automagically using "sudo apt --fix-broken install"), run:
sudo apt install mosquitto
Repeat step 3 to confirm.
Assuming the mosquitto issue has been solved, let's revisit the automatic start-up issue using the following steps.
1. Reboot your Pi. With luck, the z-way-server process will start automatically - run:
sudo reboot
2. Log back onto your Pi after 2 minutes and check to see if the z-way-server process is running. Run:
ps -ef | grep z-way-server
You should see the z-way-server process is running (as user root) and be able to access Z-Way using the web UI.
3. If the z-way-server process is not running, start the z-way server process manually - run:
sudo /etc/init.d/z-way-server start
Verify the z-way-server process is running by repeating step 2. The file /var/log/z-way-server.log should provide detailed information.
Should work. Need remote access to check it
N2641D
Post by N2641D »
Thanks to seattleneil and PoltoS!!!
Although ZWay was the single application on my RASPI before upgrade to v3.2.2 it has become clear, that there is something wrong with that OS. I think we have spent far enough time to find out the root cause of the issue.
I yesterday initialized a new SD-card, installed Raspbian, and Way v3.2.2.2. Everything is working fine and we might keep it to our imagination to think about the problem which created a not responsive ZWay application.
Since my background is to develop hard- and software for Z-Wave 700 devices, I now will be able to get back to things I really like to do :-)
Thanks again for your help!
otverber
Post by otverber »
Had the same issue.
you need to add libmosquitto to the raspian to make z-way-server work.
I found a way of fixing this under the 3.2.1 upgrade thread
easy fix when you find it.
edit:
you find the solution under the tread:
Official anouncements/Z-Way v3.2.1 Release and update of iOS app
I found the issue. It is a broken reference to libmosquitto. Solution is here: https://forum.z-wave.me/viewtopic.php?p=92009#p92009
