Is there a Library available for using a Real Time Clock shield
amatilda
Re: Is there a Library available for using a Real Time Clock shield
Post by amatilda »
Hello.
Let's try to get more information.
Use this sketch and post the error log:
#include "Arduino.h"
#include "Wire.h"
#include <ZUNO_DS3232RTC.h>
#include <Time.h>
#define MY_SERIAL Serial
DS3232RTC myRTC;
tmElements_t te, te_r;
time_t ts; // secs since 1900.
void setup() {
	MY_SERIAL.begin(9600);
	te.Second = 30;
	te.Minute = 32;
	te.Hour = 13;
	te.Wday = 6;
	te.Day = 8;
	te.Month = 6-1;
	te.Year = 2024 -1900;
	myRTC.write(&te);
void loop() {
	if (myRTC.read(&te_r) != WIRE_ERORR_TRANSMISSION_SUCCESS) {
		MY_SERIAL.print("myRTC.read - error\n");
	disp();
	delay(10000);
void disp(void){
	MY_SERIAL.print("dump: ");
	MY_SERIAL.dumpPrint(&te_r, sizeof(te_r), sizeof(te_r));
	MY_SERIAL.printf("\n*************\n%04d-%02d-%02d %02d:%02d:%02d : Weekday = %d.\n", te_r.Year + 1900, te_r.Month + 1, te_r.Day, te_r.Hour, te_r.Minute, te_r.Second, te_r.Wday);
KGBEl
Post by KGBEl »
Hi, it compiles and loads without any problems but only gives
as output and all led:s on Z-uno is off.
How do I do to invoke the white area that containes code and starts with: "CODE: SELECT ALL"?
amatilda
Post by amatilda »
Do you have a card adapter to connect to the TX0 pin?
Sorry, but I didn't quite understand, can you give me more details?
KGBEl
Post by KGBEl »
1:
I don't know what you mean by cardadapter to TX0, is there any dokumentation you can
show me about that?
I guess it has something to do with writing errors to som sort of USB or so?
2:
About the area where you copied all code to, where you can, at top of the area you can
select to mark all code.
Start:
#include "Wire.h"
#include <Time.h>
and so on till the end of the program.
amatilda
Post by amatilda »
Use:
2024-08-20 164023.png (1.36 KiB) Viewed 65813 times
amatilda
Post by amatilda »
show me about that?
I meant something like that: https://www.amazon.com/Micro-SATA-Cable ... 43&sr=8-16
Unlikely
KGBEl
Post by KGBEl »
Thank you very much for the area tip.
About TX0-issue:
1. What is the serial converter good for?
2. How do I use it?
3. Are there any cheaper alternatives? 845$ is a lot of money.
They usually cost 5-10 EUR on Amazon or 1-5 on AliExpress. You can connect the Z-Uno debug output you PC USB port.
Search for CP2102 or "USB to Serial"
KGBEl
Post by KGBEl »
Ok, I understand what it is for, can you give me a link to some place where I can read
about it and understand it better.
Is it possible to find anything in this forum?
I am using Mac, does it differ from PC in this case?
lanbrown
Post by lanbrown »
KGBEl wrote: ↑
21 Aug 2024 16:34
It isn't $845.
You want to buy the USB 2.0 to TTL UART 6PIN Module Serial Converter CP2102, not the other device listed at the top which is an ad for a different device.
The device you want is $5.75.
https://electronics.stackexchange.com/q ... d-ttl-uart
