lanbrown
Posts: 381 Joined: 01 Jun 2021 08:06
Post
by lanbrown » 12 Aug 2023 21:36
Rudi56 wrote: ↑ 12 Aug 2023 19:27
cwilms wrote: ↑ 07 Jan 2023 15:11
I managed to resolve this issue by updating the device setting mapBasicSetToSpecificReport=true.
Contact sensor updates were then interpreted as instance0.SensorBinary updates.
Sorry to bother you, but my English is even worse than my z-wave skills.
Where can/should I set this "mapBasicSetToSpecificReport" ?
I have a ZD2102EU 2013 door window sensor with firmware version 4.84
So without Gen5 and security support.
Can you help me?
Greetings Rudi
http://
IPaddressOfZ-WayServer :8083/JS/Run/zway.devices[
DeviceNumberHere ].
WhatYouWantToSetHere
Rudi56
Posts: 15 Joined: 05 Apr 2016 11:34
Post
by Rudi56 » 13 Aug 2023 13:41
Yes Sir, i did it.
http://192.168.45.191:8083/JS/Run/zway.devices[32].mapBasicSetToSpecificReport=true
Response are "true"
but nothing happened.
Zwave smarthome does show the sensor always in the same state.
(the led on the sensor blink short, when i opened the window, or when i close it.)
Where can i found the part after the zway.devices[32].???????
Is there a way to show me all the WhatICanToSetHere?
and what is the way to get the values, that is set?
Greetings and many thanks, for your help, Rudi
Rudi56 on 13 Aug 2023 14:28, edited 1 time in total.
Rudi56
Post
by Rudi56 » 13 Aug 2023 13:52
Can you see something on my z-way Server Log?
I am out of order, in a old version 3.xx all was fine, now on 4.1.1 the one windowsensor does not work.
Greetings Rudi
[2023-08-13 12:34:40.675] [D] [zway] RECEIVED: ( 01 09 00 04 00 20 03 20 01 FF 0F )
[2023-08-13 12:34:40.675] [D] [zway] SENT ACK
[2023-08-13 12:34:40.675] [D] [zway] SETDATA devices.32.data.lastReceived = 0 (0x00000000)
[2023-08-13 12:34:40.676] [W] [zway] Ignoring Set packet recieved on lower security scheme Plain text than our highest S2 Access (acceptSetSecurityLevel is not set)
[2023-08-13 12:34:40.677] [E] [zway] Error returned from _zway_cc_call_handler(zway, device->default_instance, controller->id, 0, data[4 + L], &data[5 + L]): Function class not supported by the hardware (-4)
[2023-08-13 12:34:40.694] [D] [zway] RECEIVED: ( 01 10 00 04 00 20 0A 71 05 07 FF 00 FF 07 02 00 00 B7 )
[2023-08-13 12:34:40.694] [D] [zway] SENT ACK
[2023-08-13 12:34:40.694] [D] [zway] SETDATA devices.32.data.lastReceived = 0 (0x00000000)
[2023-08-13 12:34:40.694] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.V1event.alarmType = 7 (0x00000007)
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.V1event.level = 255 (0x000000ff)
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.V1event = Empty
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.2.status = True
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.2.parameters = byte[0]
[2023-08-13 12:34:40.695] [D] [zway] ( zero-length buffer )
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.2 = Empty
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.status = True
[2023-08-13 12:34:40.695] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7 = Empty
[2023-08-13 12:34:41.630] [D] [zway] RECEIVED: ( 01 14 00 04 00 04 0E 32 02 21 34 00 00 00 00 00 01 00 00 00 02 C3 )
[2023-08-13 12:34:41.630] [D] [zway] SENT ACK
[2023-08-13 12:34:41.630] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2.precision = 1 (0x00000001)
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2.intVal = 0 (0x00000000)
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2.val = 0.000000
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2.delta = 1 (0x00000001)
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2.previous = 0.200000
[2023-08-13 12:34:41.631] [D] [zway] SETDATA devices.4.instances.0.commandClasses.50.data.2 = Empty
[2023-08-13 12:34:41.670] [I] [core] [BaseModule-13] Set lastLevel to 0 for ZWayVDev_zway_4-0-50-2 (was 0.2)
[2023-08-13 12:34:42.353] [D] [zway] RECEIVED: ( 01 09 00 04 00 20 03 20 01 00 F0 )
[2023-08-13 12:34:42.354] [D] [zway] SENT ACK
[2023-08-13 12:34:42.360] [D] [zway] SETDATA devices.32.data.lastReceived = 0 (0x00000000)
[2023-08-13 12:34:42.361] [W] [zway] Ignoring Set packet recieved on lower security scheme Plain text than our highest S2 Access (acceptSetSecurityLevel is not set)
[2023-08-13 12:34:42.361] [E] [zway] Error returned from _zway_cc_call_handler(zway, device->default_instance, controller->id, 0, data[4 + L], &data[5 + L]): Function class not supported by the hardware (-4)
[2023-08-13 12:34:42.429] [D] [zway] RECEIVED: ( 01 10 00 04 00 20 0A 71 05 07 00 00 FF 07 02 00 00 48 )
[2023-08-13 12:34:42.429] [D] [zway] SENT ACK
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.data.lastReceived = 0 (0x00000000)
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.V1event.alarmType = 7 (0x00000007)
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.V1event.level = 0 (0x00000000)
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.V1event = Empty
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.2.status = True
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.2.parameters = byte[0]
[2023-08-13 12:34:42.430] [D] [zway] ( zero-length buffer )
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.2 = Empty
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7.status = True
[2023-08-13 12:34:42.430] [D] [zway] SETDATA devices.32.instances.0.commandClasses.113.data.7 = Empty
[2023-08-13 12:34:43.130] [D] [zway] RECEIVED: ( 01 14 00 04 00 04 0E 32 02 21 34 00 00 00 1C 00 01 00 00 00 00 DD )
[2023-08-13 12:34:43.130] [D] [zway] SENT ACK
[2023-08-13 12:34:43.131] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
