Time Concition in Automations
marco
Re: Time Concition in Automations
Post by marco »
Michael, I noticed the same thing.
For some reason, the app doesn't write the trigger.
This is the unique clue.
Of course, I already tried to reboot the pi but to be sure I rebooted it once more. Same results.
About cron, if you mean this
it has been always active.
I'm still lost.
Marco
marco
Post by marco »
Hi, after a few times also a second system shows me the same problem.
Do you have any suggestions?
Marco
lanbrown
Post by lanbrown »
On the second system, what version are you running and did it recently change? If it was working and now doesn't and the Z-Way version hasn't changed, then some other "change" has happened on your system. Did you recently apply any updates to the Raspberry Pi itself?
Ultimately you need to figure out what changed from when it was working to when it stopped.
marco
Post by marco »
Hi lanbrown and sorry for my delay.
On the second system I have zway firmware version v4.1.2-wb1 (Same as the first)
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
on
Hardware : BCM2835
Revision : a22082
Serial : 000000007ab328f9
Model : Raspberry Pi 3 Model B Rev 1.2
No update or installation performed on this system. The only thing I've done some times ago was the update of zway server. Only recently I noticed the anomaly.
I need to check all other systems.
Marco
