RaZberry 7 Pro serial problem RPI4b bookworm
seattleneil
Re: RaZberry 7 Pro serial problem RPI4b bookworm
Post by seattleneil »
Please run the following command: sudo lsof -n | grep AMA0
One possible explanation is that you have 2 z-way-server processes running and they are interfering with each other. Another possibility is you have some other process talking to the serial port. The command listed above will show you if either of these situations exist.
judge
Post by judge »
Many thanks for your time @seattleneil. It is solved!
I had run
lsof -n | grep AMA0
before, but without the
sudo
. And I got an empty return, as expected. However, thanks to your suggestion I run it with
:roll: and I got
agetty    23744                             root    0u      CHR             204,64       0t0        134 /dev/ttyAMA0
agetty    23744                             root    1u      CHR             204,64       0t0        134 /dev/ttyAMA0
agetty    23744                             root    2u      CHR             204,64       0t0        134 /dev/ttyAMA0
So, I disabled agetty, rebooted and it works like a charm.
I hope this will help others.
