Z-Wave.Me future (discussion)
Spacerat
Re: Z-Wave.Me future (discussion)
Post by Spacerat »
It would be great to have some migration guides from Raspberry Pi with Razberry 7 pro to Home Assistant + Zwave.js and a USB dongle (including some recommendations which USB sticks work).
Something like this
1. add USB-Controller to existing Z-Way with RaZberry
2. do controller switch in Z-Way
3. extract S0,S1 & S2 keys
4. install HA & zwave.js to new device (would like to keep existing Pi as fallback).
5. insert USB-Conroller into HA
6. dicover devices
7. add S0,S1 & S2 keys
8. reconfigure rules & automations in HA
seattleneil
Post by seattleneil »
The approach you've describer will mostly work, but it's not ideal for the following reasons:
1. The controller switch approach will cause the new controller to have a node ID that is not 1. While a controller with a ID node that's different than 1 should work, it will introduce some subtle problems. For example, the Lifeline association in a device is frequently hard-coded to send messages to node ID=1.
2. S2-included devices won't work with the new controller. This is because the S2 keys are used to create a device-specific key during the S2 inclusion process. The S2-derived device-specific keys are not transferred on a controller switch.
There's a fairly complicated procedure for adding a new controller with the same network ID as an existing controller and node ID=1. You can read about the approach here: https://github.com/zwave-js/zwave-js/discussions/6786
For many users, my sense is that it will be easier to exclude/re-include their Z-Wave devices with a new controller.
An alternative migration approach is for @PoltoS to provide a Razberry 7 backup tool that dumps the NVRAM into a format the Zooz ZAC93 and ZST39 controllers support (see: https://www.thesmartesthouse.com/collec ... ontrollers) using zwave-js-ui. This approach allows @PoltoS to create a simple migration path: (1) Run backup on RazBerry, (2) Use zwave-js-ui to restore the backup onto either a Zooz ZAC93 or ZST39 controller. Ideally, the Razberry Gen 2 (500-series) would have a similar migration approach.
alky
Post by alky »
"Well, this is sad... sad that z-wave.me is ending. Last year I switched to RP5 + z-station. Probably wasted money...
Should I look for another solution, or will the z-station be able to function in some new form with Trident IoT?
Does anyone know Homey Pro? https://homey.app/ probably the best solution I have found or know so far."
markchang
Post by markchang »
So, for all that have a rpi with a high zwave.me home, what can we do after two years and what can’t?
I mean, I probably lost the app and the external connection but, will my system work without problem in 4.1.4? Or I will need to recreate my whole house with another zwave hub or home assistant.
I think that a guide of can/can’t will be a good idea to let us see if we continue like this or we spent the time to change.
Anyway, sad to hear that zwave.me end without continuity
lanbrown
Post by lanbrown »
Z-Way will continue to work, you won't have the remote access via the app though. In my case, this is not important as Z-Way is just feeding into Home Assistant. I have remote access to Home Assistant via Cloudflare using the Home Assistant app. Z-Way is stable and runs as a docker on Home Assistant. If Z-Way does have an issue, I can just restart the Add-on which is the docker. I could also just restart all of Home Assistant. At home, I would expect the Z-Wave,me app to work since it can communicate with the Z-Way locally.
markchang
Post by markchang »
So I can create a local backup of my pi system and continue to work with isn’t it?
And if in the future I have a problem with the system, I only need to reinstall with the backup
lanbrown
Post by lanbrown »
Yes, you should always have a backup.
seattleneil
The closing of Z-Wave.Me is unfortunate, but it's not catastophic. @PoltoS provided a detailed explanation of what we can expect - see: https://forum.z-wave.me/viewtopic.php?f ... 0&p=100028
My summary of the situation...
Z-Wave.Me controllers will continue to operate as they do today. Note that Z-Wave.Me controllers can be used with Z-Way software or they can be used with other Z-Wave software, such as zwave-js-ui, as used in Home Assistant. Transitioning from Z-Way to zwave-js-ui is straightforward - copy the S0 and S2 keys from Z-Way to zwave-js-ui and configure device names to have friendly names. In other words, there's no compelling reason to stop using a Z-Wave.Me controller. This is a good news as migrating a Z-Wave.Me controller such as a Razberry 7 Pro to a controller from a different company such as a Zooz ZAC93 is a difficult task as you can't simply backup a Z-Wave.Me controller and then restore onto a different company's hardware. Fortunately, migrating to new controller hardware should only be required if your Z-Wave.Me controller dies and you don't have a spare Z-Wave.Me controller.
Z-Way software should also continue to operate as it does today until Feb. 2027, with a few notable exceptions, as listed below:
1. Remote access via find.z-wave.me is slated to be shutdown Feb. 2027. As a workaround, chances are good that remote access will continue to work using a VPN or SSH port forwarding.
2. The Z-Way mobile app will not be available in app stores after Feb. 2027 and may stop working. As a workaround, you can use the web UI on your mobile device (with VPN or SSH port forwarding remote access discussed above).
3. Cloud backups/restore is slated to be shutdown Feb. 2027. As a workaround, you can do local backups instead of cloud backups.
4. Alexa and Google Assistant integrations is slated to be shutdown Feb. 2027. As a workaround, you can install Home Assistant and use either the Z-Way plugin or transition to the zwave-js-ui plugin.
aLiEnHeAd
Post by aLiEnHeAd »
PoltoS wrote: This forum will last two years more. Maybe even longer as this requires very small resources from us. Same for the Z-Wave.Me web sites.
Does anyone know a good alternative forum / reddit / lemmy / mastodon with a nice community like this if this forum will be shut down? ;)
markchang
Post by markchang »
And, as a question,
It is not possible to continue this project, except the part purchased in order to maintain at least all of this up?
