Integration with Home Assistant
PerH
Re: Integration with Home Assistant
Post by PerH »
Ok, Thanks Ian!
My HASS instance is still not fully operational anyway, I've been waiting for the final device entity layout before transferring control to HASS.. :)
lanbrown
Post by lanbrown »
In software, nothing is ever final. After the latest changes are included in Home Assistant you don't think there would be future changes?
PerH
Post by PerH »
hehe, no, by all means.
What I mean is that I want the entities organized properly before I start using them in automations, in case some references change when using an external automation engine.
We hope to finalize the "re-grouping" of widgets in one device this month
PerH
Post by PerH »
Any news on this?
Can't see any mentions in the 2022.7 release notes, so i guess its not ready yet?
Do I have to remove and reinstall the connection when HASS is updated with this, or will the rearranging be done automatically?
Not sur yet if a reinstall will be required, but I guess so.
PerH
Post by PerH »
Just checking if this change is implemented? The HASS release notes are impossible to read..
Still in the queue ;(
speedin70
Post by speedin70 »
Thanks for all the help, there is a new videowith slight changes but for the most part is the same setup, but I did manage to figure it out. for the initial of adding the home assistance link to google I had to be OFF wifi and connected to data on my phone, but once its setup I can control devices though the Home app over wifi
https://www.routerlogin.net/
pikashow
michap
Post by michap »
following issue:
If Z-Wave device became unavailable (plug moved to other place or got for limited time bad/no connection) and it will be available in Z-Way again - it will not be more available in HA.
Looks like the state is "unavailable" for ever, cannot be used more until the plugin will be reloaded.
