New release candidate of available now!
SolarFlor
Re: New release candidate of available now!
Post by SolarFlor »
PoltoS wrote: And from today you can also update Z-Way (same version will be installed, but you wil get remote access and some configuration features on port 8084 of your Raspberry Pi).
May I keep the port 8083 just changing the following line in the config file?
<port>8083</port>
Floriano
8083 is still same - used for Z-Way.
8084 is used for configuration and remote access UI
ricargr
Post by ricargr »
BRAVO!!! now it works with custom module.
Thank you!!!
Can be done with similar code a bind function for SensorState value?
Regards
michap
Post by michap »
Some Problems with setting values in new Version.
As sample Fibaro Motion sensor - Parameter24 (should be set to 4 for Seismograph - as I learned from Fibaro....)
After loading XML I see:
N°24 - TAMPER OPERATION MODES:
Updated: 16:56
Default value is unknown
Parameter determines the behaviour of tamper and how it reports
Configuration Parameter type is not handled in the Interface: constant
So it can not be changed
Same for some other important Parameters....
(Maybe it is an XML error/feature - but I think it could be handled here ;) ...)
Michael
[edit]:
Found it out - there is wrong XML -
wrong:
<configParam number="24" type="constant" size="1" default="00">
right:
<configParam number="24" type="rangemapped" size="1" default="00">
same for other Parameters...
Pipistrello77
Post by Pipistrello77 »
I dont know it works port 8084... Or that feature is not working for me :-(
I cant access to http://myaddress:8084
michap wrote:Some Problems with setting values in new Version.
This is due to wrong ZDDX XML in the PepperOne Database. Fixed. Please try again (run UpdateXML.sh and choose ZDDX again for this device)
Mike_77
Post by Mike_77 »
installed the RC3
When load the Dashbord following warning is active.
10/05/14 - 14:17Can not load modules.json from modules/SimpleScene/module.json: SyntaxError: Unexpected token }
pofs
Post by pofs »
Mike_77 wrote:installed the RC3
There's no SimpleScene module in the package. Can it be some custom module you added?
sdh
Post by sdh »
When I try to connect via https://find.zwave.me, my browser throws a certificate expired error. Are others seeing the same. Will the certificates get updated soon.
billyboy
Post by billyboy »
ricargr wrote:BRAVO!!! now it works with custom module.
Thank you!!!
Regards
Dear ricargr,
I am still struggling with virtual devices. Could you please share some demo code how you did it? Also which files you changed.
Thank you very mutch!
