Problem with Fibaro Motion Sensor...
pofs
Re: Problem with Fibaro Motion Sensor...
Post by pofs »
Not sure about the reason of this problem. Probably it is Motion Sensor sending some random scales sometimes, or just some noise data in the air got luck to match device and CRC (unlikely).
That's probably our mistake to allow scales to be created as data arrive. We'll disable this feature back for devices with known scales.
For now, just ignore it.
SolarFlor
Post by SolarFlor »
Hi all,
need some help
I have installed a new Fibaro Motion Sensor FGMS-001 but I'm not able to associate it with my raspberry.
I already have a Motion Sensor and it works perfectly but I remember I followed some post to make it working. I cannot find it now.
I have also tried to copy the configuration of the old Sensor to the new one but without success.
On the old sensor I have the association with the raspeberry as Group 3 and I have tried to do the same for the new one. But it doesn't work.see below picture.
I have also tried to use the old UI Expert but I have the following message
Thanks for your support amd Merry Christmas to everybody
What is in the log (corresponding to the error in UI)?
SolarFlor
Post by SolarFlor »
see below
[2014-12-30 19:25:04.905] [E] [zway] Node 17:0 CC Association: groups count is not determined yet
[2014-12-30 19:25:06.660] [D] [zway] RECEIVED: ( 01 0C 00 04 00 07 06 31 05 03 0A 00 36 FD )
[2014-12-30 19:25:06.660] [D] [zway] SENT ACK
[2014-12-30 19:25:06.660] [D] [zway] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-12-30 19:25:06.661] [W] [zway] Node 7:0 CC SensorMultilevel: Unsupported sensor type 3 received, ignoring
[2014-12-30 19:25:09.631] [D] [zway] RECEIVED: ( 01 0C 00 04 00 07 06 31 05 03 0A 00 36 FD )
[2014-12-30 19:25:09.632] [D] [zway] SENT ACK
[2014-12-30 19:25:09.632] [D] [zway] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-12-30 19:25:09.632] [W] [zway] Node 7:0 CC SensorMultilevel: Unsupported sensor type 3 received, ignoring
or maybe is this
[2014-12-30 19:52:45.194] [D] [zway] Job 0x13 (Association Set): removing duplicate
[2014-12-30 19:52:45.194] [D] [zway] Job 0x46 (Assign return route): removing duplicate
[2014-12-30 19:52:45.194] [E] [zway] Node 17:0 CC Association: groups count is not determined yet
Means interview is not complete for Association and SensorMultilevel. Are you sure interview is done?
SolarFlor
Post by SolarFlor »
I believe the interview is not complete.
when I force interview:
[2014-12-31 14:10:00.716] [D] [zway] SETDATA devices.17.data.ZDDXMLFile = Empty
[2014-12-31 14:10:00.717] [I] [zway] Saving configuration data to config/zddx/f170e06e-DevicesData.xml
[2014-12-31 14:10:01.952] [I] [zway] Loading Command Classes for device 17
[2014-12-31 14:10:01.953] [I] [zway] Node 17:0 supports CC Basic
[2014-12-31 14:10:01.953] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data = Empty
[2014-12-31 14:10:01.953] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.supported = Empty
[2014-12-31 14:10:01.953] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.supported = True
[2014-12-31 14:10:01.954] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.version = Empty
[2014-12-31 14:10:01.954] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2014-12-31 14:10:01.954] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.security = Empty
[2014-12-31 14:10:01.954] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.security = False
[2014-12-31 14:10:01.954] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.interviewDone = Empty
[2014-12-31 14:10:01.955] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.interviewCounter = Empty
[2014-12-31 14:10:01.955] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.interviewDone = False
[2014-12-31 14:10:01.955] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2014-12-31 14:10:01.965] [D] [zway] SETDATA devices.17.instances.0.commandClasses.32.data.level = Empty
[2014-12-31 14:10:01.966] [I] [zway] Node 17:0 supports CC SensorBinary
[2014-12-31 14:10:01.966] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data = Empty
[2014-12-31 14:10:01.966] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.supported = Empty
[2014-12-31 14:10:01.966] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.supported = True
[2014-12-31 14:10:01.966] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.version = Empty
[2014-12-31 14:10:01.967] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2014-12-31 14:10:01.967] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.security = Empty
[2014-12-31 14:10:01.967] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.security = False
[2014-12-31 14:10:01.967] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.interviewDone = Empty
[2014-12-31 14:10:01.967] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.interviewCounter = Empty
[2014-12-31 14:10:01.968] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.interviewDone = False
[2014-12-31 14:10:01.968] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.interviewCounter = 10 (0x0000000a)
[2014-12-31 14:10:01.968] [D] [zway] SETDATA devices.17.instances.0.commandClasses.48.data.typemask = Empty
[2014-12-31 14:10:01.968] [I] [zway] Node 17:0 supports CC SensorMultilevel
[2014-12-31 14:10:01.969] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data = Empty
[2014-12-31 14:10:01.969] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.supported = Empty
[2014-12-31 14:10:01.969] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.supported = True
[2014-12-31 14:10:01.969] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.version = Empty
[2014-12-31 14:10:01.970] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.version = 1 (0x00000001)
[2014-12-31 14:10:01.970] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.security = Empty
[2014-12-31 14:10:01.970] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.security = False
[2014-12-31 14:10:01.971] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.interviewDone = Empty
[2014-12-31 14:10:01.971] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.interviewCounter = Empty
[2014-12-31 14:10:01.971] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.interviewDone = False
[2014-12-31 14:10:01.971] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.interviewCounter = 10 (0x0000000a)
[2014-12-31 14:10:01.971] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.typemask = Empty
[2014-12-31 14:10:01.972] [I] [zway] Node 17:0 supports CC CRC16
[2014-12-31 14:10:01.980] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data = Empty
[2014-12-31 14:10:01.980] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.supported = Empty
[2014-12-31 14:10:01.980] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.supported = True
[2014-12-31 14:10:01.980] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.version = Empty
[2014-12-31 14:10:01.980] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.version = 1 (0x00000001)
[2014-12-31 14:10:01.981] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.security = Empty
[2014-12-31 14:10:01.981] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.security = False
[2014-12-31 14:10:01.981] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.interviewDone = Empty
[2014-12-31 14:10:01.981] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.interviewCounter = Empty
[2014-12-31 14:10:01.981] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.interviewDone = False
[2014-12-31 14:10:01.982] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.interviewCounter = 10 (0x0000000a)
[2014-12-31 14:10:01.982] [D] [zway] SETDATA devices.17.instances.0.commandClasses.86.data.crc16Requested = Empty
[2014-12-31 14:10:01.982] [I] [zway] Node 17:0 supports CC Configuration
[2014-12-31 14:10:01.982] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data = Empty
[2014-12-31 14:10:01.983] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.supported = Empty
[2014-12-31 14:10:01.983] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.supported = True
[2014-12-31 14:10:01.983] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.version = Empty
[2014-12-31 14:10:01.983] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-12-31 14:10:01.983] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.security = Empty
[2014-12-31 14:10:01.984] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.security = False
[2014-12-31 14:10:01.984] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.interviewDone = Empty
[2014-12-31 14:10:01.984] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.interviewCounter = Empty
[2014-12-31 14:10:01.984] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.interviewDone = False
[2014-12-31 14:10:01.984] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2014-12-31 14:10:01.985] [I] [zway] Node 17:0 supports CC ManufacturerSpecific
[2014-12-31 14:10:01.985] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data = Empty
[2014-12-31 14:10:01.985] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.supported = Empty
[2014-12-31 14:10:01.985] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.supported = True
[2014-12-31 14:10:01.985] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.version = Empty
[2014-12-31 14:10:01.986] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-12-31 14:10:01.986] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.security = Empty
[2014-12-31 14:10:01.986] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.security = False
[2014-12-31 14:10:01.986] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.interviewDone = Empty
[2014-12-31 14:10:01.987] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.interviewCounter = Empty
[2014-12-31 14:10:01.987] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.interviewDone = False
[2014-12-31 14:10:01.987] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2014-12-31 14:10:01.987] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.vendorId = Empty
[2014-12-31 14:10:01.987] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.vendor = Empty
[2014-12-31 14:10:01.988] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.productId = Empty
[2014-12-31 14:10:01.988] [D] [zway] SETDATA devices.17.instances.0.commandClasses.114.data.productType = Empty
[2014-12-31 14:10:01.988] [I] [zway] Node 17:0 supports CC Battery
[2014-12-31 14:10:01.988] [D] [zway] SETDATA devices.17.instances.0.commandClasses.128.data = Empty
[2014-12-31 14:10:01.988] [D] [zway] SETDATA devices.17.instances.0.commandClasses.128.data.supported = Empty
[2014-12-31 14:10:01.989] [D] [zway] SETDATA devices.17.instances.0.commandClasses.128.data.supported = True
SolarFlor
Post by SolarFlor »
Solved.
I excluded the device, resetted it and re-included again.
Now it is fine
Happy New Year to all
Floriano
