Thanks for your answer, pofs!
So, is there a workaround for that, using another distribution or a complete new installation of the z-way server with newest version?
Or just have to wait for z-way server update?
Thanks for your support.
Enable HomeKit and Auth Code for RaZberry
Re: Enable HomeKit and Auth Code for RaZberry
Just wait for update, as it might be hard to find a distribution where it was not broken yet (I don't know the exact moment it did, as I don't use RPi).
OK, thank you very much, then i will wait for the next z-way server RC, and hope it will be fixed.
Can´t wait to try raZberry with HomeKit!
rc6 was on old toolchain
rc7 might be broken - we are checking this
Thanks!
I tested it with this:
wget -q -O - razberry.z-wave.me/install/v2.0.1-rc6 | sudo bash
unfortunately there is the same error in log:
Dec 29 20:16:43 Davids-iMac.local HomeKitDemo[1611]: Find primary Home :)
Dec 29 20:16:45 Davids-iMac.local homed[1632]: Treating OSStatus -25300 (errSecItemNotFound) as Generic error
Dec 29 20:16:56 --- last message repeated 1 time ---
Dec 29 20:16:56 Davids-iMac.local homed[1632]: Accessory manager failed to start discovering accessories for server browser <HAPAccessoryServerBrowserBTLE: 0x7fbfabc236c0> with error Error Domain=HMErrorDomain Code=48 "Failed to power on Bluetooth because Bluetooth LE is unsupported on this system." UserInfo=0x7fbfabd25d80 {NSLocalizedDescription=Failed to power on Bluetooth because Bluetooth LE is unsupported on this system.}
Dec 29 20:16:57 Davids-iMac.local lsd[1591]: LaunchServices: Currently 0 installed placeholders: (
Dec 29 20:17:15 Davids-iMac.local mstreamd[1573]: (Note ) PS: Media stream daemon stopping.
Dec 29 20:17:15 Davids-iMac.local mstreamd[1573]: (Note ) AS: <MSIOSAlbumSharingDaemon: 0x7fb34150fc70>: Shared Streams daemon has shut down.
Dec 29 20:17:15 Davids-iMac.local mstreamd[1573]: (Warn ) mstreamd: mstreamd shutting down.
Dec 29 20:17:24 Davids-iMac.local homed[1632]: Treating OSStatus -25300 (errSecItemNotFound) as Generic error
Dec 29 20:17:28 Davids-iMac.local SpringBoard[1578]: Can't find keyplane that supports type 4 for keyboard iPhone-PortraitChoco-NumberPad; using 2382260317_PortraitChoco_iPhone-Simple-Pad_Default
Dec 29 20:17:29 Davids-iMac com.apple.CoreSimulator.SimDevice.CDA42A82-1DCA-488E-A01A-C8C97120038A.launchd_sim[1567] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Dec 29 20:17:29 Davids-iMac.local kbd[1637]: table drop: 101
Dec 29 20:17:30 Davids-iMac com.apple.CoreSimulator.SimDevice.CDA42A82-1DCA-488E-A01A-C8C97120038A.launchd_sim[1567] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Dec 29 20:17:30 Davids-iMac.local bird[1639]: Unable to bootstrap_check_in() to namedDelegatePort 'com.apple.bird.push'. APS connections will not persist past process lifetime.
Dec 29 20:17:31 Davids-iMac.local filecoordinationd[1640]: (Error) FileProvider: Could not load bundle com.apple.CloudDocsFileProvider. Error: The bundle “CloudDocsFileProvider” couldn’t be loaded because it is damaged or missing necessary resources.
Dec 29 20:17:39 Davids-iMac.local CoreHAP[1632]: 2014-12-29 08:17:39.965701 PM [Pairing] ### Pair-setup client M6 bad status: 0x1, -6700/0xFFFFE5D4 kUnknownErr
Dec 29 20:17:39 Davids-iMac.local CoreHAP[1632]: 2014-12-29 08:17:39.966674 PM [Pairing] ### Pair-setup client state 6 failed: -6700/0xFFFFE5D4 kUnknownErr
Dec 29 20:17:39 Davids-iMac.local CoreHAP[1632]: 2014-12-29 08:17:39.967571 PM [BonjourBrowser] Reconfirming PTR for RaZberry._hap._tcp.local. on interface 4
Dec 29 20:17:39 Davids-iMac.local homed[1632]: Treating OSStatus -6700 (kUnknownErr) as Generic error
Dec 29 20:17:39 --- last message repeated 1 time ---
Dec 29 20:17:39 Davids-iMac.local homed[1632]: Failed to add accessory RaZberry with error: Error Domain=HMErrorDomain Code=52 "Failed with OSStatus code -6700 (kUnknownErr)" UserInfo=0x7fbfabd376d0 {NSLocalizedDescription=Failed with OSStatus code -6700 (kUnknownErr)}
Please try this version:
v2.0.1-rc7-7-gff06bfa
Here we explicitly made it little endian
I've updated to this version and the above error is gone! ...now the log shows the following output:
Dec 29 22:48:34 Davids-iMac.local homed[3582]: Treating OSStatus -25300 (errSecItemNotFound) as Generic error
Dec 29 22:48:37 Davids-iMac.local SpringBoard[3532]: Can't find keyplane that supports type 4 for keyboard iPhone-PortraitChoco-NumberPad; using 2382260317_PortraitChoco_iPhone-Simple-Pad_Default
Dec 29 22:48:45 Davids-iMac.local homed[3582]: ### Failed to validate value for characteristic with type '00000008-0000-1000-8000-0026BB765291' because the value was of class 'NSNull' but should be 'NSNumber'
Dec 29 22:48:45 Davids-iMac.local homed[3582]: ### init of HAPCharacteristic '00000008-0000-1000-8000-0026BB765291' failed validateValue: Error = Error Domain=HMErrorDomain Code=43 "The operation couldn’t be completed. (HMErrorDomain error 43.)"
Dec 29 22:48:45 Davids-iMac.local homed[3582]: ### Unable to parse serialized characteristic.
Dec 29 22:48:45 Davids-iMac.local homed[3582]: ### Unable to parse serialized service
Dec 29 22:48:45 Davids-iMac.local homed[3582]: ### Unable to parse serialized accessory
Dec 29 22:48:45 Davids-iMac.local homed[3582]: [HAP Service Discovery] Failed HAP service discovery on accessory server <HAPAccessoryServerIP: 0x7f84f050c330> Device ID: 23:70:d6:0c:33:6a Model: RaZberry Protocol Version: 1.0 Source Version: (null) Config Number: 1 State Number: 1 with error: Error Domain=HMErrorDomain Code=66 "The operation couldn’t be completed. (HMErrorDomain error 66.)"
Dec 29 22:48:45 Davids-iMac.local homed[3582]: Failed to add accessory RaZberry with error: Error Domain=HMErrorDomain Code=66 "The operation couldn’t be completed. (HMErrorDomain error 66.)"
Dec 29 22:48:45 Davids-iMac.local HomeKitDemo[3561]: Error Domain=HMErrorDomain Code=66 "The operation couldn’t be completed. (HMErrorDomain error 66.)"
Hey, looks like one accessory had invalide type of value for characteristic.
I removed all z-Wave devices from Razberry and added some of them again.
Now the pairing with HomeKit App is working! Thank you guys for your nice support!
Cant wait for z-way server supporting more accessories for HomeKit
Yes, there are a few issues in JS code when device metric has no value. We'll fix them soon.
When I try to add the razberry to homekit, I get the following error (after entering the PIN):
“The requested change is higher then the highest possible option”
Any idea?
Razberry v2.0.1 release
Any idea?
