[Solved] My first system
cpighin
Re: [Solved] My first system
Post by cpighin »
:) Thanks Andrea for your contribution.
If I have not misunderstood, your script performs almost the same function as the 2 LogicalRules that I implemented, but does so with a different tool.
Because I'm ignorant in this field, how I could use the files that you posted with your attachment?
Claudio :)
ilcato
Post by ilcato »
1. Put the unzipped folder with the 2 files within the userModules folder of the z-way server (default is: /opt/z-way-server/automation/userModules)
2. Stop the z-way server (sudo /etc/init.d/z-way-server stop)
3. Start the z-way server (sudo /etc/init.d/z-way-server start)
4. Look for a new automation module through the preferences panel within the HA UI
Andrea
cpighin
Post by cpighin »
:) Andrea,
I followed your instructions:
- I started my RPI2,
- I used the file manager to copy the folder AutoOffSmart containing the two files index.js and module.json in /opt/z-way-server/automation/userModules,
- I stopped and restarted the server Z-way with the commands:
- I opened the HA interface UI and did not find the new module in the path Preferences > Automation, as expected.
Where did I go wrong?
Claudio :)
ilcato
Post by ilcato »
try to put it in modules instead of userModules.
cpighin
Post by cpighin »
:) Andrea,
I tried to move the folder AUtoOffSmart from /opt/z-way-server/automation/userModules to /opt/z-way-server/automation/modules without achieving the desired result. I then moved it back to the initial position.
This surprised me because a few days ago I complained that the old warnings were not removed due to a bug in the system and I was sure to find them into the dashborad along with any new ones. Surprisingly there was only one, this:
Type: core
Timestamp: 16/05/15-14:13
Message:
Can not load modules.json from userModules/AutoOffSmart/module.json: SyntaxError: Unexpected token “
I told myself that it is not true that the old warning are not removed.
Can a Z-way expert clarify this point?
I am not savvy enough to figure out what to do, but I sense that the warning was generated as a result of the move of the folder in the folder AutoOffSmart userModules and may be due to a syntax error in the file module.json.
Comments?
Claudio :)
ilcato
Post by ilcato »
There was an error in the file. Try with the one attached.
Andrea
AutoOffSmart.zip
(3.69 KiB) Downloaded 666 times
cpighin
Post by cpighin »
Andrea,
I inserted the new folder with the file you modified in /opt/z-way-server/automation/userModules and I got the following warning:
Type: core
Timestamp: 16/05/15-20:17
Message:
while the previous one was not present.
I noticed in the timestamp 20:17 while my pc was reporting 21:17.
Claudio :)
ilcato
Post by ilcato »
Be sure to download the latest zip file. The error you receive is exactly the one I corrected: there was a “ character instead of ".
It works for me.
Andrea
cpighin
Post by cpighin »
Andea,
what follows is the current contents of file module.json, located in the folder x
    "singleton": false,
    "dependencies": [],
    "category": "scheduling",
    "author": "ilcato",
    "homepage": "",
    "icon": "",
    "version": "1.0",
    "maturity": "stable",
    "repository": {
            "type": "",
            "source": ""
    "defaults": {
        "title": "Auto Off Smart",
        "description": "Automatically turn of devices after N seconds only if the controlling sensor is off",
        "timeout": 5,
        "device": ""
    "schema": {
        "type": "object",
        "properties": {
            "device": {
                "field": "enum",
                "datasource": "namespaces",
                "enum": "namespaces:devices_switchBinary:deviceId,namespaces:devices_switchMultilevel:deviceId",
                "required": true
            "controllingDevice": {
                "field": "enum",
                "enum": "namespaces:devices_sensorBinary:deviceId",
                "required": true
            "timeout": {
                "type": "number",
                "required": true
        "required": false
    "options": {
        "fields": {
            "device": {
                "label": "The device to be turned off after the timeout",
                "field": "optionLabels",
                "optionLabels": "namespaces:devices_switchBinary:deviceName,namespaces:devices_switchMultilevel:deviceName"
                "label": "The binary sensor that control the device",
                "optionLabels": "namespaces:devices_sensorBinary:deviceName"
            "timeout": {
                "label": "Timeout in seconds"
Now in the dashboard I see the previous warning and the new one:
[CORE] Can not load modules.json from userModules/AutoOffSmart/module.json: SyntaxError: Unexpected token “
Type: core
Timestamp: 17/05/15-14:31
Message:
Can not create vDev based on 2-0-48: TypeError: Cannot read property 'get' of undefined
Additional Note: few minutes ago I changed battery to my Multisensor device!
Claudio :)
cpighin
Post by cpighin »
Andrea,
here attached the content of the final part of the file /var/log/z-way-server.log of my raspberry (since this morning I started and restarted a couple of times the Raspi).
The warnings have not changed (are the three previously reported)
ecco in allegato il contenuto dellla parte finale del file /var/log/z-way-server.log del raspberry (da quando questa mattina ho avviato e riavviato un paio di volte il Raspi).
Gli warnings non sono cambiati (sono i 3 già riportati)
Claudio :)
z-way-server.log.zip
(23.29 KiB) Downloaded 678 times
