Problem Inclusion Fibaro RGBW Controller 2 FGRGBWM-442
lanbrown
Re: Problem Inclusion Fibaro RGBW Controller 2 FGRGBWM-442
Post by lanbrown »
Dumperios wrote:
04 Sep 2022 17:39
@IanBrown: yes, but what about the RGBW controllers. As you can see in the Attachment, the controllers have different Z-Wave-Versions and different Device Firmware Version. The RGBW Controller with number 9 is the working one. It has an older Z-Wave Version 4.54.02 and the Firmware Version is much older two. Numbers 29 and 30 are the newer controllers where Z-Wave Version and Firmware are much higher.
The SDK/firmware version ≠ a series. One is software, the other is hardware.
Please show the log and add comments what really happened at which moment
Dumperios
Post by Dumperios »
The attachment shows a commented part of the z-way-server.log.
z-way-server.zip
(6.85 KiB) Downloaded 1333 times
Thanks, checked it. The bug was already fixed in April (right after 3.2.3 was released) and is already part of the v4.0.0. We will make a release of the v4.0.0 soon.
Dumperios
Post by Dumperios »
Do you have an idea, when the release v4.0.0 will come out?
Dumperios
Post by Dumperios »
after still using z-way-server 3.2.3 I tried to upgrade to the newest z-way-server version, but the new build image doesn't start.
Dockerfile:
FROM balenalib/rpi-raspbian
WORKDIR /opt/z-way-server
RUN apt-get update && \
    apt-get install -qqy --no-install-recommends \
    ca-certificates curl \
    wget procps gpg iproute2 openssh-client logrotate
RUN wget -q -O - https://storage.z-wave.me/RaspbianInstall | sudo bash
EXPOSE 8083
Docker-Compose:
version: '3.8'
services:
  z-way:
    container_name: z-way
    build: ./z-way-builder
    image: z-way
    restart: always
    expose:
     - 8083
    ports:
     - 8083:8083
    volumes:
     - z-way-config:/opt/z-way-server/config
     - z-way-automation-storage:/opt/z-way-server/automation/storage
     - z-way-htdocs-smarthome-user:/opt/z-way-server/htdocs/smarthome/user
     - z-way-zddx:/opt/z-way-server/ZDDX
     - z-way-log:/var/log
    devices:
     - '/dev/ttyAMA0:/dev/ttyAMA0'
    networks:
      - app-nw
      - backend-nw
volumes:
  z-way-config:
  z-way-zddx:
  z-way-log:
networks:
  app-nw:
    internal: false
    driver: bridge
    driver_opts:
      com.docker.network.bridge.name: app-${PROJECT_NAME}
  backend-nw:
    internal: true
    driver: bridge
    driver_opts:
      com.docker.network.bridge.name: be-${PROJECT_NAME}
I built the image with the this command:
docker-compose build --no-cache z-way
Build-Output:
root@raspberrypi:/opt/openhab3# docker-compose build --no-cache z-way
Building z-way
Sending build context to Docker daemon  2.048kB
Step 1/6 : FROM balenalib/rpi-raspbian
 ---> 438d2cc59a55
Step 2/6 : WORKDIR /opt/z-way-server
 ---> [Warning] The requested image's platform (linux/arm/v6) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
 ---> Running in b2b818a06f31
Removing intermediate container b2b818a06f31
 ---> d99dfc0d32e5
Step 3/6 : ENV DEBIAN_FRONTEND=noninteractive
 ---> Running in 9d799d2e903c
Removing intermediate container 9d799d2e903c
 ---> 50e7c602d171
Step 4/6 : RUN apt-get update &&     apt-get install -qqy --no-install-recommends     ca-certificates curl     wget procps gpg iproute2 openssh-client logrotate
 ---> Running in 1e7b0cc7edf9
Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Get:2 http://archive.raspbian.org/raspbian bullseye InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [313 kB]
Get:4 http://archive.raspbian.org/raspbian bullseye/contrib armhf Packages [70.3 kB]
Get:5 http://archive.raspbian.org/raspbian bullseye/rpi armhf Packages [1299 B]
Get:6 http://archive.raspbian.org/raspbian bullseye/firmware armhf Packages [1201 B]
Get:7 http://archive.raspbian.org/raspbian bullseye/main armhf Packages [18.3 MB]
Get:8 http://archive.raspbian.org/raspbian bullseye/non-free armhf Packages [130 kB]
Fetched 18.8 MB in 5s (3654 kB/s)
Reading package lists...
W: Skipping acquire of configured file 'ui/binary-armhf/Packages' as repository 'http://archive.raspberrypi.org/debian bullseye InRelease' doesn't have the component 'ui' (component misspelt in sources.list?)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package sensible-utils.
(Reading database ... 7899 files and directories currently installed.)
Preparing to unpack .../sensible-utils_0.0.14_all.deb ...
Unpacking sensible-utils (0.0.14) ...
Selecting previously unselected package cron.
Preparing to unpack .../cron_3.0pl1-137_armhf.deb ...
Unpacking cron (3.0pl1-137) ...
Preparing to unpack .../gnupg-l10n_2.2.27-2+deb11u2_all.deb ...
Unpacking gnupg-l10n (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gnupg-l10n (2.2.27-2+deb11u2) ...
(Reading database ... 7956 files and directories currently installed.)
Preparing to unpack .../gnupg-utils_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gnupg-utils (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gnupg-utils (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpgconf_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpgconf (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpgconf (2.2.27-2+deb11u2) ...
Preparing to unpack .../dirmngr_2.2.27-2+deb11u2_armhf.deb ...
Unpacking dirmngr (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up dirmngr (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpg_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpg (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpg-agent_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg-agent (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpg-agent (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpg-wks-client_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg-wks-client (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpg-wks-client (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpg-wks-server_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg-wks-server (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpg-wks-server (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpgv_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpgv (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpgv (2.2.27-2+deb11u2) ...
Preparing to unpack .../gpgsm_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpgsm (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gpgsm (2.2.27-2+deb11u2) ...
Preparing to unpack .../gnupg_2.2.27-2+deb11u2_all.deb ...
Unpacking gnupg (2.2.27-2+deb11u2) over (2.2.27-2+deb11u1) ...
Setting up gnupg (2.2.27-2+deb11u2) ...
Selecting previously unselected package libelf1:armhf.
Preparing to unpack .../00-libelf1_0.183-1_armhf.deb ...
Unpacking libelf1:armhf (0.183-1) ...
Selecting previously unselected package libbpf0:armhf.
Preparing to unpack .../01-libbpf0_1%3a0.3-2+rpi1_armhf.deb ...
Unpacking libbpf0:armhf (1:0.3-2+rpi1) ...
Selecting previously unselected package libmd0:armhf.
Preparing to unpack .../02-libmd0_1.0.3-3_armhf.deb ...
Unpacking libmd0:armhf (1.0.3-3) ...
Selecting previously unselected package libbsd0:armhf.
Preparing to unpack .../03-libbsd0_0.11.3-1+deb11u1_armhf.deb ...
Unpacking libbsd0:armhf (0.11.3-1+deb11u1) ...
Selecting previously unselected package libcap2:armhf.
Preparing to unpack .../04-libcap2_1%3a2.44-1_armhf.deb ...
Unpacking libcap2:armhf (1:2.44-1) ...
Selecting previously unselected package libmnl0:armhf.
Preparing to unpack .../05-libmnl0_1.0.4-3_armhf.deb ...
Unpacking libmnl0:armhf (1.0.4-3) ...
Selecting previously unselected package libxtables12:armhf.
Preparing to unpack .../06-libxtables12_1.8.7-1_armhf.deb ...
Unpacking libxtables12:armhf (1.8.7-1) ...
Selecting previously unselected package libcap2-bin.
Preparing to unpack .../07-libcap2-bin_1%3a2.44-1_armhf.deb ...
Unpacking libcap2-bin (1:2.44-1) ...
Selecting previously unselected package iproute2.
Preparing to unpack .../08-iproute2_5.10.0-4_armhf.deb ...
Unpacking iproute2 (5.10.0-4) ...
Selecting previously unselected package libpopt0:armhf.
Preparing to unpack .../09-libpopt0_1.18-2_armhf.deb ...
Unpacking libpopt0:armhf (1.18-2) ...
Selecting previously unselected package logrotate.
Preparing to unpack .../10-logrotate_3.18.0-2+deb11u2_armhf.deb ...
Unpacking logrotate (3.18.0-2+deb11u2) ...
Selecting previously unselected package libedit2:armhf.
Preparing to unpack .../11-libedit2_3.1-20191231-2_armhf.deb ...
Unpacking libedit2:armhf (3.1-20191231-2) ...
Selecting previously unselected package libcbor0:armhf.
Preparing to unpack .../12-libcbor0_0.5.0+dfsg-2_armhf.deb ...
Unpacking libcbor0:armhf (0.5.0+dfsg-2) ...
Selecting previously unselected package libfido2-1:armhf.
Preparing to unpack .../13-libfido2-1_1.6.0-2_armhf.deb ...
Unpacking libfido2-1:armhf (1.6.0-2) ...
Selecting previously unselected package openssh-client.
Preparing to unpack .../14-openssh-client_1%3a8.4p1-5+deb11u3_armhf.deb ...
Unpacking openssh-client (1:8.4p1-5+deb11u3) ...
Selecting previously unselected package wget.
Preparing to unpack .../15-wget_1.21-1+deb11u1_armhf.deb ...
Unpacking wget (1.21-1+deb11u1) ...
Preparing to unpack .../16-curl_7.74.0-1.3+deb11u11_armhf.deb ...
Unpacking curl (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u1) ...
Preparing to unpack .../17-libcurl4_7.74.0-1.3+deb11u11_armhf.deb ...
Unpacking libcurl4:armhf (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u1) ...
Setting up wget (1.21-1+deb11u1) ...
Setting up libcbor0:armhf (0.5.0+dfsg-2) ...
Setting up libcap2:armhf (1:2.44-1) ...
Setting up libcap2-bin (1:2.44-1) ...
Setting up libmnl0:armhf (1.0.4-3) ...
Setting up libxtables12:armhf (1.8.7-1) ...
Setting up libmd0:armhf (1.0.3-3) ...
Setting up sensible-utils (0.0.14) ...
Setting up libcurl4:armhf (7.74.0-1.3+deb11u11) ...
Setting up curl (7.74.0-1.3+deb11u11) ...
Setting up libfido2-1:armhf (1.6.0-2) ...
Setting up libbsd0:armhf (0.11.3-1+deb11u1) ...
Setting up libelf1:armhf (0.183-1) ...
Setting up libpopt0:armhf (1.18-2) ...
Setting up libedit2:armhf (3.1-20191231-2) ...
Setting up cron (3.0pl1-137) ...
Adding group `crontab' (GID 104) ...
Done.
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up libbpf0:armhf (1:0.3-2+rpi1) ...
Setting up logrotate (3.18.0-2+deb11u2) ...
Setting up iproute2 (5.10.0-4) ...
Setting up openssh-client (1:8.4p1-5+deb11u3) ...
Processing triggers for libc-bin (2.31-13+rpi1+deb11u3) ...
Removing intermediate container 1e7b0cc7edf9
 ---> 3b60b253935e
Step 5/6 : RUN wget -q -O - https://storage.z-wave.me/RaspbianInstall | sudo bash
 ---> Running in 98d49d16256a
Hit:1 http://archive.raspbian.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Building dependency tree...
Reading state information...
dirmngr is already the newest version (2.2.27-2+deb11u2).
gnupg is already the newest version (2.2.27-2+deb11u2).
wget is already the newest version (1.21-1+deb11u1).
The following NEW packages will be installed:
  apt-transport-https
0 upgraded, 1 newly installed, 0 to remove and 38 not upgraded.
Need to get 160 kB of archives.
After this operation, 166 kB of additional disk space will be used.
Get:1 http://archive.raspbian.org/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB]
Fetched 160 kB in 0s (1068 kB/s)
Selecting previously unselected package apt-transport-https.
(Reading database ... 8413 files and directories currently installed.)
Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
Unpacking apt-transport-https (2.2.4) ...
Setting up apt-transport-https (2.2.4) ...
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Executing: /tmp/apt-key-gpghome.7YzU3NDM8B/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 5b2f88a91611e683
gpg: key 5B2F88A91611E683: public key "Z-Wave.Me <info@z-wave.me>" imported
gpg: Total number processed: 1
gpg:               imported: 1
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://archive.raspbian.org/raspbian bullseye InRelease
Get:3 https://repo.z-wave.me/z-way/raspbian bullseye InRelease [1808 B]
Get:4 https://repo.z-wave.me/z-way/raspbian bullseye/main armhf Packages [1337 B]
Fetched 3145 B in 1s (4079 B/s)
The following additional packages will be installed:
  avahi-daemon bind9-host bind9-libs dbus gawk libapparmor1 libarchive13
  libatomic1 libavahi-client-dev libavahi-client3 libavahi-common-data
  libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
  libavahi-compat-libdnssd1 libavahi-core7 libc-ares2 libcurl3-gnutls
  libdaemon0 libdbus-1-3 libdbus-1-dev libdpkg-perl libev4 libexpat1 libfstrm0
  libgdbm-compat4 libgdbm6 libglib2.0-0 libicu67 libjson-c5 liblmdb0
  libmaxminddb0 libmosquitto1 libmpfr6 libnss-mdns libperl5.32 libprotobuf-c1
  libsigsegv2 libuv1 libwebsockets16 libxml2 net-tools perl perl-modules-5.32
  pkg-config sharutils
Suggested packages:
  avahi-autoipd default-dbus-session-bus | dbus-session-bus gawk-doc lrzip
  debian-keyring gcc | c-compiler binutils patch git bzr gdbm-l10n mmdb-bin
  avahi-autoipd | zeroconf perl-doc libterm-readline-gnu-perl
  | libterm-readline-perl-perl make libtap-harness-archive-perl dpkg-dev
  sharutils-doc bsd-mailx | mailx
Recommended packages:
  libfile-fcntllock-perl bzip2 xz-utils libglib2.0-data shared-mime-info
  xdg-user-dirs
  pkg-config sharutils webif z-way-full z-way-server zbw
0 upgraded, 50 newly installed, 0 to remove and 38 not upgraded.
Need to get 65.0 MB of archives.
After this operation, 99.5 MB of additional disk space will be used.
Get:1 http://archive.raspbian.org/raspbian bullseye/main armhf libapparmor1 armhf 2.13.6-10 [94.9 kB]
Get:2 http://archive.raspbian.org/raspbian bullseye/main armhf libdbus-1-3 armhf 1.12.28-0+deb11u1 [198 kB]
Get:3 http://archive.raspbian.org/raspbian bullseye/main armhf libexpat1 armhf 2.2.10-2+deb11u5 [75.0 kB]
Get:4 https://repo.z-wave.me/z-way/raspbian bullseye/main armhf z-way-server armhf 4.1.2-wb1-lws16 [40.2 MB]
Get:5 http://archive.raspbian.org/raspbian bullseye/main armhf dbus armhf 1.12.28-0+deb11u1 [220 kB]
Get:6 http://archive.raspbian.org/raspbian bullseye/main armhf perl-modules-5.32 all 5.32.1-4+deb11u2 [2823 kB]
Get:7 http://archive.raspbian.org/raspbian bullseye/main armhf libgdbm6 armhf 1.19-2 [61.7 kB]
Get:8 http://archive.raspbian.org/raspbian bullseye/main armhf libgdbm-compat4 armhf 1.19-2 [44.5 kB]
Get:9 http://archive.raspbian.org/raspbian bullseye/main armhf libperl5.32 armhf 5.32.1-4+deb11u2 [3373 kB]
Get:10 http://archive.raspbian.org/raspbian bullseye/main armhf perl armhf 5.32.1-4+deb11u2 [293 kB]
Get:11 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-common-data armhf 0.8-5+deb11u2 [124 kB]
Get:12 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-common3 armhf 0.8-5+deb11u2 [55.7 kB]
Get:13 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-core7 armhf 0.8-5+deb11u2 [107 kB]
Get:14 http://archive.raspbian.org/raspbian bullseye/main armhf libdaemon0 armhf 0.14-7.1 [13.4 kB]
Get:15 http://archive.raspbian.org/raspbian bullseye/main armhf libuv1 armhf 1.40.0-2 [119 kB]
Get:16 http://archive.raspbian.org/raspbian bullseye/main armhf libatomic1 armhf 10.2.1-6+rpi1 [8212 B]
Get:17 http://archive.raspbian.org/raspbian bullseye/main armhf libfstrm0 armhf 0.6.0-1+b1 [18.1 kB]
Get:18 http://archive.raspbian.org/raspbian bullseye/main armhf libjson-c5 armhf 0.15-2+deb11u1 [38.8 kB]
Get:19 http://archive.raspbian.org/raspbian bullseye/main armhf liblmdb0 armhf 0.9.24-1 [38.7 kB]
Get:20 http://archive.raspbian.org/raspbian bullseye/main armhf libmaxminddb0 armhf 1.5.2-1 [28.3 kB]
Get:21 http://archive.raspbian.org/raspbian bullseye/main armhf libprotobuf-c1 armhf 1.3.3-1+b2 [24.8 kB]
Get:22 http://archive.raspbian.org/raspbian bullseye/main armhf libicu67 armhf 67.1-7 [8291 kB]
Get:23 http://archive.raspbian.org/raspbian bullseye/main armhf libxml2 armhf 2.9.10+dfsg-6.7+deb11u4 [581 kB]
Get:24 http://archive.raspbian.org/raspbian bullseye/main armhf bind9-libs armhf 1:9.16.44-1~deb11u1 [1279 kB]
Get:25 http://archive.raspbian.org/raspbian bullseye/main armhf bind9-host armhf 1:9.16.44-1~deb11u1 [309 kB]
Get:26 http://archive.raspbian.org/raspbian bullseye/main armhf avahi-daemon armhf 0.8-5+deb11u2 [91.2 kB]
Get:27 http://archive.raspbian.org/raspbian bullseye/main armhf libmpfr6 armhf 4.1.0-3 [803 kB]
Get:28 http://archive.raspbian.org/raspbian bullseye/main armhf libsigsegv2 armhf 2.13-1 [34.3 kB]
Get:29 http://archive.raspbian.org/raspbian bullseye/main armhf gawk armhf 1:5.1.0-1 [533 kB]
Get:30 http://archive.raspbian.org/raspbian bullseye/main armhf net-tools armhf 1.60+git20181103.0eebece-1 [223 kB]
Get:31 http://archive.raspbian.org/raspbian bullseye/main armhf libarchive13 armhf 3.4.3-2+deb11u1 [297 kB]
Get:32 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-client3 armhf 0.8-5+deb11u2 [58.3 kB]
Get:33 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-common-dev armhf 0.8-5+deb11u2 [69.5 kB]
Get:34 http://archive.raspbian.org/raspbian bullseye/main armhf libglib2.0-0 armhf 2.66.8-1 [1183 kB]
Get:35 http://archive.raspbian.org/raspbian bullseye/main armhf libdpkg-perl all 1.20.12+rpi1 [1551 kB]
Get:36 http://archive.raspbian.org/raspbian bullseye/main armhf pkg-config armhf 0.29.2-1 [61.5 kB]
Get:37 http://archive.raspbian.org/raspbian bullseye/main armhf libdbus-1-dev armhf 1.12.28-0+deb11u1 [229 kB]
Get:38 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-client-dev armhf 0.8-5+deb11u2 [66.3 kB]
Get:39 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-compat-libdnssd1 armhf 0.8-5+deb11u2 [50.9 kB]
Get:40 http://archive.raspbian.org/raspbian bullseye/main armhf libavahi-compat-libdnssd-dev armhf 0.8-5+deb11u2 [65.5 kB]
Get:41 http://archive.raspbian.org/raspbian bullseye/main armhf libc-ares2 armhf 1.17.1-1+deb11u3 [96.3 kB]
Get:42 http://archive.raspbian.org/raspbian bullseye/main armhf libcurl3-gnutls armhf 7.74.0-1.3+deb11u11 [306 kB]
Get:43 http://archive.raspbian.org/raspbian bullseye/main armhf libev4 armhf 1:4.33-1 [38.2 kB]
Get:44 http://archive.raspbian.org/raspbian bullseye/main armhf libmosquitto1 armhf 2.0.11-1+deb11u1 [83.9 kB]
Get:45 http://archive.raspbian.org/raspbian bullseye/main armhf libnss-mdns armhf 0.14.1-2 [25.2 kB]
Get:46 http://archive.raspbian.org/raspbian bullseye/main armhf libwebsockets16 armhf 4.0.20-2 [161 kB]
Get:47 http://archive.raspbian.org/raspbian bullseye/main armhf sharutils armhf 1:4.15.2-5 [236 kB]
Get:48 https://repo.z-wave.me/z-way/raspbian bullseye/main armhf webif armhf 1.5 [308 kB]
Get:49 https://repo.z-wave.me/z-way/raspbian bullseye/main armhf zbw armhf 2.6 [4272 B]
Get:50 https://repo.z-wave.me/z-way/raspbian bullseye/main armhf z-way-full armhf 1.0-latest-version [884 B]
Fetched 65.0 MB in 9s (6978 kB/s)
Selecting previously unselected package libapparmor1:armhf.
(Reading database ... 8417 files and directories currently installed.)
Preparing to unpack .../00-libapparmor1_2.13.6-10_armhf.deb ...
Unpacking libapparmor1:armhf (2.13.6-10) ...
Selecting previously unselected package libdbus-1-3:armhf.
Preparing to unpack .../01-libdbus-1-3_1.12.28-0+deb11u1_armhf.deb ...
Unpacking libdbus-1-3:armhf (1.12.28-0+deb11u1) ...
Selecting previously unselected package libexpat1:armhf.
Preparing to unpack .../02-libexpat1_2.2.10-2+deb11u5_armhf.deb ...
Unpacking libexpat1:armhf (2.2.10-2+deb11u5) ...
Selecting previously unselected package dbus.
Preparing to unpack .../03-dbus_1.12.28-0+deb11u1_armhf.deb ...
Unpacking dbus (1.12.28-0+deb11u1) ...
Selecting previously unselected package perl-modules-5.32.
Preparing to unpack .../04-perl-modules-5.32_5.32.1-4+deb11u2_all.deb ...
Unpacking perl-modules-5.32 (5.32.1-4+deb11u2) ...
Selecting previously unselected package libgdbm6:armhf.
Preparing to unpack .../05-libgdbm6_1.19-2_armhf.deb ...
Unpacking libgdbm6:armhf (1.19-2) ...
Selecting previously unselected package libgdbm-compat4:armhf.
Preparing to unpack .../06-libgdbm-compat4_1.19-2_armhf.deb ...
Unpacking libgdbm-compat4:armhf (1.19-2) ...
Selecting previously unselected package libperl5.32:armhf.
Preparing to unpack .../07-libperl5.32_5.32.1-4+deb11u2_armhf.deb ...
Unpacking libperl5.32:armhf (5.32.1-4+deb11u2) ...
Selecting previously unselected package perl.
Preparing to unpack .../08-perl_5.32.1-4+deb11u2_armhf.deb ...
Unpacking perl (5.32.1-4+deb11u2) ...
Selecting previously unselected package libavahi-common-data:armhf.
Preparing to unpack .../09-libavahi-common-data_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-common-data:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libavahi-common3:armhf.
Preparing to unpack .../10-libavahi-common3_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-common3:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libavahi-core7:armhf.
Preparing to unpack .../11-libavahi-core7_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-core7:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libdaemon0:armhf.
Preparing to unpack .../12-libdaemon0_0.14-7.1_armhf.deb ...
Unpacking libdaemon0:armhf (0.14-7.1) ...
Selecting previously unselected package libuv1:armhf.
Preparing to unpack .../13-libuv1_1.40.0-2_armhf.deb ...
Unpacking libuv1:armhf (1.40.0-2) ...
Selecting previously unselected package libatomic1:armhf.
Preparing to unpack .../14-libatomic1_10.2.1-6+rpi1_armhf.deb ...
Unpacking libatomic1:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libfstrm0:armhf.
Preparing to unpack .../15-libfstrm0_0.6.0-1+b1_armhf.deb ...
Unpacking libfstrm0:armhf (0.6.0-1+b1) ...
Selecting previously unselected package libjson-c5:armhf.
Preparing to unpack .../16-libjson-c5_0.15-2+deb11u1_armhf.deb ...
Unpacking libjson-c5:armhf (0.15-2+deb11u1) ...
Selecting previously unselected package liblmdb0:armhf.
Preparing to unpack .../17-liblmdb0_0.9.24-1_armhf.deb ...
Unpacking liblmdb0:armhf (0.9.24-1) ...
Selecting previously unselected package libmaxminddb0:armhf.
Preparing to unpack .../18-libmaxminddb0_1.5.2-1_armhf.deb ...
Unpacking libmaxminddb0:armhf (1.5.2-1) ...
Selecting previously unselected package libprotobuf-c1:armhf.
Preparing to unpack .../19-libprotobuf-c1_1.3.3-1+b2_armhf.deb ...
Unpacking libprotobuf-c1:armhf (1.3.3-1+b2) ...
Selecting previously unselected package libicu67:armhf.
Preparing to unpack .../20-libicu67_67.1-7_armhf.deb ...
Unpacking libicu67:armhf (67.1-7) ...
Selecting previously unselected package libxml2:armhf.
Preparing to unpack .../21-libxml2_2.9.10+dfsg-6.7+deb11u4_armhf.deb ...
Unpacking libxml2:armhf (2.9.10+dfsg-6.7+deb11u4) ...
Selecting previously unselected package bind9-libs:armhf.
Preparing to unpack .../22-bind9-libs_1%3a9.16.44-1~deb11u1_armhf.deb ...
Unpacking bind9-libs:armhf (1:9.16.44-1~deb11u1) ...
Selecting previously unselected package bind9-host.
Preparing to unpack .../23-bind9-host_1%3a9.16.44-1~deb11u1_armhf.deb ...
Unpacking bind9-host (1:9.16.44-1~deb11u1) ...
Selecting previously unselected package avahi-daemon.
Preparing to unpack .../24-avahi-daemon_0.8-5+deb11u2_armhf.deb ...
Unpacking avahi-daemon (0.8-5+deb11u2) ...
Selecting previously unselected package libmpfr6:armhf.
Preparing to unpack .../25-libmpfr6_4.1.0-3_armhf.deb ...
Unpacking libmpfr6:armhf (4.1.0-3) ...
Selecting previously unselected package libsigsegv2:armhf.
Preparing to unpack .../26-libsigsegv2_2.13-1_armhf.deb ...
Unpacking libsigsegv2:armhf (2.13-1) ...
Setting up libmpfr6:armhf (4.1.0-3) ...
Setting up libsigsegv2:armhf (2.13-1) ...
Selecting previously unselected package gawk.
(Reading database ... 10684 files and directories currently installed.)
Preparing to unpack .../00-gawk_1%3a5.1.0-1_armhf.deb ...
Unpacking gawk (1:5.1.0-1) ...
Selecting previously unselected package net-tools.
Preparing to unpack .../01-net-tools_1.60+git20181103.0eebece-1_armhf.deb ...
Unpacking net-tools (1.60+git20181103.0eebece-1) ...
Selecting previously unselected package libarchive13:armhf.
Preparing to unpack .../02-libarchive13_3.4.3-2+deb11u1_armhf.deb ...
Unpacking libarchive13:armhf (3.4.3-2+deb11u1) ...
Selecting previously unselected package libavahi-client3:armhf.
Preparing to unpack .../03-libavahi-client3_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-client3:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libavahi-common-dev:armhf.
Preparing to unpack .../04-libavahi-common-dev_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-common-dev:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libglib2.0-0:armhf.
Preparing to unpack .../05-libglib2.0-0_2.66.8-1_armhf.deb ...
Unpacking libglib2.0-0:armhf (2.66.8-1) ...
Selecting previously unselected package libdpkg-perl.
Preparing to unpack .../06-libdpkg-perl_1.20.12+rpi1_all.deb ...
Unpacking libdpkg-perl (1.20.12+rpi1) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../07-pkg-config_0.29.2-1_armhf.deb ...
Unpacking pkg-config (0.29.2-1) ...
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack .../08-libdbus-1-dev_1.12.28-0+deb11u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.12.28-0+deb11u1) ...
Selecting previously unselected package libavahi-client-dev:armhf.
Preparing to unpack .../09-libavahi-client-dev_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-client-dev:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
Preparing to unpack .../10-libavahi-compat-libdnssd1_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev:armhf.
Preparing to unpack .../11-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev:armhf (0.8-5+deb11u2) ...
Selecting previously unselected package libc-ares2:armhf.
Preparing to unpack .../12-libc-ares2_1.17.1-1+deb11u3_armhf.deb ...
Unpacking libc-ares2:armhf (1.17.1-1+deb11u3) ...
Selecting previously unselected package libcurl3-gnutls:armhf.
Preparing to unpack .../13-libcurl3-gnutls_7.74.0-1.3+deb11u11_armhf.deb ...
Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u11) ...
Selecting previously unselected package libev4:armhf.
Preparing to unpack .../14-libev4_1%3a4.33-1_armhf.deb ...
Unpacking libev4:armhf (1:4.33-1) ...
Selecting previously unselected package libmosquitto1:armhf.
Preparing to unpack .../15-libmosquitto1_2.0.11-1+deb11u1_armhf.deb ...
Unpacking libmosquitto1:armhf (2.0.11-1+deb11u1) ...
Selecting previously unselected package libnss-mdns:armhf.
Preparing to unpack .../16-libnss-mdns_0.14.1-2_armhf.deb ...
Unpacking libnss-mdns:armhf (0.14.1-2) ...
Selecting previously unselected package libwebsockets16:armhf.
Preparing to unpack .../17-libwebsockets16_4.0.20-2_armhf.deb ...
Unpacking libwebsockets16:armhf (4.0.20-2) ...
Selecting previously unselected package sharutils.
Preparing to unpack .../18-sharutils_1%3a4.15.2-5_armhf.deb ...
Unpacking sharutils (1:4.15.2-5) ...
Selecting previously unselected package z-way-server.
Preparing to unpack .../19-z-way-server_4.1.2-wb1-lws16_armhf.deb ...
Unpacking z-way-server (4.1.2-wb1-lws16) ...
Selecting previously unselected package webif.
Preparing to unpack .../20-webif_1.5_armhf.deb ...
Unpacking webif (1.5) ...
Selecting previously unselected package zbw.
Preparing to unpack .../21-zbw_2.6_armhf.deb ...
Unpacking zbw (2.6) ...
Selecting previously unselected package z-way-full.
Preparing to unpack .../22-z-way-full_1.0-latest-version_armhf.deb ...
Unpacking z-way-full (1.0-latest-version) ...
Setting up libexpat1:armhf (2.2.10-2+deb11u5) ...
Setting up liblmdb0:armhf (0.9.24-1) ...
Setting up net-tools (1.60+git20181103.0eebece-1) ...
Setting up libapparmor1:armhf (2.13.6-10) ...
Setting up libicu67:armhf (67.1-7) ...
Setting up gawk (1:5.1.0-1) ...
Setting up libglib2.0-0:armhf (2.66.8-1) ...
No schema files found: doing nothing.
Setting up libmosquitto1:armhf (2.0.11-1+deb11u1) ...
Setting up libmaxminddb0:armhf (1.5.2-1) ...
Setting up libev4:armhf (1:4.33-1) ...
Setting up perl-modules-5.32 (5.32.1-4+deb11u2) ...
Setting up libfstrm0:armhf (0.6.0-1+b1) ...
Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u11) ...
Setting up libc-ares2:armhf (1.17.1-1+deb11u3) ...
Setting up libprotobuf-c1:armhf (1.3.3-1+b2) ...
Setting up libuv1:armhf (1.40.0-2) ...
Setting up libavahi-common-data:armhf (0.8-5+deb11u2) ...
Setting up libdbus-1-3:armhf (1.12.28-0+deb11u1) ...
Setting up dbus (1.12.28-0+deb11u1) ...
Setting up libatomic1:armhf (10.2.1-6+rpi1) ...
Setting up sharutils (1:4.15.2-5) ...
Setting up libdaemon0:armhf (0.14-7.1) ...
Setting up libjson-c5:armhf (0.15-2+deb11u1) ...
Setting up libxml2:armhf (2.9.10+dfsg-6.7+deb11u4) ...
Setting up libgdbm6:armhf (1.19-2) ...
Setting up libwebsockets16:armhf (4.0.20-2) ...
Setting up bind9-libs:armhf (1:9.16.44-1~deb11u1) ...
Setting up libarchive13:armhf (3.4.3-2+deb11u1) ...
Setting up libavahi-common3:armhf (0.8-5+deb11u2) ...
Setting up libgdbm-compat4:armhf (1.19-2) ...
Setting up libperl5.32:armhf (5.32.1-4+deb11u2) ...
Setting up zbw (2.6) ...
Starting zbw_connect:A private key isn't found. Fetching...
--2024-01-06 18:17:43--  https://find.z-wave.me/zbw_new_user2?box_type=deb
Resolving find.z-wave.me (find.z-wave.me)... 185.25.224.111, 185.25.224.206, 194.190.114.100, ...
Connecting to find.z-wave.me (find.z-wave.me)|185.25.224.111|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘/etc/zbw/new.user’
/etc/zbw/new.user       [ <=>                ]   1.70K  --.-KB/s    in 0s
2024-01-06 18:17:43 (17.7 MB/s) - ‘/etc/zbw/new.user’ saved [1738]
ok.
Setting up libavahi-common-dev:armhf (0.8-5+deb11u2) ...
Setting up libavahi-core7:armhf (0.8-5+deb11u2) ...
Setting up bind9-host (1:9.16.44-1~deb11u1) ...
Setting up libavahi-client3:armhf (0.8-5+deb11u2) ...
Setting up libavahi-compat-libdnssd1:armhf (0.8-5+deb11u2) ...
Setting up perl (5.32.1-4+deb11u2) ...
Setting up libdpkg-perl (1.20.12+rpi1) ...
Setting up avahi-daemon (0.8-5+deb11u2) ...
invoke-rc.d: policy-rc.d denied execution of force-reload.
Setting up libnss-mdns:armhf (0.14.1-2) ...
First installation detected...
Checking NSS setup...
Setting up pkg-config (0.29.2-1) ...
Setting up libdbus-1-dev:armhf (1.12.28-0+deb11u1) ...
Setting up libavahi-client-dev:armhf (0.8-5+deb11u2) ...
Setting up libavahi-compat-libdnssd-dev:armhf (0.8-5+deb11u2) ...
Setting up z-way-server (4.1.2-wb1-lws16) ...
Setting default automation config
Raspberry Pi 4B Detected. Setting up miniUART for Bluetooth
grep: /boot/config.txt: No such file or directory
Adding 'dtoverlay=pi3-miniuart-bt' to /boot/config.txt
Starting z-way-server: done.
Setting up webif (1.5) ...
Setting up z-way-full (1.0-latest-version) ...
Processing triggers for dbus (1.12.28-0+deb11u1) ...
Removing intermediate container 98d49d16256a
 ---> 2c0976083851
Step 6/6 : EXPOSE 8083
 ---> Running in 04a15dad2b2e
Removing intermediate container 04a15dad2b2e
 ---> 36832fe25af6
Successfully built 36832fe25af6
Successfully tagged z-way:latest
I started z-way-server:
docker-compose up z-way
Docker PS shows that the Process is permanent restarting and docker logs shows nothing:
root@raspberrypi:/opt/openhab3# docker ps
CONTAINER ID   IMAGE     COMMAND                  CREATED         STATUS                  PORTS                                       NAMES
f32e420c6c00   z-way     "/usr/bin/entry.sh /…"   6 seconds ago   Up Less than a second   0.0.0.0:8083->8083/tcp, :::8083->8083/tcp   z-way
f32e420c6c00   z-way     "/usr/bin/entry.sh /…"   13 seconds ago   Up Less than a second   0.0.0.0:8083->8083/tcp, :::8083->8083/tcp   z-way
f32e420c6c00   z-way     "/usr/bin/entry.sh /…"   17 seconds ago   Restarting (0) 3 seconds ago             z-way
root@raspberrypi:/opt/openhab3# docker logs f32e420c6c00
Do you have a solution for this problem?
Looks like it requires another forum thread. Make sure to use armhf and not arm64 platform.
Dumperios
Post by Dumperios »
Okay, shall I shift or copy my post to a new threat?
In the log output I can see that it uses the armhf platform. The downloaded script made this decision.
The log output finished with the following messages:
 ---> 36832fe25af6
There is a warning, but in other Threads on the web I read, that this can be ignored.
