New iOS and Android apps for Z-Way
aLiEnHeAd
Re: New iOS and Android apps for Z-Way
Post by aLiEnHeAd »
I stopped z-way-server, copied your dev-version and started (build date in gui was 19-01-2021 23:04:22).
Opened the app (WiFi enabled) and cleared the cache.Tried to connect -> the issue remained: Loading-Circle and after that the "my hubs" button showed up.
Opened the app again with mobile data -> Connected without problems.
No suspicious output in z-way-server.log (but I guess the issue is on the client side, so is there a way to get some kind of debug logs from the client /app ?)
hm... we will see it again on our side.
This is only about UI (HTML/CSS/JS/AngularJS). So nothing to do with the Z-Way server (nothing in the log) - even no need to restart Z-Way when you change HTML files.
We check it on our side and come back to you.
Does this still make problems for you? New dev version under to be checked in the same way: https://forum.z-wave.me/viewtopic.php?p=89547#p89547
aLiEnHeAd
Post by aLiEnHeAd »
@PoltoS: Yes the problem still exists with the new dev version.
I also made two screen capture videos and sent it to support@z-wave.me. (Ticket #706159) Perhaps it helps to understand the behaviour...
Thanks, will ask support team
Locked
