lanbrown
Posts: 383 Joined: 01 Jun 2021 08:06
Post
by lanbrown » 31 May 2022 03:23
It seems there are quite a few complaints about the Leviton DZ15S switches and not updating their status.
Here is the same issue in Hubitat:
https://community.hubitat.com/t/zwave-s ... at/66019/5
One solution provided:
Ok, I found a post of someone with a similar problem which (s)he solved by turning off then on the circuit breaker for that switch. What do you know. It worked. Sure like to understand why though and why only the status updates were not working.
SmartThings:
https://community.smartthings.com/t/pro ... /21?page=2
HomeSeer:
https://forums.homeseer.com/forum/homes ... ant-status
So multiple home automation platforms all have the same issue with the same brand and model switches. So it seems like the prudent thing to do would be for @DisneyJoe to work directly with Leviton. Maybe there is a firmware update available. Given how old the Z-Way release you were running, chances are the switches have never been updated.
disneyjoe7
Posts: 29 Joined: 02 Oct 2016 04:15
Post
by disneyjoe7 » 31 May 2022 22:46
Hmm Don't know I'm a fan of Leviton switches and outlets don't use anything else. And would state was never issue with Razberryme 2 but had an issue with that equipment and 3.2.3 software. Got many of them so that would be a big issue. Not that I think Leviton and Z-wave love themselves, think things better. But then redoing all switches and outlets was better if I did a factory default first then inclusion update. Taking a 25min problem into a 90 seconds issue. So maybe it was a pilot issue and not a Leviton / Z-wave problem.
But knowing that I can turn the power off and problem may go away. I give that a try.
Steve
disneyjoe7
Post
by disneyjoe7 » 31 May 2022 23:12
well turning circuits off waited for 2 mins then back on same issue. If looking on a Laptop and looking at Z-wave website. Can turn on light via screen and it states green ON or OFF if I used the screen website. Website screen of Z-wave doesn't see if the switch / light was turned ON or OFF was turned on manual.
disneyjoe7
Post
by disneyjoe7 » 01 Jun 2022 06:19
[2022-05-31 22:59:00.103]
[core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 22:59:07.982] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 22:59:17.691] [zway] Adding job: Get background noise level
[2022-05-31 22:59:17.693] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 22:59:17.695] [D] [zway] RECEIVED ACK
[2022-05-31 22:59:17.695] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A7 A7 7F 15 )
[2022-05-31 22:59:17.695] [D] [zway] SENT ACK
[2022-05-31 22:59:47.691] [zway] Adding job: Get background noise level
[2022-05-31 22:59:47.699] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 22:59:47.701] [D] [zway] RECEIVED ACK
[2022-05-31 22:59:47.701] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A6 A6 7F 15 )
[2022-05-31 22:59:47.701] [D] [zway] SENT ACK
[2022-05-31 22:59:47.702] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 166 (0x000000a6)
[2022-05-31 22:59:47.702] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -90 dBm, Ch#3: -90 dBm
[2022-05-31 22:59:47.702] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 22:59:47.702] [zway] Removing job: Get background noise level
[2022-05-31 23:00:00.460] [core] --- ZWayVDev_zway_11-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.461] [zway] Adding job: SwitchBinary Set to node 11
[2022-05-31 23:00:00.461] [zway] Adding job: SwitchBinary Get to node 11
[2022-05-31 23:00:00.461] [core] --- ZWayVDev_zway_8-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.461] [zway] Adding job: SwitchBinary Set to node 8
[2022-05-31 23:00:00.462] [I] [core] --- ZWayVDev_zway_9-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.462] [I] [zway] Adding job: SwitchBinary Set to node 9
[2022-05-31 23:00:00.467] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:00:00.469] [D] [zway] SENDING (cb 0x75): ( 01 0B 00 13 0B 04 25 01 00 FF 25 75 63 )
[2022-05-31 23:00:00.470] [I] [core] --- ZWayVDev_zway_11-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.470] [I] [zway] Adding job: SwitchBinary Set to node 11
[2022-05-31 23:00:00.470] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:00.471] [I] [core] --- ZWayVDev_zway_8-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.471] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:00.471] [I] [core] --- ZWayVDev_zway_9-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.471] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:00.473] [I] [core] --- ZWayVDev_zway_11-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.473] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:00.473] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:00.473] [D] [zway] SENT ACK
[2022-05-31 23:00:00.473] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:00.473] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:00.474] [I] [core] --- ZWayVDev_zway_8-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.474] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:00.474] [I] [core] --- ZWayVDev_zway_9-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:00.493] [D] [zway] RECEIVED: ( 01 1D 00 13 75 00 00 01 00 A8 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 52 )
[2022-05-31 23:00:00.493] [D] [zway] SENT ACK
[2022-05-31 23:00:00.493] [I] [zway] Job 0x13 (SwitchBinary Set to node 11): Delivered
[2022-05-31 23:00:00.494] [D] [zway] SendData Response with callback 0x75 received: received by recipient
[2022-05-31 23:00:00.494] [D] [zway] SETDATA devices.11.data.lastSendInternal = **********
[2022-05-31 23:00:00.494] [D] [zway] SETDATA devices.11.data.lastSend = 2451717 (0x00256905)
[2022-05-31 23:00:00.494] [D] [zway] Job 0x13 (SwitchBinary Set to node 11): success
[2022-05-31 23:00:00.494] [I] [zway] Removing job: SwitchBinary Set to node 11
[2022-05-31 23:00:00.494] [D] [zway] SENDING (cb 0x76): ( 01 0B 00 13 08 04 25 01 00 FF 25 76 63 )
[2022-05-31 23:00:00.496] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:00.498] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:00.498] [D] [zway] SENT ACK
[2022-05-31 23:00:00.498] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:00.560] [D] [zway] RECEIVED: ( 01 1D 00 13 76 00 00 05 02 B3 CD B5 7F 7F 00 00 03 03 05 00 00 03 01 00 00 7F 7F 7F 7F 7F 33 )
[2022-05-31 23:00:00.560] [D] [zway] SENT ACK
[2022-05-31 23:00:00.560] [I] [zway] Job 0x13 (SwitchBinary Set to node 8): Delivered
[2022-05-31 23:00:00.560] [D] [zway] SendData Response with callback 0x76 received: received by recipient
[2022-05-31 23:00:00.560] [D] [zway] SETDATA devices.8.data.lastSendInternal = **********
[2022-05-31 23:00:00.561] [D] [zway] SETDATA devices.8.data.lastSend = 2451722 (0x0025690a)
[2022-05-31 23:00:00.561] [D] [zway] Job 0x13 (SwitchBinary Set to node 8): success
[2022-05-31 23:00:00.561] [I] [zway] Removing job: SwitchBinary Set to node 8
[2022-05-31 23:00:00.561] [D] [zway] SENDING (cb 0x77): ( 01 0B 00 13 0B 04 25 01 00 FF 25 77 61 )
[2022-05-31 23:00:00.563] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:00.564] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:00.564] [D] [zway] SENT ACK
[2022-05-31 23:00:00.564] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:00.583] [D] [zway] RECEIVED: ( 01 1D 00 13 77 00 00 01 00 A8 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 50 )
[2022-05-31 23:00:00.583] [D] [zway] SENT ACK
[2022-05-31 23:00:00.583] [I] [zway] Job 0x13 (SwitchBinary Set to node 11): Delivered
[2022-05-31 23:00:00.584] [D] [zway] SendData Response with callback 0x77 received: received by recipient
[2022-05-31 23:00:00.584] [D] [zway] SETDATA devices.11.data.lastSendInternal = **********
[2022-05-31 23:00:00.584] [D] [zway] SETDATA devices.11.data.lastSend = 2451723 (0x0025690b)
[2022-05-31 23:00:00.584] [D] [zway] Job 0x13 (SwitchBinary Set to node 11): success
[2022-05-31 23:00:00.584] [I] [zway] Removing job: SwitchBinary Set to node 11
[2022-05-31 23:00:00.584] [D] [zway] SENDING (cb 0x78): ( 01 0B 00 13 09 04 25 01 00 FF 25 78 6C )
[2022-05-31 23:00:00.586] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:00.588] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:00.588] [D] [zway] SENT ACK
[2022-05-31 23:00:00.588] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:00.604] [D] [zway] RECEIVED: ( 01 1D 00 13 78 00 00 01 00 B1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 47 )
[2022-05-31 23:00:00.604] [D] [zway] SENT ACK
[2022-05-31 23:00:00.605] [I] [zway] Job 0x13 (SwitchBinary Set to node 9): Delivered
[2022-05-31 23:00:00.605] [D] [zway] SendData Response with callback 0x78 received: received by recipient
[2022-05-31 23:00:00.605] [D] [zway] SETDATA devices.9.data.lastSendInternal = **********
[2022-05-31 23:00:00.605] [D] [zway] SETDATA devices.9.data.lastSend = 2451724 (0x0025690c)
[2022-05-31 23:00:00.605] [D] [zway] Job 0x13 (SwitchBinary Set to node 9): success
[2022-05-31 23:00:00.605] [I] [zway] Removing job: SwitchBinary Set to node 9
[2022-05-31 23:00:00.610] [D] [zway] RECEIVED: ( 01 0B 00 04 00 09 02 82 01 B0 00 00 C8 )
[2022-05-31 23:00:00.610] [D] [zway] SENT ACK
[2022-05-31 23:00:00.610] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:00.610] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:00.611] [W] [zway] Got unsecure packet from device 9, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:00.611] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:00.635] [D] [zway] SENDING (cb 0x79): ( 01 09 00 13 0B 02 25 02 25 79 97 )
[2022-05-31 23:00:00.636] [D] [zway] RECEIVED: ( 01 16 00 04 00 08 02 82 01 B2 00 0B 10 01 00 22 05 03 82 01 D9 1A 7F D7 )
[2022-05-31 23:00:00.636] [D] [zway] SENT ACK
[2022-05-31 23:00:00.636] [D] [zway] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:00.636] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:00.636] [W] [zway] Got unsecure packet from device 8, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:00.637] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:00.637] [D] [zway] RECEIVED CAN
[2022-05-31 23:00:00.648] [D] [zway] SENDING (cb 0x7a): ( 01 09 00 13 0B 02 25 02 25 7A 94 )
[2022-05-31 23:00:00.649] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:00.651] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:00.651] [D] [zway] SENT ACK
[2022-05-31 23:00:00.651] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:00.731] [D] [zway] RECEIVED: ( 01 1D 00 13 7A 00 00 07 00 A8 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 5B )
[2022-05-31 23:00:00.733] [D] [zway] SENT ACK
[2022-05-31 23:00:00.733] [I] [zway] Job 0x13 (SwitchBinary Get to node 11): Delivered
[2022-05-31 23:00:00.736] [D] [zway] SendData Response with callback 0x7a received: received by recipient
[2022-05-31 23:00:00.736] [D] [zway] SETDATA devices.11.data.lastSendInternal = **********
[2022-05-31 23:00:00.736] [D] [zway] SETDATA devices.11.data.lastSend = 2451734 (0x00256916)
[2022-05-31 23:00:00.736] [D] [zway] Job 0x13 (SwitchBinary Get to node 11): success
[2022-05-31 23:00:00.736] [I] [zway] Waiting for job reply: SwitchBinary Get from node 11
[2022-05-31 23:00:00.761] [D] [zway] RECEIVED: ( 01 15 00 04 00 09 02 82 01 BB 00 0A 0F 01 00 11 04 82 01 29 D9 1A A5 )
[2022-05-31 23:00:00.761] [D] [zway] SENT ACK
[2022-05-31 23:00:00.762] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:00.762] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:00.762] [W] [zway] Got unsecure packet from device 9, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:00.762] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:00.845] [D] [zway] RECEIVED: ( 01 0C 00 04 00 0B 02 82 01 B2 00 01 10 DE )
[2022-05-31 23:00:00.845] [D] [zway] SENT ACK
[2022-05-31 23:00:00.846] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:00.846] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:00.846] [W] [zway] Got unsecure packet from device 11, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:00.846] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:00.928] [D] [zway] RECEIVED: ( 01 19 00 04 00 0B 02 82 01 B6 00 0E 0F 01 00 11 03 82 01 93 B5 7F 75 3A 89 08 D8 )
[2022-05-31 23:00:00.928] [D] [zway] SENT ACK
[2022-05-31 23:00:00.929] [W] [zway] Discarding duplicate packet from node 11
[2022-05-31 23:00:00.971] [D] [zway] RECEIVED: ( 01 19 00 04 00 0B 02 82 01 B6 00 0E 0F 01 00 11 03 82 01 93 B5 7F 69 A0 89 D8 8E )
[2022-05-31 23:00:00.972] [D] [zway] SENT ACK
[2022-05-31 23:00:00.972] [W] [zway] Discarding duplicate packet from node 11
[2022-05-31 23:00:01.047] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0B 02 82 01 A8 00 00 D2 )
[2022-05-31 23:00:01.047] [D] [zway] SENT ACK
[2022-05-31 23:00:01.048] [W] [zway] Discarding duplicate packet from node 11
[2022-05-31 23:00:01.100] [D] [zway] RECEIVED: ( 01 0C 00 04 00 0B 03 25 03 00 A8 00 00 71 )
[2022-05-31 23:00:01.100] [D] [zway] SENT ACK
[2022-05-31 23:00:01.101] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:01.101] [D] [zway] Received reply on job (SwitchBinary Get to node 11)
[2022-05-31 23:00:01.101] [D] [zway] SETDATA devices.11.instances.0.commandClasses.37.data.level = False
[2022-05-31 23:00:01.106] [I] [core] HK: updated ZWayVDev_zway_11-0-37
[2022-05-31 23:00:01.111] [I] [core] Notification: device-info (device-OnOff): {"dev":"Back Porch Light","l":"off","location":2}
[2022-05-31 23:00:01.256] [D] [zway] RECEIVED: ( 01 16 00 04 00 05 02 82 01 B7 00 0B 0F 01 00 11 03 82 01 E2 FF 7F 69 41 )
[2022-05-31 23:00:01.256] [D] [zway] SENT ACK
[2022-05-31 23:00:01.257] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:01.257] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:01.257] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:01.257] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:02.346] [D] [zway] Node 8:0 CC SwitchBinary: Unsolicited report not received, sending Get
[2022-05-31 23:00:02.346] [I] [zway] Adding job: SwitchBinary Get to node 8
[2022-05-31 23:00:02.346] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:02.356] [D] [zway] SENDING (cb 0x7b): ( 01 09 00 13 08 02 25 02 25 7B 96 )
[2022-05-31 23:00:02.358] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:02.360] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:02.360] [D] [zway] SENT ACK
[2022-05-31 23:00:02.360] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:02.421] [D] [zway] RECEIVED: ( 01 1D 00 13 7B 00 00 05 02 B2 CD B3 7F 7F 00 00 03 03 05 00 00 03 01 00 00 7F 7F 7F 7F 7F 39 )
[2022-05-31 23:00:02.421] [D] [zway] SENT ACK
[2022-05-31 23:00:02.421] [I] [zway] Job 0x13 (SwitchBinary Get to node 8): Delivered
[2022-05-31 23:00:02.422] [D] [zway] SendData Response with callback 0x7b received: received by recipient
[2022-05-31 23:00:02.422] [D] [zway] SETDATA devices.8.data.lastSendInternal = **********
[2022-05-31 23:00:02.422] [D] [zway] SETDATA devices.8.data.lastSend = 2451893 (0x002569b5)
[2022-05-31 23:00:02.422] [D] [zway] Job 0x13 (SwitchBinary Get to node 8): success
[2022-05-31 23:00:02.422] [I] [zway] Waiting for job reply: SwitchBinary Get from node 8
[2022-05-31 23:00:02.422] [D] [zway] Node 9:0 CC SwitchBinary: Unsolicited report not received, sending Get
[2022-05-31 23:00:02.422] [I] [zway] Adding job: SwitchBinary Get to node 9
[2022-05-31 23:00:02.423] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:02.423] [D] [zway] Node 9:0 CC SwitchBinary: Unsolicited report not received, sending Get
[2022-05-31 23:00:02.433] [D] [zway] SENDING (cb 0x7c): ( 01 09 00 13 09 02 25 02 25 7C 90 )
[2022-05-31 23:00:02.435] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:02.436] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:02.436] [D] [zway] SENT ACK
[2022-05-31 23:00:02.436] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:02.492] [D] [zway] RECEIVED: ( 01 1D 00 13 7C 00 00 05 01 BA CA 7F 7F 7F 01 01 03 04 00 00 00 02 01 00 00 7F 7F 7F 7F 7F FD )
[2022-05-31 23:00:02.492] [D] [zway] SENT ACK
[2022-05-31 23:00:02.492] [I] [zway] Job 0x13 (SwitchBinary Get to node 9): Delivered
[2022-05-31 23:00:02.493] [D] [zway] SendData Response with callback 0x7c received: received by recipient
[2022-05-31 23:00:02.493] [D] [zway] SETDATA devices.9.data.lastSendInternal = **********
[2022-05-31 23:00:02.493] [D] [zway] SETDATA devices.9.data.lastSend = 2451899 (0x002569bb)
[2022-05-31 23:00:02.493] [D] [zway] Job 0x13 (SwitchBinary Get to node 9): success
[2022-05-31 23:00:02.493] [I] [zway] Waiting for job reply: SwitchBinary Get from node 9
[2022-05-31 23:00:02.509] [D] [zway] RECEIVED: ( 01 18 00 04 00 08 03 25 03 00 B1 00 0C 11 01 00 22 05 03 25 03 00 2F 84 A0 6A )
[2022-05-31 23:00:02.509] [D] [zway] SENT ACK
[2022-05-31 23:00:02.510] [D] [zway] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:02.510] [D] [zway] Received reply on job (SwitchBinary Get to node 8)
[2022-05-31 23:00:02.510] [D] [zway] SETDATA devices.8.instances.0.commandClasses.37.data.level = False
[2022-05-31 23:00:02.567] [D] [zway] RECEIVED: ( 01 17 00 04 00 09 03 25 03 00 BB 00 0B 10 01 00 11 04 25 03 00 92 2F 84 6B )
[2022-05-31 23:00:02.567] [D] [zway] SENT ACK
[2022-05-31 23:00:02.568] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:02.568] [D] [zway] Received reply on job (SwitchBinary Get to node 9)
[2022-05-31 23:00:02.568] [D] [zway] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2022-05-31 23:00:02.658] [I] [core] HK: updated ZWayVDev_zway_8-0-37
[2022-05-31 23:00:02.659] [I] [core] Notification: device-info (device-OnOff): {"dev":"Front Porch Light","l":"off","location":2}
[2022-05-31 23:00:02.664] [I] [core] --- ZWayVDev_zway_11-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.664] [I] [zway] Adding job: SwitchBinary Set to node 11
[2022-05-31 23:00:02.664] [I] [zway] Adding job: SwitchBinary Get to node 11
[2022-05-31 23:00:02.665] [I] [core] --- ZWayVDev_zway_19-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.665] [I] [zway] Adding job: SwitchBinary Set to node 19
[2022-05-31 23:00:02.665] [I] [zway] Adding job: SwitchBinary Get to node 19
[2022-05-31 23:00:02.665] [I] [core] --- ZWayVDev_zway_9-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.665] [I] [zway] Adding job: SwitchBinary Set to node 9
[2022-05-31 23:00:02.667] [I] [core] --- ZWayVDev_zway_11-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.667] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:02.668] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:02.668] [I] [core] --- ZWayVDev_zway_19-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.668] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:02.668] [I] [core] --- ZWayVDev_zway_9-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.669] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:02.670] [D] [zway] SENDING (cb 0x7d): ( 01 0B 00 13 0B 04 25 01 00 FF 25 7D 6B )
[2022-05-31 23:00:02.672] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:02.672] [I] [core] HK: updated ZWayVDev_zway_9-0-37
[2022-05-31 23:00:02.674] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:02.674] [D] [zway] SENT ACK
[2022-05-31 23:00:02.674] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:02.676] [I] [core] Notification: device-info (device-OnOff): {"dev":"Garage Lights","l":"off","location":2}
[2022-05-31 23:00:02.694] [D] [zway] RECEIVED: ( 01 1D 00 13 7D 00 00 01 00 A8 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 5A )
[2022-05-31 23:00:02.694] [D] [zway] SENT ACK
[2022-05-31 23:00:02.694] [I] [zway] Job 0x13 (SwitchBinary Set to node 11): Delivered
[2022-05-31 23:00:02.695] [D] [zway] SendData Response with callback 0x7d received: received by recipient
[2022-05-31 23:00:02.695] [D] [zway] SETDATA devices.11.data.lastSendInternal = **********
[2022-05-31 23:00:02.695] [D] [zway] SETDATA devices.11.data.lastSend = 2451916 (0x002569cc)
[2022-05-31 23:00:02.695] [D] [zway] Job 0x13 (SwitchBinary Set to node 11): success
[2022-05-31 23:00:02.695] [I] [zway] Removing job: SwitchBinary Set to node 11
[2022-05-31 23:00:02.695] [D] [zway] SENDING (cb 0x7e): ( 01 0B 00 13 13 04 25 01 00 FF 25 7E 70 )
[2022-05-31 23:00:02.697] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:02.698] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:02.698] [D] [zway] SENT ACK
[2022-05-31 23:00:02.698] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:02.700] [I] [core] --- ZWayVDev_zway_11-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.700] [I] [zway] Adding job: SwitchBinary Set to node 11
[2022-05-31 23:00:02.700] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:02.700] [I] [core] --- ZWayVDev_zway_19-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.700] [I] [zway] Adding job: SwitchBinary Set to node 19
[2022-05-31 23:00:02.701] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:02.701] [I] [core] --- ZWayVDev_zway_9-0-37 performCommand processing: {"0":"off"}
[2022-05-31 23:00:02.701] [D] [zway] Job 0x13 (SwitchBinary Set): removing duplicate
[2022-05-31 23:00:02.728] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0B 02 82 01 A8 00 00 D2 )
[2022-05-31 23:00:02.728] [D] [zway] SENT ACK
[2022-05-31 23:00:02.728] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:02.728] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:02.728] [W] [zway] Got unsecure packet from device 11, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:02.729] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:02.861] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:02.889] [D] [zway] RECEIVED: ( 01 1D 00 13 7E 00 00 12 01 B2 BE 7F 7F 7F 01 01 03 11 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 81 )
[2022-05-31 23:00:02.889] [D] [zway] SENT ACK
[2022-05-31 23:00:02.889] [I] [zway] Job 0x13 (SwitchBinary Set to node 19): Delivered
[2022-05-31 23:00:02.889] [D] [zway] SendData Response with callback 0x7e received: received by recipient
[2022-05-31 23:00:02.889] [D] [zway] SETDATA devices.19.data.lastSendInternal = **********
[2022-05-31 23:00:02.889] [D] [zway] SETDATA devices.19.data.lastSend = 2451933 (0x002569dd)
[2022-05-31 23:00:02.889] [D] [zway] Job 0x13 (SwitchBinary Set to node 19): success
[2022-05-31 23:00:02.889] [I] [zway] Removing job: SwitchBinary Set to node 19
[2022-05-31 23:00:02.890] [D] [zway] SENDING (cb 0x7f): ( 01 0B 00 13 0B 04 25 01 00 FF 25 7F 69 )
[2022-05-31 23:00:02.891] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:02.893] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:02.893] [D] [zway] SENT ACK
[2022-05-31 23:00:02.893] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:02.913] [D] [zway] RECEIVED: ( 01 1D 00 13 7F 00 00 01 00 A8 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 58 )
[2022-05-31 23:00:02.913] [D] [zway] SENT ACK
[2022-05-31 23:00:02.913] [I] [zway] Job 0x13 (SwitchBinary Set to node 11): Delivered
[2022-05-31 23:00:02.914] [D] [zway] SendData Response with callback 0x7f received: received by recipient
[2022-05-31 23:00:02.914] [D] [zway] SETDATA devices.11.data.lastSendInternal = **********
[2022-05-31 23:00:02.914] [D] [zway] SETDATA devices.11.data.lastSend = 2451934 (0x002569de)
[2022-05-31 23:00:02.914] [D] [zway] Job 0x13 (SwitchBinary Set to node 11): success
[2022-05-31 23:00:02.914] [I] [zway] Removing job: SwitchBinary Set to node 11
[2022-05-31 23:00:02.914] [D] [zway] SENDING (cb 0x80): ( 01 0B 00 13 09 04 25 01 00 FF 25 80 94 )
[2022-05-31 23:00:02.916] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:02.917] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:02.917] [D] [zway] SENT ACK
[2022-05-31 23:00:02.917] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:02.952] [D] [zway] RECEIVED: ( 01 14 00 04 00 13 02 82 01 B2 00 09 0F 01 00 11 11 82 01 25 FF 91 )
[2022-05-31 23:00:02.952] [D] [zway] SENT ACK
[2022-05-31 23:00:02.952] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:02.952] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:02.952] [W] [zway] Got unsecure packet from device 19, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:02.952] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:02.979] [D] [zway] RECEIVED: ( 01 14 00 04 00 13 02 82 01 B1 00 09 0F 01 00 11 11 82 01 25 7F 12 )
[2022-05-31 23:00:02.979] [D] [zway] SENT ACK
[2022-05-31 23:00:02.979] [W] [zway] Discarding duplicate packet from node 19
[2022-05-31 23:00:03.047] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0B 02 82 01 A8 00 00 D2 )
[2022-05-31 23:00:03.047] [D] [zway] SENT ACK
[2022-05-31 23:00:03.047] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:03.047] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:03.047] [W] [zway] Got unsecure packet from device 11, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:03.047] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:03.387] [D] [zway] RECEIVED: ( 01 1D 00 13 80 00 00 2E 01 BA CC 7F 7F 7F 01 01 03 04 00 00 00 02 02 00 00 7F 7F 7F 7F 7F 2F )
[2022-05-31 23:00:03.387] [D] [zway] SENT ACK
[2022-05-31 23:00:03.387] [I] [zway] Job 0x13 (SwitchBinary Set to node 9): Delivered
[2022-05-31 23:00:03.388] [D] [zway] SendData Response with callback 0x80 received: received by recipient
[2022-05-31 23:00:03.388] [D] [zway] SETDATA devices.9.data.lastSendInternal = **********
[2022-05-31 23:00:03.388] [D] [zway] SETDATA devices.9.data.lastSend = 2451978 (0x00256a0a)
[2022-05-31 23:00:03.388] [D] [zway] Job 0x13 (SwitchBinary Set to node 9): success
[2022-05-31 23:00:03.388] [I] [zway] Removing job: SwitchBinary Set to node 9
[2022-05-31 23:00:03.388] [D] [zway] SENDING (cb 0x81): ( 01 09 00 13 0B 02 25 02 25 81 6F )
[2022-05-31 23:00:03.390] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:03.391] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:03.391] [D] [zway] SENT ACK
[2022-05-31 23:00:03.391] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:03.467] [D] [zway] RECEIVED: ( 01 17 00 04 00 09 02 82 01 B8 00 0C 0F 01 00 11 04 82 01 2F 7F 7F 0D FC 96 )
[2022-05-31 23:00:03.467] [D] [zway] SENT ACK
[2022-05-31 23:00:03.468] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:03.468] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:03.468] [W] [zway] Got unsecure packet from device 9, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:03.468] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:03.488] [D] [zway] RECEIVED: ( 01 1D 00 13 81 00 00 09 00 A8 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 7F 7F 7F 7F 7F AE )
[2022-05-31 23:00:03.488] [D] [zway] SENT ACK
[2022-05-31 23:00:03.488] [I] [zway] Job 0x13 (SwitchBinary Get to node 11): Delivered
[2022-05-31 23:00:03.489] [D] [zway] SendData Response with callback 0x81 received: received by recipient
[2022-05-31 23:00:03.489] [D] [zway] SETDATA devices.11.data.lastSendInternal = **********
[2022-05-31 23:00:03.489] [D] [zway] SETDATA devices.11.data.lastSend = 2451986 (0x00256a12)
[2022-05-31 23:00:03.489] [D] [zway] Job 0x13 (SwitchBinary Get to node 11): success
[2022-05-31 23:00:03.489] [I] [zway] Waiting for job reply: SwitchBinary Get from node 11
[2022-05-31 23:00:03.489] [D] [zway] SENDING (cb 0x82): ( 01 0B 00 13 13 04 25 01 00 FF 25 82 8C )
[2022-05-31 23:00:03.491] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:03.492] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:03.492] [D] [zway] SENT ACK
[2022-05-31 23:00:03.493] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:03.561] [D] [zway] RECEIVED: ( 01 0C 00 04 00 0B 03 25 03 00 A8 00 00 71 )
[2022-05-31 23:00:03.561] [D] [zway] SENT ACK
[2022-05-31 23:00:03.562] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:03.562] [D] [zway] Received reply on job (SwitchBinary Get to node 11)
[2022-05-31 23:00:03.562] [D] [zway] SETDATA devices.11.instances.0.commandClasses.37.data.level = False
[2022-05-31 23:00:03.568] [I] [core] HK: updated ZWayVDev_zway_11-0-37
[2022-05-31 23:00:04.484] [D] [zway] RECEIVED: ( 01 1D 00 13 82 00 00 61 01 B3 BE 7F 7F 7F 01 01 03 11 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 0F )
[2022-05-31 23:00:04.484] [D] [zway] SENT ACK
[2022-05-31 23:00:04.484] [I] [zway] Job 0x13 (SwitchBinary Set to node 19): Delivered
[2022-05-31 23:00:04.485] [D] [zway] SendData Response with callback 0x82 received: received by recipient
[2022-05-31 23:00:04.485] [D] [zway] SETDATA devices.19.data.lastSendInternal = **********
[2022-05-31 23:00:04.485] [D] [zway] SETDATA devices.19.data.lastSend = 2452081 (0x00256a71)
[2022-05-31 23:00:04.485] [D] [zway] Job 0x13 (SwitchBinary Set to node 19): success
[2022-05-31 23:00:04.485] [I] [zway] Removing job: SwitchBinary Set to node 19
[2022-05-31 23:00:04.527] [D] [zway] SENDING (cb 0x83): ( 01 09 00 13 13 02 25 02 25 83 75 )
[2022-05-31 23:00:04.529] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:04.530] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:04.530] [D] [zway] SENT ACK
[2022-05-31 23:00:04.530] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:04.550] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:04.622] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:04.671] [D] [zway] RECEIVED: ( 01 1D 00 13 83 00 00 0D 01 B3 BE 7F 7F 7F 01 01 03 11 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 62 )
[2022-05-31 23:00:04.671] [D] [zway] SENT ACK
[2022-05-31 23:00:04.671] [I] [zway] Job 0x13 (SwitchBinary Get to node 19): Delivered
[2022-05-31 23:00:04.672] [D] [zway] SendData Response with callback 0x83 received: received by recipient
[2022-05-31 23:00:04.672] [D] [zway] SETDATA devices.19.data.lastSendInternal = **********
[2022-05-31 23:00:04.672] [D] [zway] SETDATA devices.19.data.lastSend = 2452098 (0x00256a82)
[2022-05-31 23:00:04.672] [D] [zway] Job 0x13 (SwitchBinary Get to node 19): success
[2022-05-31 23:00:04.672] [I] [zway] Waiting for job reply: SwitchBinary Get from node 19
[2022-05-31 23:00:04.837] [D] [zway] RECEIVED: ( 01 15 00 04 00 13 02 82 01 B3 00 0A 0F 01 00 11 11 82 01 26 7F 7F 6E )
[2022-05-31 23:00:04.837] [D] [zway] SENT ACK
[2022-05-31 23:00:04.837] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:04.838] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:04.838] [W] [zway] Got unsecure packet from device 19, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:04.838] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:00:05.260] [D] [zway] Node 9:0 CC SwitchBinary: Unsolicited report not received, sending Get
[2022-05-31 23:00:05.261] [I] [zway] Adding job: SwitchBinary Get to node 9
[2022-05-31 23:00:05.261] [D] [zway] Node 9:0 CC SwitchBinary: Unsolicited report not received, sending Get
[2022-05-31 23:00:05.261] [D] [zway] Job 0x13 (SwitchBinary Get): removing duplicate
[2022-05-31 23:00:05.272] [D] [zway] SENDING (cb 0x84): ( 01 09 00 13 09 02 25 02 25 84 68 )
[2022-05-31 23:00:05.273] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:05.275] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-05-31 23:00:05.275] [D] [zway] SENT ACK
[2022-05-31 23:00:05.275] [D] [zway] Delivered to Z-Wave stack
[2022-05-31 23:00:05.325] [D] [zway] RECEIVED: ( 01 1D 00 13 84 00 00 04 01 B7 CC 7F 7F 7F 01 01 03 04 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 0F )
[2022-05-31 23:00:05.326] [D] [zway] SENT ACK
[2022-05-31 23:00:05.326] [I] [zway] Job 0x13 (SwitchBinary Get to node 9): Delivered
[2022-05-31 23:00:05.326] [D] [zway] SendData Response with callback 0x84 received: received by recipient
[2022-05-31 23:00:05.326] [D] [zway] SETDATA devices.9.data.lastSendInternal = **********
[2022-05-31 23:00:05.326] [D] [zway] SETDATA devices.9.data.lastSend = 2452160 (0x00256ac0)
[2022-05-31 23:00:05.326] [D] [zway] Job 0x13 (SwitchBinary Get to node 9): success
[2022-05-31 23:00:05.326] [I] [zway] Waiting for job reply: SwitchBinary Get from node 9
[2022-05-31 23:00:05.397] [D] [zway] RECEIVED: ( 01 19 00 04 00 09 03 25 03 00 B8 00 0D 10 01 00 11 04 25 03 00 94 7F FC A8 41 A7 )
[2022-05-31 23:00:05.398] [D] [zway] SENT ACK
[2022-05-31 23:00:05.398] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:05.398] [D] [zway] Received reply on job (SwitchBinary Get to node 9)
[2022-05-31 23:00:05.398] [D] [zway] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2022-05-31 23:00:05.401] [I] [core] HK: updated ZWayVDev_zway_9-0-37
[2022-05-31 23:00:05.624] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:06.118] [I] [core] NotificationChannelEmail Sending a message to skohlman1@att.net
[2022-05-31 23:00:06.802] [W] [zway] Reply not received before timeout for job (SwitchBinary Get to node 19)
[2022-05-31 23:00:07.454] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:08.023] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:00:11.137] [I] [core] NotificationChannelEmail Sending a message to skohlman1@att.net
[2022-05-31 23:00:12.043] [I] [core] NotificationChannelEmail error: {"status":405,"statusText":"Can not send mails that fast","url":"https://service.z-wave.me/emailnotifica ... ested-With , content-type","Access-Control-Allow-Methods":"POST, GET, PUT, DELETE, OPTIONS","Access-Control-Allow-Origin":"*","Connection":"close","Content-Length":"0","Content-Type":"text/html; charset=UTF-8","Date":"Wed, 01 Jun 2022 03:00:11 GMT","Server":"Apache/2.4.18 (Ubuntu)"},"contentType":"text/html","data":""}
[2022-05-31 23:00:12.044] [I] [core] Notification: error (module): NotificationChannelEmail error
[2022-05-31 23:00:16.163] [I] [core] NotificationChannelEmail Sending a message to skohlman1@att.net
[2022-05-31 23:00:17.696] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:00:17.702] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:00:17.703] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:17.704] [D] [zway] RECEIVED: ( 01 07 01 3B AB A8 A8 7F 16 )
[2022-05-31 23:00:17.704] [D] [zway] SENT ACK
[2022-05-31 23:00:17.704] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 171 (0x000000ab)
[2022-05-31 23:00:17.704] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 168 (0x000000a8)
[2022-05-31 23:00:17.704] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 168 (0x000000a8)
[2022-05-31 23:00:17.705] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -85 dBm, Ch#2: -88 dBm, Ch#3: -88 dBm
[2022-05-31 23:00:17.705] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:00:17.705] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:00:20.818] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:20.879] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:20.910] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:20.930] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:21.184] [I] [core] NotificationChannelEmail Sending a message to xxxxxxx
[2022-05-31 23:00:23.016] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:23.210] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:23.231] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:23.701] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:24.794] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:27.109] [D] [zway] Job 0x13: deleted from queue
[2022-05-31 23:00:38.009] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:00:47.701] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:00:47.708] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:00:47.710] [D] [zway] RECEIVED ACK
[2022-05-31 23:00:47.710] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A5 A5 7F 15 )
[2022-05-31 23:00:47.710] [D] [zway] SENT ACK
[2022-05-31 23:00:47.710] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 168 (0x000000a8)
[2022-05-31 23:00:47.711] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 165 (0x000000a5)
[2022-05-31 23:00:47.711] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 165 (0x000000a5)
[2022-05-31 23:00:47.711] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -91 dBm, Ch#3: -91 dBm
[2022-05-31 23:00:47.711] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:00:47.711] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:00:53.605] [D] [zway] RECEIVED: ( 01 17 00 04 00 05 02 82 01 B0 00 0C 0F 01 00 11 03 82 01 25 E7 7F 60 A0 36 )
[2022-05-31 23:00:53.605] [D] [zway] SENT ACK
[2022-05-31 23:00:53.606] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:00:53.606] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:00:53.606] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:00:53.606] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:01:00.774] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:01:07.759] [I] [zway] Saving configuration data to config/zddx/da1c9a90-DevicesData.xml
[2022-05-31 23:01:08.011] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:01:08.240] [I] [zway] Adding job: Get statistics gathered by the Z-Wave protocol
[2022-05-31 23:01:08.245] [D] [zway] SENDING: ( 01 03 00 3A C6 )
[2022-05-31 23:01:08.246] [D] [zway] RECEIVED ACK
[2022-05-31 23:01:08.248] [D] [zway] RECEIVED: ( 01 0F 01 3A 00 2E 00 00 00 67 00 00 17 A2 00 03 34 )
[2022-05-31 23:01:08.248] [D] [zway] SENT ACK
[2022-05-31 23:01:08.248] [D] [zway] SETDATA controller.data.statistics.RFTxFrames = 46 (0x0000002e)
[2022-05-31 23:01:08.248] [D] [zway] SETDATA controller.data.statistics.RFTxLBTBackOffs = 0 (0x00000000)
[2022-05-31 23:01:08.248] [D] [zway] SETDATA controller.data.statistics.RFRxFrames = 103 (0x00000067)
[2022-05-31 23:01:08.248] [D] [zway] SETDATA controller.data.statistics.RFRxLRCErrors = 0 (0x00000000)
[2022-05-31 23:01:08.248] [D] [zway] SETDATA controller.data.statistics.RFRxCRC16Errors = 6050 (0x000017a2)
[2022-05-31 23:01:08.248] [D] [zway] SETDATA controller.data.statistics.RFRxForeignHomeID = 3 (0x00000003)
[2022-05-31 23:01:08.248] [I] [zway] Job 0x3a (Get statistics gathered by the Z-Wave protocol): Done
[2022-05-31 23:01:08.248] [D] [zway] Job 0x3a (Get statistics gathered by the Z-Wave protocol): success
[2022-05-31 23:01:08.248] [I] [zway] Removing job: Get statistics gathered by the Z-Wave protocol
[2022-05-31 23:01:17.709] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:01:17.710] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:01:17.711] [D] [zway] RECEIVED ACK
[2022-05-31 23:01:17.712] [D] [zway] RECEIVED: ( 01 07 01 3B AA A6 A6 7F 17 )
[2022-05-31 23:01:17.712] [D] [zway] SENT ACK
[2022-05-31 23:01:17.712] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 170 (0x000000aa)
[2022-05-31 23:01:17.713] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 166 (0x000000a6)
[2022-05-31 23:01:17.713] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 166 (0x000000a6)
[2022-05-31 23:01:17.713] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -86 dBm, Ch#2: -90 dBm, Ch#3: -90 dBm
[2022-05-31 23:01:17.713] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:01:17.713] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:01:28.553] [D] [zway] Job 0x3a: deleted from queue
[2022-05-31 23:01:38.020] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:01:47.726] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:01:47.730] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:01:47.732] [D] [zway] RECEIVED ACK
[2022-05-31 23:01:47.732] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A6 A6 7F 15 )
[2022-05-31 23:01:47.732] [D] [zway] SENT ACK
[2022-05-31 23:01:47.733] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 168 (0x000000a8)
[2022-05-31 23:01:47.733] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 166 (0x000000a6)
[2022-05-31 23:01:47.733] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 166 (0x000000a6)
[2022-05-31 23:01:47.733] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -90 dBm, Ch#3: -90 dBm
[2022-05-31 23:01:47.733] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:01:47.733] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:02:00.113] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:02:08.009] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:02:17.736] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:02:17.736] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:02:17.738] [D] [zway] RECEIVED ACK
[2022-05-31 23:02:17.739] [D] [zway] RECEIVED: ( 01 07 01 3B A7 A5 A5 7F 1A )
[2022-05-31 23:02:17.739] [D] [zway] SENT ACK
[2022-05-31 23:02:17.739] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 167 (0x000000a7)
[2022-05-31 23:02:17.739] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 165 (0x000000a5)
[2022-05-31 23:02:17.739] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 165 (0x000000a5)
[2022-05-31 23:02:17.739] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -89 dBm, Ch#2: -91 dBm, Ch#3: -91 dBm
[2022-05-31 23:02:17.739] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:02:17.739] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:02:38.021] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:02:47.755] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:02:47.764] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:02:47.766] [D] [zway] RECEIVED ACK
[2022-05-31 23:02:47.766] [D] [zway] RECEIVED: ( 01 07 01 3B A7 A4 A4 7F 1A )
[2022-05-31 23:02:47.766] [D] [zway] SENT ACK
[2022-05-31 23:02:47.766] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 167 (0x000000a7)
[2022-05-31 23:02:47.766] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 164 (0x000000a4)
[2022-05-31 23:02:47.766] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 164 (0x000000a4)
[2022-05-31 23:02:47.766] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -89 dBm, Ch#2: -92 dBm, Ch#3: -92 dBm
[2022-05-31 23:02:47.767] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:02:47.767] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:02:53.287] [D] [zway] RECEIVED: ( 01 18 00 04 00 05 02 82 01 B1 00 0D 0F 01 00 11 03 82 01 62 34 7F EE F1 44 36 )
[2022-05-31 23:02:53.288] [D] [zway] SENT ACK
[2022-05-31 23:02:53.288] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:02:53.288] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:02:53.288] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:02:53.288] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:03:00.447] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:03:00.725] [D] [zway] RECEIVED: ( 01 19 00 04 00 05 02 82 01 B2 00 0E 0F 01 00 11 03 82 01 AA 41 7F EE F1 44 00 8A )
[2022-05-31 23:03:00.725] [D] [zway] SENT ACK
[2022-05-31 23:03:00.726] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:03:00.726] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:03:00.726] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:03:00.726] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:03:08.055] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:03:17.775] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:03:17.777] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:03:17.779] [D] [zway] RECEIVED ACK
[2022-05-31 23:03:17.780] [D] [zway] RECEIVED: ( 01 07 01 3B A9 A6 A6 7F 14 )
[2022-05-31 23:03:17.780] [D] [zway] SENT ACK
[2022-05-31 23:03:17.780] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 169 (0x000000a9)
[2022-05-31 23:03:17.780] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 166 (0x000000a6)
[2022-05-31 23:03:17.780] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 166 (0x000000a6)
[2022-05-31 23:03:17.780] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -87 dBm, Ch#2: -90 dBm, Ch#3: -90 dBm
[2022-05-31 23:03:17.781] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:03:17.781] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:03:38.064] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:03:47.775] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:03:47.776] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:03:47.777] [D] [zway] RECEIVED ACK
[2022-05-31 23:03:47.778] [D] [zway] RECEIVED: ( 01 07 01 3B A6 A5 A5 7F 1B )
[2022-05-31 23:03:47.778] [D] [zway] SENT ACK
[2022-05-31 23:03:47.778] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 166 (0x000000a6)
[2022-05-31 23:03:47.778] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 165 (0x000000a5)
[2022-05-31 23:03:47.778] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 165 (0x000000a5)
[2022-05-31 23:03:47.778] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -90 dBm, Ch#2: -91 dBm, Ch#3: -91 dBm
[2022-05-31 23:03:47.778] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:03:47.779] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:04:00.770] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:04:08.083] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:04:17.795] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:04:17.795] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:04:17.797] [D] [zway] RECEIVED ACK
[2022-05-31 23:04:17.797] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A6 A6 7F 15 )
[2022-05-31 23:04:17.797] [D] [zway] SENT ACK
[2022-05-31 23:04:17.797] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 168 (0x000000a8)
[2022-05-31 23:04:17.797] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 166 (0x000000a6)
[2022-05-31 23:04:17.797] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 166 (0x000000a6)
[2022-05-31 23:04:17.798] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -90 dBm, Ch#3: -90 dBm
[2022-05-31 23:04:17.798] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:04:17.798] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:04:38.088] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:04:47.804] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:04:47.806] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:04:47.808] [D] [zway] RECEIVED ACK
[2022-05-31 23:04:47.808] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A4 A4 7F 15 )
[2022-05-31 23:04:47.808] [D] [zway] SENT ACK
[2022-05-31 23:04:47.809] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 168 (0x000000a8)
[2022-05-31 23:04:47.809] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 164 (0x000000a4)
[2022-05-31 23:04:47.809] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 164 (0x000000a4)
[2022-05-31 23:04:47.809] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -92 dBm, Ch#3: -92 dBm
[2022-05-31 23:04:47.809] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:04:47.809] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:05:00.079] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:05:08.110] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:05:17.811] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:05:17.821] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:05:17.823] [D] [zway] RECEIVED ACK
[2022-05-31 23:05:17.823] [D] [zway] RECEIVED: ( 01 07 01 3B A7 A5 A5 7F 1A )
[2022-05-31 23:05:17.823] [D] [zway] SENT ACK
[2022-05-31 23:05:17.823] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 167 (0x000000a7)
[2022-05-31 23:05:17.823] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 165 (0x000000a5)
[2022-05-31 23:05:17.823] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 165 (0x000000a5)
[2022-05-31 23:05:17.823] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -89 dBm, Ch#2: -91 dBm, Ch#3: -91 dBm
[2022-05-31 23:05:17.824] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:05:17.824] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:05:38.131] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:05:47.838] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:05:47.842] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:05:47.843] [D] [zway] RECEIVED ACK
[2022-05-31 23:05:47.844] [D] [zway] RECEIVED: ( 01 07 01 3B AB A7 A7 7F 16 )
[2022-05-31 23:05:47.844] [D] [zway] SENT ACK
[2022-05-31 23:05:47.844] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 171 (0x000000ab)
[2022-05-31 23:05:47.844] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 167 (0x000000a7)
[2022-05-31 23:05:47.844] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 167 (0x000000a7)
[2022-05-31 23:05:47.844] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -85 dBm, Ch#2: -89 dBm, Ch#3: -89 dBm
[2022-05-31 23:05:47.844] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:05:47.844] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:06:00.410] [I] [core] --- Daylight_30 performCommand processing: {"0":"update"}
[2022-05-31 23:06:08.119] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:06:15.460] [D] [zway] RECEIVED: ( 01 1A 00 04 00 05 02 82 01 B5 00 0F 0F 01 00 11 03 82 01 ED 92 7F EE F1 44 00 13 08 )
[2022-05-31 23:06:15.460] [D] [zway] SENT ACK
[2022-05-31 23:06:15.460] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:06:15.460] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:06:15.460] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:06:15.461] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:06:17.842] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:06:17.843] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:06:17.844] [D] [zway] RECEIVED ACK
[2022-05-31 23:06:17.845] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A5 A5 7F 15 )
[2022-05-31 23:06:17.845] [D] [zway] SENT ACK
[2022-05-31 23:06:17.846] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 168 (0x000000a8)
[2022-05-31 23:06:17.846] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 165 (0x000000a5)
[2022-05-31 23:06:17.846] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 165 (0x000000a5)
[2022-05-31 23:06:17.846] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -91 dBm, Ch#3: -91 dBm
[2022-05-31 23:06:17.846] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:06:17.846] [I] [zway] Removing job: Get background noise level
[2022-05-31 23:06:25.079] [D] [zway] RECEIVED: ( 01 0C 00 04 00 05 02 82 01 B6 00 01 0F CB )
[2022-05-31 23:06:25.079] [D] [zway] SENT ACK
[2022-05-31 23:06:25.080] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:06:25.080] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:06:25.080] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:06:25.080] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:06:28.828] [D] [zway] RECEIVED: ( 01 0D 00 04 00 05 02 82 01 B7 00 02 0F 01 C9 )
[2022-05-31 23:06:28.828] [D] [zway] SENT ACK
[2022-05-31 23:06:28.828] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:06:28.828] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:06:28.828] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:06:28.828] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:06:32.868] [D] [zway] RECEIVED: ( 01 0E 00 04 00 05 02 82 01 B6 00 03 0F 01 00 CA )
[2022-05-31 23:06:32.869] [D] [zway] SENT ACK
[2022-05-31 23:06:32.869] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2022-05-31 23:06:32.869] [W] [zway] Unhandled command in policy - contact Z-Wave.Me support: 82 01
[2022-05-31 23:06:32.869] [W] [zway] Got unsecure packet from device 5, but Command Class 0x82 Hail is marked as secure and not present in unsecure NIF. Ignoring packet.
[2022-05-31 23:06:32.869] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
[2022-05-31 23:06:38.130] [D] [zway] Job 0x3b: deleted from queue
[2022-05-31 23:06:47.865] [I] [zway] Adding job: Get background noise level
[2022-05-31 23:06:47.874] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-05-31 23:06:47.876] [D] [zway] RECEIVED ACK
[2022-05-31 23:06:47.876] [D] [zway] RECEIVED: ( 01 07 01 3B A8 A6 A6 7F 15 )
[2022-05-31 23:06:47.876] [D] [zway] SENT ACK
[2022-05-31 23:06:47.876] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 168 (0x000000a8)
[2022-05-31 23:06:47.876] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 166 (0x000000a6)
[2022-05-31 23:06:47.877] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 166 (0x000000a6)
[2022-05-31 23:06:47.877] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -88 dBm, Ch#2: -90 dBm, Ch#3: -90 dBm
[2022-05-31 23:06:47.877] [D] [zway] Job 0x3b (Get background noise level): success
[2022-05-31 23:06:47.877] [I] [zway] Removing job: Get background noise level
pi@raspberrypi:/var/log $ [2022-05-31 23:06:32.869] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Function class not supported by the hardware (-4)
Ok not sure what I should be looking at here but a log of my kitchen lights being turn on and off manually and at 23:00 outside light turned off 4 lights via timer.
Steve
lanbrown
Post
by lanbrown » 01 Jun 2022 07:42
Z-Way developers know of that issue and will have a fix in a future release.
shurpsur
Posts: 2 Joined: 25 Oct 2022 14:36
Post
by shurpsur » 25 Oct 2022 14:55
I have the Z-Wave integration set up, but when I attempt to include a device, nothing happens. The one device that seems to have communicated with the RazBerry seems to have failed to provide any info in the interview.
shurpsur
Post
by shurpsur » 26 Oct 2022 15:52
Did a factory reset for a outlet got in programmed to see this outlet can turn on or off via on-screen but the same issue if I turn on or off outlet via button on outlet (outside of on-screen) doesn't see my state either on or off of that device.
get-vidmate.com instasave
micky1500
Posts: 305 Joined: 07 Feb 2016 16:29
Post
by micky1500 » 26 Oct 2022 19:54
Sorry shurpsur.
What you say doesn't make sense.
You need to include a device name and log files of the issue.
What version of z-way you are using ?
