Razberry 7 Pro Issues
harre
Re: Razberry 7 Pro Issues
Post by harre »
PoltoS wrote:
07 Apr 2022 13:22
Please show the log with exclusion and inclusion
I did an exclude of the device with id 31 and then an include and it got added as 33.
See attached log:
https://www.dropbox.com/s/uz6qpmx412hh4 ... e.log?dl=0
z-wavettaja
Post by z-wavettaja »
z-wavettaja wrote:
07 Apr 2022 18:39
I updated fw from 3.2.2 to 3.2.3 and now I'm in more trouble than before.
In 3.2.2 scenes were unusable, because only one device coud be operated at time.
But now after update almost nothing works anymore.
It seems that my system is now totally unusable condition. Could someone link here a hint (sorry if this is many times asked, but I just could not find at the moment, how that should be done), if and how it's possible to downgrade back to 3.2.2 if that would resolve issue for now as even not lights are not working at the moment so it's quite difficult situation.
Thank you in advance
Raspi 4(Buster), Zwave Version 4.0.2 (7.28), Raz 7 Pro
lanbrown
Post by lanbrown »
the releases can be found here:
https://storage.z-wave.me/z-way-server/
Find the one you want and you then have the URL to it. You can download it, use wget or curl or whatever method you decide to use.
@z-wavettaja powercycle your Raspberry. I think it will work
@harre you have logging almost disabled. Please put 0 in log-level in config.xml
harre
Post by harre »
PoltoS, I found this thread about my device
https://forum.z-wave.me/viewtopic.php?p=64808#p64808
If there some workarounds missing for my device in the newer versions on z-way?
I get exactly same issue with another fibaro z-wave plug. But when including without security I get the interview stuck on version class.
harre
Post by harre »
PoltoS wrote:
09 Apr 2022 13:14
Hello, I was on the 4.0.0 beta but downloaded the latest 3.2.3 as it was newer as you said in another thread.
Now it seems to include with security correctly. I'm on the EU-version and perhaps it was wrong of using the 4.0 with long range as the EU doesn't support it.
See attached log:
https://www.dropbox.com/s/3cu6ckxy9fx5w ... 3.log?dl=0
So, should I check your log if inclusion is now ok?
harre
Post by harre »
I missed telling what to look for 😅
I did and exclusion of node 43 and it got included as 44. The 43 is still listed in the device list however.
Again, you have your logging disabled. Please change log-level to 0 in config.xml
