Debugger for Z-Way JavaScript
lifeisfunny
Re: Debugger for Z-Way JavaScript
Since z-way and node both using the v8 javascript engine , Will there be two javascript v8 running when you using node debugger ? If not , How so ? Does that means i can run nw.js for my interface on the same machines without worry about 2 javascript engine running ???
Yes, there will be 2 v8 running in different processes (one in node process, another in z-way). You can even run several instances of v8 in the same process (they still will be completely isolated from each other, while sharing codebase and libraries).lifeisfunny wrote:Since z-way and node both using the v8 javascript engine , Will there be two javascript v8 running when you using node debugger ? If not , How so ? Does that means i can run nw.js for my interface on the same machines without worry about 2 javascript engine running ???
Why would you think you cannot run multiple v8 instances simultaneously?
