New release candidate of available now!
Tiptop
Re: New release candidate of available now!
Post by Tiptop »
@PoltoS:
Version 1.7.1 rc2 really fixed all my stability issues including the memory leak - great job, thanks!! :)
However, I have a problem with all of my motion detectors with this version of the server.
I am using the following type of detectors:
• Everspring SP103
• Everspring SP814
• EZMotion
Whatever I tried - I do not get any motion detection response, anymore!
I even removed and re-included the sensors into my network... no success!
Even the "Expert (Blue) GUI" does not show any activity of those sensors...
Do you have an idea what might be the reason?
The Fibaro FGK10x door/window sensor still work without problems.
Many thanks in advance for any hints/ideas.
Greets!
pofs
Post by pofs »
@Tiptop,
there were no changes in low-level z-wave stuff since 1.7.0, so it should work. Do you have any events from your devices in the log? Maybe the associations are lost?
Tiptop
Post by Tiptop »
@pofs:
Yes, you are right. Even though the "Expert GUI" showed the RaZberry server as being the associated target, it in fact seemed not have been the case. After re-applying the settings, at least my Everspring SP814 works, again.
I will have to see if my other motion detectors will be back to live doing so, tonight.
Thanks for your quick reply!
Testing 1.7.1-rc2, with yesterday's HA branh develop.
I had 12 warnings about Openweather in my system. I had to push the hide all four times before all were gone. Is this expected behaviour?
@pz1: No, it is a bug. We are investigating it.
Ah, now I see. I misread issue #115, which seemed to have been closed. Actually one response on that issue references to #108 that has the status closed.
alboon
Post by alboon »
Hi, first thank you for your work.
I use RaZberry and test the new 1.7.0-rc2.
My z-way network is simple , 2 fibaro FGR211 Roller Shutter, and 1 fibaro fgs221 binary power switch.
The fgs221 is automaticaly in DASHBOARD, but FGR211 not, I've got this error message :
14/06/14 - 9:10Can not instanciate module 3: TypeError: Cannot read property 'meta' of undefined
can I fix it manualy ? wait for update is the good solution ?
Last question : I use DOMOTICZ for time automatisation, Are you working on time planning ?
Regards
Albin
SolarFlor
Post by SolarFlor »
pz1 wrote:Testing 1.7.1-rc2, with yesterday's HA branh develop.
in your signature you are referring to the version 1.7.2-rc2.
Is it a typo?
SolarFlor wrote:Is it a typo?
Yes :oops: , thanks, corrected
@alboon: check out latest from git. It should work now
