Here is the copy of the log.
Home Automation - Roller Shutter
Re: Home Automation - Roller Shutter
Hello it's not working
- export.zip
- (12.67 KiB) Downloaded 597 times
Updated the previous post. Fuckin' url parser just ate ?: operator.
Bingo, it's works thx @pofs
But for the common users this commands are not easy ...
Yeah, a bit tricky.
But it is said before, the multilevel switch also appears when calibrating a device. If so, it makes things easier:
then re-interview this particular command class (not the entire device!), and save config:
Note: unlike the previous method, it won't survive force re-interview for device.
http://ip:8083/JS/Run/zway.devices[x].SwitchMultilevel.data.supported=true
http://ip:8083/JS/Run/zway.devices.SaveData()
Ok thx i test this second method later.
With the second method if i force a re-interview of the module the multilevel switch will disappear ?
In Zway can you imagine to do so :
if module FGRM-222 added then apply exception (add command multilevel class ) ?
If it is possible of course.
Thx
Thx
It it a perfect task for a JS module, no need to integrate these dirty hacks into z-way itself.jayce wrote: if module FGRM-222 added then apply exception (add command multilevel class ) ?
Ok with the second method it works also.
But after forece re-interview the command class disappear.
What is the better way first or second solution ?
Hi all,
It would be very useful, for all 'mortal' users, if someone could summarise or prepare a guide on how to install/set Fibaro Roller Shutters.
thanks
thanks
Hi all,
Why this settings are not (yet) included in z-way engine ?
What's the reason ?
What's the reason ?
Hello
this code doesn't work in version 2.0.0
var nif=zway.devices[4].data.nodeInfoFrame.value;
var toAdd=0x26;
var pos=nif.indexOf(0xEF);
if (pos >= 0)
nif = nif.slice(0,pos).concat(toAdd).concat(nif.slice(pos));
else
nif = nif.concat(toAdd);
zway.devices[4].data.nodeInfoFrame.value=nif;
var toAdd=0x26;
if (pos >= 0)
else
