Trane / Schlage T-Stat Issue
mikelsr
Re: Trane / Schlage T-Stat Issue
Post by mikelsr »
If I did this correctly, I got the value 1. Here is what I did:
wget http://ipaddr:8083/ZWaveAPI/Run/devices ... sion.value
mikelsr
Post by mikelsr »
If I do this from a browser:
http://<ipaddr>:8083/ZWaveAPI/Run/devices[3].ThermostatSetPoint.data.version.value
I get 2 displayed in the window.
mikelsr
Post by mikelsr »
Besides getting a 2, I am watching the log file and seeing a Node 3.0 CC SensorMultilevel: Different sensor type 5 received, ignoring. This happens for both thermostats (nodes 3 and 4).
mikelsr
Post by mikelsr »
Bump
eblock
Post by eblock »
Was there ever a solution or workaround found for this? I'm hitting the same issue.
Sure you are using latest Z-Way?
eblock
Post by eblock »
Yeah I'm on v2.1.1.
jalalsinisaz
Post by jalalsinisaz »
I have the same issue with both GoControl thermostat and alarm.com thermostat. Is this resolved?
I am using the latest zway
jalalsinisaz
This is the log when I force interview cc
[2020-02-05 14:51:33.593] [zway] Adding job: ThermostatSetPoint Supported Get
[2020-02-05 14:51:33.599] [D] [zway] SENDING (cb 0x45): ( 01 09 00 13 0E 02 43 04 25 45 CE )
[2020-02-05 14:51:33.600] [D] [zway] RECEIVED ACK
[2020-02-05 14:51:33.605] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-02-05 14:51:33.605] [D] [zway] SENT ACK
[2020-02-05 14:51:33.605] [D] [zway] Delivered to Z-Wave stack
[2020-02-05 14:51:33.619] [D] [zway] RECEIVED: ( 01 07 00 13 45 00 00 01 AF )
[2020-02-05 14:51:33.620] [D] [zway] SENT ACK
[2020-02-05 14:51:33.620] [zway] Job 0x13 (ThermostatSetPoint Supported Get): Delivered
[2020-02-05 14:51:33.620] [D] [zway] SendData Response with callback 0x45 received: received by recipient
[2020-02-05 14:51:33.620] [D] [zway] SETDATA devices.14.data.lastSendInternal = **********
[2020-02-05 14:51:33.620] [D] [zway] SETDATA devices.14.data.lastSend = 7582668 (0x0073b3cc)
[2020-02-05 14:51:33.620] [D] [zway] Job 0x13 (ThermostatSetPoint Supported Get): success
[2020-02-05 14:51:33.620] [zway] Waiting for job reply: ThermostatSetPoint Supported Get
[2020-02-05 14:51:33.639] [D] [zway] RECEIVED: ( 01 0A 00 04 00 0E 04 43 05 06 18 A3 )
[2020-02-05 14:51:33.639] [D] [zway] SENT ACK
[2020-02-05 14:51:33.639] [D] [zway] SETDATA devices.14.data.lastReceived = 0 (0x00000000)
[2020-02-05 14:51:33.639] [D] [zway] Received reply on job (ThermostatSetPoint Supported Get)
[2020-02-05 14:51:33.639] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.modemask = 6150 (0x00001806)
[2020-02-05 14:51:33.640] [zway] Node 14:0 CC ThermostatSetPoint: Supported Thermostat SetPoint modemask 0x1806
[2020-02-05 14:51:33.640] [zway] Adding job: ThermostatSetPoint Get
[2020-02-05 14:51:33.659] [zway] Adding job: MultiCmd, ThermostatSetPoint Get, ThermostatSetPoint Get, ThermostatSetPoint Get
[2020-02-05 14:51:33.660] [D] [zway] SENDING (cb 0x46): ( 01 16 00 13 0E 0F 8F 01 03 03 43 02 01 03 43 02 02 03 43 02 0F 25 46 5B )
[2020-02-05 14:51:33.662] [D] [zway] RECEIVED ACK
[2020-02-05 14:51:33.667] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-02-05 14:51:33.667] [D] [zway] SENT ACK
[2020-02-05 14:51:33.667] [zway] Job 0x13 (MultiCmd, ThermostatSetPoint Get, ThermostatSetPoint Get, ThermostatSetPoint Get): Response received - transfered to encapsulated jobs
[2020-02-05 14:51:33.667] [D] [zway] Delivered to Z-Wave stack
[2020-02-05 14:51:33.691] [D] [zway] RECEIVED: ( 01 07 00 13 46 00 00 02 AF )
[2020-02-05 14:51:33.691] [D] [zway] SENT ACK
[2020-02-05 14:51:33.692] [zway] Job 0x13 (MultiCmd, ThermostatSetPoint Get, ThermostatSetPoint Get, ThermostatSetPoint Get): Callback received - transfered to encapsulated jobs
[2020-02-05 14:51:33.692] [zway] Job 0x13 (ThermostatSetPoint Get): Delivered
[2020-02-05 14:51:33.692] [D] [zway] SendData Response with callback 0x46 received: received by recipient
[2020-02-05 14:51:33.692] [D] [zway] Job 0x13 (ThermostatSetPoint Get): success
[2020-02-05 14:51:33.692] [zway] Waiting for job reply: ThermostatSetPoint Get
[2020-02-05 14:51:33.692] [zway] Job 0x13 (MultiCmd, ThermostatSetPoint Get, ThermostatSetPoint Get, ThermostatSetPoint Get): Delivered
[2020-02-05 14:51:33.693] [D] [zway] SETDATA devices.14.data.lastSendInternal = **********
[2020-02-05 14:51:33.693] [D] [zway] SETDATA devices.14.data.lastSend = 7582675 (0x0073b3d3)
[2020-02-05 14:51:33.693] [D] [zway] Job 0x13 (MultiCmd, ThermostatSetPoint Get, ThermostatSetPoint Get, ThermostatSetPoint Get): success
[2020-02-05 14:51:33.693] [zway] Removing job: MultiCmd, ThermostatSetPoint Get, ThermostatSetPoint Get, ThermostatSetPoint Get
[2020-02-05 14:51:33.701] [D] [zway] RECEIVED: ( 01 15 00 04 00 0E 0F 8F 01 02 05 43 03 01 09 48 05 43 03 02 09 50 78 )
[2020-02-05 14:51:33.702] [D] [zway] SENT ACK
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.data.lastReceived = 0 (0x00000000)
[2020-02-05 14:51:33.702] [D] [zway] Received reply on job (ThermostatSetPoint Get)
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1.size = **********
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1.precision = **********
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1.deviceScale = 1 (0x00000001)
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1.deviceScaleString = "°F"
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1.val = 22.200001
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1.setVal = 22.200001
[2020-02-05 14:51:33.702] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.1 = Empty
[2020-02-05 14:51:33.703] [D] [zway] Received reply on job (ThermostatSetPoint Get)
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2.size = **********
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2.precision = **********
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2.deviceScale = 1 (0x00000001)
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2.deviceScaleString = "°F"
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2.val = 26.700001
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2.setVal = 26.700001
[2020-02-05 14:51:33.703] [D] [zway] SETDATA devices.14.instances.0.commandClasses.67.data.2 = Empty
[2020-02-05 14:51:35.792] [D] [zway] Job 0x13: deleted from queue
[2020-02-05 14:51:35.822] [W] [zway] Reply not received before timeout for job (ThermostatSetPoint Get)
[2020-02-05 14:51:53.902] [D] [zway] Job 0x13: deleted from queue
[2020-02-05 14:51:53.912] [D] [zway] Job 0x13: deleted from queue
[2020-02-05 14:51:56.018] [D] [zway] Job 0x13: deleted from queue
