Z-WaveMe down...????
nutcracker
Post by nutcracker » 12 Jan 2013 12:24
Does this service work?
(I'm using a zwave me USB connector...I believe this is compatible with the zwave.me service...).
Similar symptoms to this user... (http://en.z-wave.me/content/agent-loop- ... aspberrypi)
Opening device...
Connecting to server...
Establishing SSL connection...
Performing SSL handshake...
Loop started
[E] Socket has gone
Loop ended
Opening device...
[I] Establishing SSL connection...
[I] Performing SSL handshake...
[I] Loop started
[E] Socket has gone
[I] Loop ended
[I] Opening device...
[I] Connecting to server...
[I] Loop started
[E] Socket has gone
[I] Loop ended
[I] Loop started
[E] Socket has gone
[I] Loop ended
nutcracker
Still not working...
Tried this now on both a Raspberry + OSX
(with debug)
[D] Freeing SSL session...
[D] Freeing SSL context...
Opening device...
[D] Configuring device...
[D] Creating a socket...
[D] Enabling keep-alives on the socket...
[D] Initialising OpenSSL environment...
[D] Allocating SSL context...
[D] Loading personal certificate...
[D] Loading personal certificate key...
[D] Loading CA certificate...
[D] Setting verification mode...
[D] Allocating SSL session...
[D] Assigning socket...
[D] Initialising SSL state...
[D] Sending handshake...
[D] Server has closed the SSL connection
[D] Shutting down SSL session...
Loop started
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] Server has closed the connection
[E] Socket has gone
Loop ended
Opening device...
[I] Loop started
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[E] Socket has gone
[I] Loop ended
^C
Your detailed log shows same
Post by PoltoS » 12 Jan 2013 12:24
Your detailed log shows same behavior as we have seen for jussiva and some other users. Please try to test your stick with some other s/w - may be it is dead? Unfortunately we have seen about 5 dead sticks last two months?
Try to unplug and plug back it. For some users it helped.
nutcracker
I'm not particularly
I'm not particularly impressed. Yes, have tried unplugging/replugging back in, but no go. Unfortunately no other software (that I'm aware of?) works with this stick. The stick was advertised as working with the Z-Wave.me service so unless I can download the Z-Way software and run locally here to confirm all is good, I'm stuffed.
kenazcs
agreed is there any way we
Post by kenazcs » 12 Jan 2013 12:24
agreed is there any way we can run z-way local? That's better for my home. (limited bandwidth)
You can test it agains some
You can test it agains some other software like Z-Send, AZW, HomeSeer, Z-Commander, ...Unfrtunatelly we do not ship Z-Way as is yet.
