Linux newbie can't install z-agent
t2tonesimone
Post by t2tonesimone »
Tried what little I could find to install Z-agent after downloading it using some small bits of advice from forum. Just wondered if there is a linux (Ubuntu) installation guide somewhere as I am really struggling.
I managed the sudo apt-get lidg-dev or whatever it was and can navigate to the unix folder but it says there is no such command as make. How do I compile it?
thanks
You need to install development tools
Something like this should do the job: sudo apt-get install make gcc libargtable2-dev libssl-dev
eligv
./Run_Z-Agent.sh...
Post by eligv »
./Run_Z-Agent.sh...
E] opening device
failed to open device: permission denied
E] opening device
E] opening device
failed to open device: permission denied...
Try tu run under superuser
Try to run under superuser (root): sudo ./Run_Z-Agent.sh
This can be solved by correct permissions on port or adding youself to the group owning the ttyUSBx device.
eligv
Right! With da superuser
Post by eligv »
Right! With da superuser permissions and starts the loop.
Thank you very much.
