Z-Way for iOS and RaZberry
graycrow
Post by graycrow »
Before RaZberry I used Z-Wave.me USB stick with my Raspberry Pi and Z-Cloud. With Z-Cloud I been able to use Z-Way application from iOS devices.
After replacing USB stick by RaZberry, I tried to set up Z-Way for iOS by providing a local Raspberry IP address (instead of Z-Cloud) and blank username and password, but id doesn't work, it says No Connection.
I understand that Z-Way for iOS been made for Z-Cloud, but because RaZberry software so similar to Z-Cloud (and probably based on it), is there any plans to support RaZberry in this iOS application?
Thank you.
It must work! Make sure to
It must work! Make sure to specify "http://" perfix and the port 8083 (or other if you have changed it).
graycrow
It works! Thank you.
Post by graycrow »
The problem solved by adding an "http://" perfix.
