ACT compatibility problem?
Johnny
Post by Johnny »
At the moment I test some different devices:
I bought some zwave.me devices (dimmer and blind control) which work great.
This week I tested an ACT ZRW232 dimmer which cannot be detected correct in the device configuration and also cannot be found in the manual selection of the device description record.
I can control the dimmer (on/off/various dimming level), but I cannot change some selection like dimming time, switch buttons, and so on..
I tried to select the ZRW230 which is very similar (3 wire version) but still no improvement.
Is this a problem with the ACT devices itself (e.g. not 100% zwave compatible firmware) or a problem of the device description records?
This device was discontinued
This device was discontinued several years ago and it is not in our database. Some of versions of the device are in the db - just try to pick it up manually.
If you want to configure the device, you can use our API to do this (we will do a UI soon). This is done with devices[X].instances[0].commandClasses.Configuration.Set(param, val, size)
