Camera Access
Yepher
Camera Access
Post by Yepher »
I have this camera
http://www.zwaveproducts.com/Zwave-Secu ... amera.html
How can I access it with Z-Way and my RaZberry?
If you look in the data sheet
If you look in the data sheet, you will find that is just an ip cam. there is nothing from Z-Wave in it.
Yepher
Datasheet
Post by Yepher »
Which datasheet did you look at.
I have used this witch a couple of ZWave gateways like "MyNexia" and I was able to view it through their gateway.
The datasheet in the site you
The datasheet in the site you posted does not mention it is a Z-Wave device except that it is supported by some specific Z-Wave enabled controller. The camera is a simple IP cam, which is supported by the gateway you have used, but it has nothing to do with Z-Wave. At least we have never seen Z-Wave enabled cameras.
