Multiple events of same type and content
krambriw
Post by krambriw »
Multiple events of same type and content. I notice that I receive multiple numbers of the same event in many cases. Like when touching an input on the Fibaro universal binary sensor. Is there a design idea behind or is it just the internal filtering that is missing? Or is it the device that sends so many repetitions? BestR Walter
16:53:27 ZWAY.Device_6_Instance_2 ['192.168.10.248', u'false']
16:53:28 ZWAY.Device_6_Instance_2 ['192.168.10.248', u'true']
16:53:29 ZWAY.Device_6_Instance_2 ['192.168.10.248', u'true']
16:53:30 ZWAY.Device_6_Instance_2 ['192.168.10.248', u'true']
16:53:31 ZWAY.Device_6_Instance_2 ['192.168.10.248', u'true']
16:53:32 ZWAY.Device_6_Instance_2 ['192.168.10.248', u'true']
We need to see Z-Way log to
We need to see Z-Way log to tell more. Your log says us nothing ;)
krambriw
 This is from the z-way log
Post by krambriw »
 This is from the z-way log after I press one time quickly on a button that triggers the input:[2013-04-20 14:22:08.592] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:08.593] SENT ACK
[2013-04-20 14:22:08.594] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:08.594] Node 6:0 CC MultiChannel: Received CC 0x4131eb64 command command from instance 2691530, but it isn't registered, creating it
[2013-04-20 14:22:08.594] SETDATA devices.6.instances.2.commandClasses.32.data = Empty
[2013-04-20 14:22:08.595] SETDATA devices.6.instances.2.commandClasses.32.data.version = Empty
[2013-04-20 14:22:08.595] SETDATA devices.6.instances.2.commandClasses.32.data.version = 1 (0x00000001)
[2013-04-20 14:22:08.595] SETDATA devices.6.instances.2.commandClasses.32.data.security = Empty
[2013-04-20 14:22:08.595] SETDATA devices.6.instances.2.commandClasses.32.data.security = False
[2013-04-20 14:22:08.596] SETDATA devices.6.instances.2.commandClasses.32.data.interviewDone = Empty
[2013-04-20 14:22:08.596] SETDATA devices.6.instances.2.commandClasses.32.data.interviewCounter = Empty
[2013-04-20 14:22:08.596] SETDATA devices.6.instances.2.commandClasses.32.data.interviewDone = False
[2013-04-20 14:22:08.596] SETDATA devices.6.instances.2.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2013-04-20 14:22:08.596] SETDATA devices.6.instances.2.commandClasses.32.data.level = Empty
[2013-04-20 14:22:08.596] SETDATA devices.6.instances.2.commandClasses.32.data.lastset = Empty
[2013-04-20 14:22:08.597] SETDATA devices.6.instances.2.commandClasses.32.data.mylevel = Empty
[2013-04-20 14:22:08.597] SETDATA devices.6.instances.2.commandClasses.32.data.mylevel = 0 (0x00000000)
[2013-04-20 14:22:08.597] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:08.597] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:08.778] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:08.779] SENT ACK
[2013-04-20 14:22:08.779] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:08.780] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:08.780] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:08.939] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:08.940] SENT ACK
[2013-04-20 14:22:08.940] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:08.941] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:08.941] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:09.006] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:09.007] SENT ACK
[2013-04-20 14:22:09.007] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.007] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:09.007] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:09.072] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:09.073] SENT ACK
[2013-04-20 14:22:09.074] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.074] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:09.074] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:09.098] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:09.099] SENT ACK
[2013-04-20 14:22:09.099] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.099] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:09.099] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:09.189] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:09.190] SENT ACK
[2013-04-20 14:22:09.190] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.191] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:09.191] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:09.272] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 00 BB )
[2013-04-20 14:22:09.273] SENT ACK
[2013-04-20 14:22:09.273] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.273] SETDATA devices.1.instances.2.commandClasses.32.data.level = 0 (0x00000000)
[2013-04-20 14:22:09.273] SETDATA devices.6.instances.2.commandClasses.48.data.level = False
[2013-04-20 14:22:09.318] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.319] SENT ACK
[2013-04-20 14:22:09.319] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.319] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.320] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.501] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.502] SENT ACK
[2013-04-20 14:22:09.502] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.503] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.503] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.548] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.549] SENT ACK
[2013-04-20 14:22:09.549] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.549] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.549] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.617] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.618] SENT ACK
[2013-04-20 14:22:09.618] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.618] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.619] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.686] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.687] SENT ACK
[2013-04-20 14:22:09.688] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.688] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.688] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.710] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.711] SENT ACK
[2013-04-20 14:22:09.711] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.712] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.712] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.734] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.735] SENT ACK
[2013-04-20 14:22:09.735] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.735] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.735] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.825] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.826] SENT ACK
[2013-04-20 14:22:09.826] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.827] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.827] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.860] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.861] SENT ACK
[2013-04-20 14:22:09.861] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.862] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.862] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:09.906] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:09.907] SENT ACK
[2013-04-20 14:22:09.907] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:09.908] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:09.908] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.095] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.096] SENT ACK
[2013-04-20 14:22:10.097] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.097] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.097] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.186] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.189] SENT ACK
[2013-04-20 14:22:10.189] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.189] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.189] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.268] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.269] SENT ACK
[2013-04-20 14:22:10.269] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.269] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.270] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.291] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.292] SENT ACK
[2013-04-20 14:22:10.293] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.293] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.293] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.339] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.340] SENT ACK
[2013-04-20 14:22:10.340] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.340] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.340] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.408] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.408] SENT ACK
[2013-04-20 14:22:10.409] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.409] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.409] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.454] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.455] SENT ACK
[2013-04-20 14:22:10.455] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.455] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.455] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.489] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.489] SENT ACK
[2013-04-20 14:22:10.490] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.490] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.490] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.557] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.558] SENT ACK
[2013-04-20 14:22:10.558] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.559] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.559] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
[2013-04-20 14:22:10.603] RECEIVED: ( 01 0D 00 04 00 06 07 60 0D 02 02 20 01 FF 44 )
[2013-04-20 14:22:10.604] SENT ACK
[2013-04-20 14:22:10.604] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2013-04-20 14:22:10.605] SETDATA devices.1.instances.2.commandClasses.32.data.level = 255 (0x000000ff)
[2013-04-20 14:22:10.605] SETDATA devices.6.instances.2.commandClasses.48.data.level = True
Well, as you see, there are
Well, as you see, there are indeed quite a lot of events from the Fibaro sensor. Z-Way is not to blame in making too much events.
Please check that connection is good (duplicates may come due to no reception confirmation)
