HomeSettings HA05 - Screw-in Module
brent192
Post by brent192 »
I'm having trouble getting this device to include... It sees it come up but never adds it in the system. I see a failed message in the Inspect Queue, but no error message in the log file. Any ideas?
[2013-09-25 23:20:12.056] Executing script: zway.controller.AddNodeToNetwork(1)
[2013-09-25 23:20:12.057] Adding job: Add/re-include node to network
[2013-09-25 23:20:12.064] SENDING (cb 0xbb): ( 01 05 00 4A C1 BB CA )
[2013-09-25 23:20:12.076] RECEIVED ACK
[2013-09-25 23:20:12.087] RECEIVED: ( 01 07 00 4A BB 01 00 00 08 )
[2013-09-25 23:20:12.088] SENT ACK
[2013-09-25 23:20:12.089] SETDATA controller.data.lastIncludedDevice = Empty
[2013-09-25 23:20:12.091] SETDATA controller.data.lastExcludedDevice = Empty
[2013-09-25 23:20:12.092] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2013-09-25 23:20:12.093] SETDATA controller.data.controllerState = 1 (0x00000001)
[2013-09-25 23:20:12.648] Executing script: zway.InspectQueue()
[2013-09-25 23:20:13.646] Executing script: zway.InspectQueue()
[2013-09-25 23:20:14.647] Executing script: zway.InspectQueue()
[2013-09-25 23:20:15.647] Executing script: zway.InspectQueue()
[2013-09-25 23:20:15.935] RECEIVED: ( 01 07 00 4A BB 02 00 00 0B )
[2013-09-25 23:20:15.936] SENT ACK
[2013-09-25 23:20:15.937] Job 0x4a (Add/re-include node to network): Node found: #0
[2013-09-25 23:20:15.939] SETDATA controller.data.controllerState = 2 (0x00000002)
[2013-09-25 23:20:16.648] Executing script: zway.InspectQueue()
[2013-09-25 23:20:17.658] Executing script: zway.InspectQueue()
[2013-09-25 23:20:18.647] Executing script: zway.InspectQueue()
[2013-09-25 23:20:19.052] RECEIVED: ( 01 07 00 4A BB 07 00 00 0E )
[2013-09-25 23:20:19.053] SENT ACK
[2013-09-25 23:20:19.054] Job 0x4a (Add/re-include node to network): Failed
[2013-09-25 23:20:19.056] Job 0x4a (Add/re-include node to network): fail
[2013-09-25 23:20:19.056] Removing job: Add/re-include node to network
[2013-09-25 23:20:19.058] Adding job: Add/re-include node to network
[2013-09-25 23:20:19.070] SENDING (cb 0xc5): ( 01 04 00 4A C5 74 )
[2013-09-25 23:20:19.082] RECEIVED ACK
[2013-09-25 23:20:19.083] Removing job: Add/re-include node to network
[2013-09-25 23:20:19.128] RECEIVED: ( 01 07 00 4A BB 06 00 00 0F )
[2013-09-25 23:20:19.129] SENT ACK
[2013-09-25 23:20:19.130] Job 0x4a (Add/re-include node to network): Done
[2013-09-25 23:20:19.131] SETDATA controller.data.controllerState = 0 (0x00000000)
[2013-09-25 23:20:19.132] Job 0x4a (Add/re-include node to network): success
[2013-09-25 23:20:19.133] Removing job: Add/re-include node to network
You certainly press NIF
You certainly press NIF button sequence instead of learn mode sequence. Please read user manual of your device to check button sequence you nee to include the device.
