Hi I have uploaded floorplan and set up all zones etc. All works fine, although not currently as useful as z-cloud. Problem I have is that if I log in from another device or even a different browser on the same computer the floor plan I have uploaded gets replaced by the default. Is there anyway to stop it doing this?
I currently work around it by having floor plan saved in dropbox and uploading to all devices/browsers as required but its a bit annoying.
Simon
Where does floor plan get saved. mine resets to default
t2tonesimone
Did you hit the save button
Did you hit the save button after you uploaded your new floorplan?
The image is stored in directory /opt/z-way-server/htdocs/config/maps
