I got Razberry with one module fibaro dimmer FGD 211, regulary the module is disconnected from zway program.
I got this message "The device seems to be dead", i only successfully connected the module 4 hours straight.
Configuration :
Raspberry PI model B
Razberry card
FGD211 dimmer
Raspian '2014-01-07-wheezy-raspbian.zip' default.
Tested :
domoticz image (pb to integrated zway library, after reboot zway en domoticz software not running)
Zway on raspian + domoticz work but module disconnect.
I tried many possibility but no one seem to work correctly.
like mentionned in another post does fibaro/chip is fully compatible with razberry ?
Regards,
Nicka
Re: The device seems to be dead
Just for info i will try to install the last version v1.5.0-rc1 and i will report if something change.
Do you have some update on this ?
I'm also experiencing that problem with my roller shutter from aeotec.
I did setup cronjob to shut up and down , and it hangs every 2 cycles.
yeah finally sent back my razberry to vendor, i wait a new razberry.
There is some razberrry with problem. you can contact your vendor.
I also change client, now i use jeedom and this one for me is better.
