Cancell Device
SolarFlor
Cancell Device
Post by SolarFlor »
during all my trials with Z-Way I have included and excluded more times the same device (Fibaro Plug).
At the end now I have 3 devices but only one is a real one.
How I can remove the 'false' devices?
thanks
SolarFlor
Re: Cancell Device
Post by SolarFlor »
Anybody to help? :?
Pipistrello77
Re: Cancell Device
Post by Pipistrello77 »
Probably, in network section, reset the controller and reinclude all the devices.
ollfa
Re: Cancell Device
Post by ollfa »
If they are marked as failed or dead by the system you remove failed nodes under "network management".
SolarFlor
Re: Cancell Device
Post by SolarFlor »
It seems I cannot select "Remove Failed Node"
Re: Cancell Device
You need first to enable Expert mode and in Device Status tab press Test Connection button. Then go to Network Management and Remove them as Failed.
SolarFlor
Re: Cancell Device
Post by SolarFlor »
I did but doesn't work
Re: Cancell Device
Was it maked as Failed?
SolarFlor
Re: Cancell Device
Post by SolarFlor »
Please see attached the situation on Device 2 (one of the ones that I would like to remove).
I'm in Expert mode.
Presentazione standard2.jpg (36.96 KiB) Viewed 13935 times
Presentazione standard1.jpg (51.89 KiB) Viewed 13935 times
michap
Re: Cancell Device
Post by michap »
have you tried this?
PoltoS wrote:You need first to enable Expert mode and in Device Status tab press Test Connection button. Then go to Network Management and Remove them as Failed.
It is not possible that the same device is online with different IDs ;)
Michael
