UI not updating when wall switch operated
sdh
Post by sdh »
I am having a handful of Aeon Labs MSES G2 installed. I observe that the Z-Way UI does not get updated when the wall switch connected to the MSES is operated. I have to manually update it in the UI. I am on 1.5.0-rc3 and the Parameter 80 of the MSES is set to 1 (Hail). Any idea what is wrong here.
Edit 1
Under 'Device Control' Tab, I see that 'Device Status', 'Sensors' and 'Meters' are getting updated. Only the 'Switches' tab never updates till I manually update it.
Edit 2, Some screen shots:
Device 10 KWh readings updated
Screen Shot 2014-04-14 at 5.11.25 am.png (139.67 KiB) Viewed 14562 times
Device 10 power meter is reporting and updated
Screen Shot 2014-04-14 at 5.10.53 am.png (205.35 KiB) Viewed 14562 times
Device 4, 6, 17 status updated because of a script, 10 operated using wall switch, no update
Screen Shot 2014-04-14 at 5.10.11 am.png (211.51 KiB) Viewed 14562 times
Re: UI not updating when wall switch operated
This seems to be a known issue. Show me your log when updates are comming.
Two options:
1) device does not send updates (unlikely)
2) device sends these updates without channel information, so Z-Way applies them to channel 0 and not to channels 1-5 (sine the device do not provide that info)
ozgreg
Post by ozgreg »
Actually I suspect now that is also my issue..
I am not seeing any (power) data in the log..
[2014-04-16 22:09:36.637] SENT ACK
[2014-04-16 22:09:36.637] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:09:36.637] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2014-04-16 22:09:36.637] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2014-04-16 22:09:36.638] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 47.000000
[2014-04-16 22:09:36.640] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2014-04-16 22:09:36.640] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2014-04-16 22:09:36.673] RECEIVED: ( 01 0C 00 04 00 03 06 31 05 01 22 00 D8 3D )
[2014-04-16 22:09:36.674] SENT ACK
[2014-04-16 22:09:36.674] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:09:36.674] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2014-04-16 22:09:36.676] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-04-16 22:09:36.676] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.600000
[2014-04-16 22:09:36.679] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2014-04-16 22:09:36.679] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2014-04-16 22:10:36.590] RECEIVED: ( 01 09 00 04 00 03 03 80 03 64 15 )
[2014-04-16 22:10:36.590] SENT ACK
[2014-04-16 22:10:36.590] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:10:36.590] SETDATA devices.3.instances.0.commandClasses.128.data.history.100 = 1397650236 (0x534e733c)
[2014-04-16 22:10:36.590] SETDATA devices.3.instances.0.commandClasses.128.data.last = 100 (0x00000064)
[2014-04-16 22:10:36.612] RECEIVED: ( 01 0C 00 04 00 03 06 31 05 03 0A 00 12 DD )
[2014-04-16 22:10:36.613] SENT ACK
[2014-04-16 22:10:36.613] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:10:36.613] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2014-04-16 22:10:36.613] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2014-04-16 22:10:36.613] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 18.000000
[2014-04-16 22:10:36.616] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2014-04-16 22:10:36.616] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2014-04-16 22:10:36.650] RECEIVED: ( 01 0C 00 04 00 03 06 31 05 05 01 2F 00 ED )
[2014-04-16 22:10:36.650] SENT ACK
[2014-04-16 22:10:36.651] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:10:36.651] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2014-04-16 22:10:36.651] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2014-04-16 22:10:36.651] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 47.000000
[2014-04-16 22:10:36.653] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2014-04-16 22:10:36.654] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2014-04-16 22:10:36.675] RECEIVED: ( 01 0C 00 04 00 03 06 31 05 01 22 00 D8 3D )
[2014-04-16 22:10:36.676] SENT ACK
[2014-04-16 22:10:36.676] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:10:36.676] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2014-04-16 22:10:36.678] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2014-04-16 22:10:36.678] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.600000
[2014-04-16 22:10:36.681] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2014-04-16 22:10:36.681] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
I would be expecting to see..
[2014-04-16 22:12:54.953] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2014-04-16 22:12:54.953] SETDATA devices.4.instances.0.commandClasses.50.data.2.val = 4.774000
[2014-04-16 22:12:54.953] SETDATA devices.4.instances.0.commandClasses.50.data.2.delta = 1207 (0x000004b7)
[2014-04-16 22:12:54.954] SETDATA devices.4.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2014-04-16 22:12:54.954] SETDATA devices.4.instances.0.commandClasses.50.data.2.previous = 1.802000
[2014-04-16 22:12:54.954] SETDATA devices.4.instances.0.commandClasses.50.data.2 = Empty
[2014-04-16 22:12:56.369] RECEIVED: ( 01 0C 00 04 00 03 06 31 05 03 0A 00 12 DD )
ozgreg
Post by ozgreg »
When I look at the configuration of the device I am seeing a lot of
Configuration parameter type is not handled in the interface: constant
and the parameters are all missing values which would explain the lack of updates as they control when the updates are reported..
You can still set them in expert mode, so please do that. Then you can press on Configuration and see them to be stored on the device (inspect data tree)
sdh
Post by sdh »
Here is what I did. First ran update all on Z-Way UI, followed by operating the node 10 from the UI (ON followed by OFF) and then operated the node 10 using the wall switch (ON, OFF). Device 10 is Aeon MSES G2.
Log Part 1:
[2014-04-17 08:06:09.447] Executing script: zway.devices[3].instances[2].commandClasses[38].Get()
[2014-04-17 08:06:09.461] Adding job: MultiChannel encapsulation
[2014-04-17 08:06:09.469] SENDING (cb 0xe5): [2014-04-17 08:06:09.474] Executing script: zway.devices[3].instances[1].commandClasses[38].Get()
( 01 0D 00 13 03 06 60 0D 01 02 26 02 25 E5 6E )
[2014-04-17 08:06:09.476] Adding job: MultiChannel encapsulation
[2014-04-17 08:06:09.477] Executing script: zway.devices[3].instances[3].commandClasses[38].Get()
[2014-04-17 08:06:09.479] Adding job: MultiChannel encapsulation
[2014-04-17 08:06:09.480] RECEIVED ACK
[2014-04-17 08:06:09.480] Executing script: zway.devices[3].instances[4].commandClasses[38].Get()
[2014-04-17 08:06:09.482] Adding job: MultiChannel encapsulation
[2014-04-17 08:06:09.483] Executing script: zway.devices[3].instances[5].commandClasses[38].Get()
[2014-04-17 08:06:09.485] Adding job: MultiChannel encapsulation
[2014-04-17 08:06:09.486] Executing script: zway.devices[4].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.489] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.491] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:09.491] SENT ACK
[2014-04-17 08:06:09.492] Delivered to Z-Wave stack
[2014-04-17 08:06:09.567] Executing script: zway.devices[5].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.585] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.597] Executing script: zway.devices[6].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.600] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.601] Executing script: zway.devices[7].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.603] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.603] Executing script: zway.devices[8].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.605] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.605] Executing script: zway.devices[9].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.607] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.608] Executing script: zway.devices[10].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.611] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.685] Executing script: zway.devices[11].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.693] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.714] Executing script: zway.devices[12].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.716] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.717] Executing script: zway.devices[13].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.719] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.720] Executing script: zway.devices[14].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.721] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.722] Executing script: zway.devices[15].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.724] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.725] Executing script: zway.devices[16].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.728] Adding job: SwitchBinary Get
[2014-04-17 08:06:09.794] Executing script: zway.devices[17].instances[0].commandClasses[37].Get()
[2014-04-17 08:06:09.796] Adding job: SwitchBinary Get
[2014-04-17 08:06:15.074] RECEIVED: ( 01 05 00 13 E5 01 0D )
[2014-04-17 08:06:15.080] SENT ACK
[2014-04-17 08:06:15.080] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:06:15.081] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:15.081] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:06:15.081] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5589 (0x000015d5)
[2014-04-17 08:06:15.081] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:06:15.093] SENDING (cb 0xe6): ( 01 0D 00 13 03 06 60 0D 01 02 26 02 25 E6 6D )
[2014-04-17 08:06:15.105] RECEIVED ACK
[2014-04-17 08:06:15.117] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:15.118] SENT ACK
[2014-04-17 08:06:15.118] Delivered to Z-Wave stack
[2014-04-17 08:06:20.443] RECEIVED: ( 01 05 00 13 E6 01 0E )
[2014-04-17 08:06:20.444] SENT ACK
[2014-04-17 08:06:20.444] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:06:20.444] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:20.445] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:06:20.445] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5325 (0x000014cd)
[2014-04-17 08:06:20.445] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:06:20.457] SENDING (cb 0xe7): ( 01 0D 00 13 03 06 60 0D 01 02 26 02 25 E7 6C )
[2014-04-17 08:06:20.468] RECEIVED ACK
[2014-04-17 08:06:20.491] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:20.492] SENT ACK
[2014-04-17 08:06:20.493] Delivered to Z-Wave stack
[2014-04-17 08:06:26.194] RECEIVED: ( 01 05 00 13 E7 01 0F )
[2014-04-17 08:06:26.194] SENT ACK
[2014-04-17 08:06:26.195] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:06:26.195] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:26.195] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:06:26.195] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5703 (0x00001647)
[2014-04-17 08:06:26.196] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:06:26.196] Job 0x13 (MultiChannel encapsulation): Removing job due to too much retransmitions
[2014-04-17 08:06:26.196] Adding job: Check if node is failed
[2014-04-17 08:06:26.196] Job 0x13 (MultiChannel encapsulation): fail
[2014-04-17 08:06:26.197] Removing job: MultiChannel encapsulation
[2014-04-17 08:06:26.208] SENDING (cb 0x03): ( 01 04 00 62 03 9A )
[2014-04-17 08:06:26.219] RECEIVED ACK
[2014-04-17 08:06:26.230] RECEIVED: ( 01 04 01 62 01 99 )
[2014-04-17 08:06:26.230] SENT ACK
[2014-04-17 08:06:26.230] SETDATA devices.3.data.isFailed = True
[2014-04-17 08:06:26.231] Job 0x62 (Check if node is failed): Node 3 is failed
[2014-04-17 08:06:26.231] Job 0x62 (Check if node is failed): success
[2014-04-17 08:06:26.231] SETDATA devices.3.data.failureCount = 1 (0x00000001)
[2014-04-17 08:06:26.231] SETDATA devices.3.data.lastSend = 21816880 (0x014ce630)
[2014-04-17 08:06:26.232] Removing job: Check if node is failed
[2014-04-17 08:06:26.243] SENDING (cb 0xe8): ( 01 09 00 13 04 02 25 02 25 E8 09 )
[2014-04-17 08:06:26.255] RECEIVED ACK
[2014-04-17 08:06:26.265] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.266] SENT ACK
[2014-04-17 08:06:26.266] Delivered to Z-Wave stack
[2014-04-17 08:06:26.278] RECEIVED: ( 01 05 00 13 E8 00 01 )
[2014-04-17 08:06:26.278] SENT ACK
[2014-04-17 08:06:26.279] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.279] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.279] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.280] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-04-17 08:06:26.281] SETDATA devices.4.data.lastPacketInfo = **********
[2014-04-17 08:06:26.281] SendData Response with callback 0xe8 received: received by recipient
[2014-04-17 08:06:26.281] SETDATA devices.4.data.lastSend = 21816584 (0x014ce508)
[2014-04-17 08:06:26.281] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.282] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.292] RECEIVED: ( 01 09 00 04 00 04 03 25 03 FF 2C )
[2014-04-17 08:06:26.293] SENT ACK
[2014-04-17 08:06:26.293] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.293] SETDATA devices.4.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:26.305] SENDING (cb 0xe9): ( 01 09 00 13 05 02 25 02 25 E9 09 )
[2014-04-17 08:06:26.316] RECEIVED ACK
[2014-04-17 08:06:26.327] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.327] SENT ACK
[2014-04-17 08:06:26.327] Delivered to Z-Wave stack
[2014-04-17 08:06:26.338] RECEIVED: ( 01 05 00 13 E9 00 00 )
[2014-04-17 08:06:26.339] SENT ACK
[2014-04-17 08:06:26.339] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.339] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.339] SETDATA devices.5.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.341] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-04-17 08:06:26.342] SETDATA devices.5.data.lastPacketInfo = **********
[2014-04-17 08:06:26.342] SendData Response with callback 0xe9 received: received by recipient
[2014-04-17 08:06:26.342] SETDATA devices.5.data.lastSend = 21816589 (0x014ce50d)
[2014-04-17 08:06:26.342] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.343] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.353] RECEIVED: ( 01 09 00 04 00 05 03 25 03 FF 2D )
[2014-04-17 08:06:26.354] SENT ACK
[2014-04-17 08:06:26.354] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.354] SETDATA devices.5.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:26.367] SENDING (cb 0xea): ( 01 09 00 13 06 02 25 02 25 EA 09 )
[2014-04-17 08:06:26.378] RECEIVED ACK
[2014-04-17 08:06:26.389] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.390] SENT ACK
[2014-04-17 08:06:26.390] Delivered to Z-Wave stack
[2014-04-17 08:06:26.400] RECEIVED: ( 01 05 00 13 EA 00 03 )
[2014-04-17 08:06:26.401] SENT ACK
[2014-04-17 08:06:26.401] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.402] SETDATA devices.6.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.403] SETDATA devices.6.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.403] SETDATA devices.6.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-04-17 08:06:26.403] SETDATA devices.6.data.lastPacketInfo = **********
[2014-04-17 08:06:26.404] SendData Response with callback 0xea received: received by recipient
[2014-04-17 08:06:26.405] SETDATA devices.6.data.lastSend = 21816594 (0x014ce512)
[2014-04-17 08:06:26.405] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.405] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.415] RECEIVED: ( 01 09 00 04 00 06 03 25 03 FF 2E )
[2014-04-17 08:06:26.416] SENT ACK
[2014-04-17 08:06:26.416] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.417] SETDATA devices.6.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:26.429] SENDING (cb 0xeb): ( 01 09 00 13 07 02 25 02 25 EB 09 )
[2014-04-17 08:06:26.439] RECEIVED ACK
[2014-04-17 08:06:26.450] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.451] SENT ACK
[2014-04-17 08:06:26.451] Delivered to Z-Wave stack
[2014-04-17 08:06:26.461] RECEIVED: ( 01 05 00 13 EB 00 02 )
[2014-04-17 08:06:26.462] SENT ACK
[2014-04-17 08:06:26.462] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.464] SETDATA devices.7.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.464] SETDATA devices.7.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.464] SETDATA devices.7.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-04-17 08:06:26.465] SETDATA devices.7.data.lastPacketInfo = **********
[2014-04-17 08:06:26.465] SendData Response with callback 0xeb received: received by recipient
[2014-04-17 08:06:26.465] SETDATA devices.7.data.lastSend = 21816599 (0x014ce517)
[2014-04-17 08:06:26.465] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.466] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.476] RECEIVED: ( 01 09 00 04 00 07 03 25 03 FF 2F )
[2014-04-17 08:06:26.477] SENT ACK
[2014-04-17 08:06:26.477] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.477] SETDATA devices.7.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:26.489] SENDING (cb 0xec): ( 01 09 00 13 08 02 25 02 25 EC 01 )
[2014-04-17 08:06:26.500] RECEIVED ACK
[2014-04-17 08:06:26.511] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.512] SENT ACK
[2014-04-17 08:06:26.512] Delivered to Z-Wave stack
[2014-04-17 08:06:26.522] RECEIVED: ( 01 05 00 13 EC 00 05 )
[2014-04-17 08:06:26.523] SENT ACK
[2014-04-17 08:06:26.523] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.523] SETDATA devices.8.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.524] SETDATA devices.8.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.525] SETDATA devices.8.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-04-17 08:06:26.525] SETDATA devices.8.data.lastPacketInfo = **********
[2014-04-17 08:06:26.526] SendData Response with callback 0xec received: received by recipient
[2014-04-17 08:06:26.526] SETDATA devices.8.data.lastSend = 21816604 (0x014ce51c)
[2014-04-17 08:06:26.526] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.526] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.537] RECEIVED: ( 01 09 00 04 00 08 03 25 03 FF 20 )
[2014-04-17 08:06:26.537] SENT ACK
[2014-04-17 08:06:26.538] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.538] SETDATA devices.8.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:26.550] SENDING (cb 0xed): ( 01 09 00 13 09 02 25 02 25 ED 01 )
[2014-04-17 08:06:26.561] RECEIVED ACK
[2014-04-17 08:06:26.572] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.572] SENT ACK
[2014-04-17 08:06:26.572] Delivered to Z-Wave stack
[2014-04-17 08:06:26.606] RECEIVED: ( 01 05 00 13 ED 00 04 )
[2014-04-17 08:06:26.607] SENT ACK
[2014-04-17 08:06:26.607] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.607] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.607] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.608] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 34 (0x00000022)
[2014-04-17 08:06:26.608] SETDATA devices.9.data.lastPacketInfo = **********
[2014-04-17 08:06:26.608] SendData Response with callback 0xed received: received by recipient
[2014-04-17 08:06:26.608] SETDATA devices.9.data.lastSend = 21816611 (0x014ce523)
[2014-04-17 08:06:26.609] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.609] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.621] SENDING (cb 0xee): ( 01 09 00 13 0A 02 25 02 25 EE 01 )
[2014-04-17 08:06:26.641] RECEIVED ACK
[2014-04-17 08:06:26.658] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.659] SENT ACK
[2014-04-17 08:06:26.659] Delivered to Z-Wave stack
[2014-04-17 08:06:26.670] RECEIVED: ( 01 05 00 13 EE 00 07 )
[2014-04-17 08:06:26.671] SENT ACK
[2014-04-17 08:06:26.672] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:26.672] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:26.672] SETDATA devices.10.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:26.672] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
[2014-04-17 08:06:26.673] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:06:26.673] SendData Response with callback 0xee received: received by recipient
[2014-04-17 08:06:26.673] SETDATA devices.10.data.lastSend = 21816615 (0x014ce527)
[2014-04-17 08:06:26.673] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:26.674] Removing job: SwitchBinary Get
[2014-04-17 08:06:26.685] SENDING (cb 0xef): ( 01 09 00 13 0B 02 25 02 25 EF 01 )
[2014-04-17 08:06:26.696] RECEIVED ACK
[2014-04-17 08:06:26.707] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:26.707] SENT ACK
[2014-04-17 08:06:26.707] Delivered to Z-Wave stack
[2014-04-17 08:06:26.820] RECEIVED: ( 01 09 00 04 00 09 03 25 03 00 DE )
[2014-04-17 08:06:26.820] SENT ACK
[2014-04-17 08:06:26.821] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.821] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:26.832] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:26.832] SENT ACK
[2014-04-17 08:06:26.833] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:26.834] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.164] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:27.165] SENT ACK
[2014-04-17 08:06:27.166] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.166] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.270] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:27.271] SENT ACK
[2014-04-17 08:06:27.271] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.271] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.400] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:27.401] SENT ACK
[2014-04-17 08:06:27.401] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.402] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.539] RECEIVED: ( 01 09 00 04 00 09 03 25 03 00 DE )
[2014-04-17 08:06:27.540] SENT ACK
[2014-04-17 08:06:27.541] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.541] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.563] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:27.564] SENT ACK
[2014-04-17 08:06:27.564] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.565] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.598] RECEIVED: ( 01 09 00 04 00 09 03 25 03 00 DE )
[2014-04-17 08:06:27.599] SENT ACK
[2014-04-17 08:06:27.599] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.600] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.667] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:27.668] SENT ACK
[2014-04-17 08:06:27.668] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.669] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.747] RECEIVED: ( 01 09 00 04 00 09 03 25 03 00 DE )
[2014-04-17 08:06:27.748] SENT ACK
[2014-04-17 08:06:27.749] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.749] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.759] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:06:27.760] SENT ACK
[2014-04-17 08:06:27.761] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.762] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:27.905] RECEIVED: ( 01 09 00 04 10 09 03 25 03 00 CE )
[2014-04-17 08:06:27.906] SENT ACK
[2014-04-17 08:06:27.906] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:27.907] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:28.209] RECEIVED: ( 01 09 00 04 10 09 03 25 03 00 CE )
[2014-04-17 08:06:28.210] SENT ACK
[2014-04-17 08:06:28.210] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:28.210] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:28.221] RECEIVED: ( 01 09 00 04 10 09 03 25 03 00 CE )
[2014-04-17 08:06:28.222] SENT ACK
[2014-04-17 08:06:28.223] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:28.223] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:28.335] RECEIVED: ( 01 09 00 04 10 09 03 25 03 00 CE )
[2014-04-17 08:06:28.336] SENT ACK
[2014-04-17 08:06:28.336] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:28.336] SETDATA devices.9.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:29.789] RECEIVED: ( 01 05 00 13 EF 00 06 )
[2014-04-17 08:06:29.790] SENT ACK
[2014-04-17 08:06:29.790] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:29.791] SETDATA devices.11.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:29.791] SETDATA devices.11.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:29.791] SETDATA devices.11.data.lastPacketInfo.deliveryTime = 3083 (0x00000c0b)
[2014-04-17 08:06:29.792] SETDATA devices.11.data.lastPacketInfo = **********
[2014-04-17 08:06:29.792] SendData Response with callback 0xef received: received by recipient
[2014-04-17 08:06:29.792] SETDATA devices.11.data.lastSend = 21816882 (0x014ce632)
[2014-04-17 08:06:29.792] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:29.793] Removing job: SwitchBinary Get
[2014-04-17 08:06:29.804] SENDING (cb 0xf0): ( 01 09 00 13 0C 02 25 02 25 F0 19 )
[2014-04-17 08:06:29.816] RECEIVED ACK
[2014-04-17 08:06:29.828] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:29.829] SENT ACK
[2014-04-17 08:06:29.829] Delivered to Z-Wave stack
[2014-04-17 08:06:30.200] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:30.201] SENT ACK
[2014-04-17 08:06:30.201] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:30.201] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:30.212] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:30.218] SENT ACK
[2014-04-17 08:06:30.219] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:30.219] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:30.242] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:30.242] SENT ACK
[2014-04-17 08:06:30.243] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:30.243] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:30.931] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:30.932] SENT ACK
[2014-04-17 08:06:30.933] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:30.933] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.132] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:31.133] SENT ACK
[2014-04-17 08:06:31.134] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.134] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.167] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:31.169] SENT ACK
[2014-04-17 08:06:31.169] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.170] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.202] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:31.206] SENT ACK
[2014-04-17 08:06:31.207] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.207] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.713] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:31.714] SENT ACK
[2014-04-17 08:06:31.715] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.715] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.726] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:31.727] SENT ACK
[2014-04-17 08:06:31.727] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.727] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.914] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:31.915] SENT ACK
[2014-04-17 08:06:31.915] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.915] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.983] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:31.984] SENT ACK
[2014-04-17 08:06:31.984] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.984] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:31.995] RECEIVED: ( 01 09 00 04 00 0B 03 25 03 FF 23 )
[2014-04-17 08:06:31.996] SENT ACK
[2014-04-17 08:06:31.996] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:31.997] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:32.018] RECEIVED: ( 01 09 00 04 10 0B 03 25 03 FF 33 )
[2014-04-17 08:06:32.019] SENT ACK
[2014-04-17 08:06:32.020] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:32.020] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:32.065] RECEIVED: ( 01 05 00 13 F0 01 18 )
[2014-04-17 08:06:32.065] SENT ACK
[2014-04-17 08:06:32.066] Job 0x13 (SwitchBinary Get): Not delivered to recipient
[2014-04-17 08:06:32.066] SETDATA devices.12.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:32.067] SETDATA devices.12.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:32.067] SETDATA devices.12.data.lastPacketInfo.deliveryTime = 2237 (0x000008bd)
[2014-04-17 08:06:32.067] SETDATA devices.12.data.lastPacketInfo = **********
[2014-04-17 08:06:32.079] SENDING (cb 0xf1): ( 01 0D 00 13 03 06 60 0D 01 01 26 02 25 F1 79 )
[2014-04-17 08:06:32.091] RECEIVED ACK
[2014-04-17 08:06:32.115] RECEIVED: ( 01 04 01 13 00 E9 )
[2014-04-17 08:06:32.116] SENT ACK
[2014-04-17 08:06:32.116] Job 0x13 (MultiChannel encapsulation): Could not be delivered to Z-Wave stack
[2014-04-17 08:06:32.128] SENDING (cb 0xf2): ( 01 0D 00 13 03 06 60 0D 01 01 26 02 25 F2 7A )
[2014-04-17 08:06:32.139] RECEIVED ACK
[2014-04-17 08:06:32.150] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:32.150] SENT ACK
[2014-04-17 08:06:32.150] Delivered to Z-Wave stack
[2014-04-17 08:06:32.172] RECEIVED: ( 01 09 00 04 10 0B 03 25 03 FF 33 )
[2014-04-17 08:06:32.173] SENT ACK
[2014-04-17 08:06:32.174] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:32.174] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:32.252] RECEIVED: ( 01 09 00 04 10 0B 03 25 03 FF 33 )
[2014-04-17 08:06:32.253] SENT ACK
[2014-04-17 08:06:32.254] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:32.254] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:32.276] RECEIVED: ( 01 09 00 04 10 0B 03 25 03 FF 33 )
[2014-04-17 08:06:32.277] SENT ACK
[2014-04-17 08:06:32.277] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:32.278] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:32.526] RECEIVED: ( 01 09 00 04 10 0B 03 25 03 FF 33 )
[2014-04-17 08:06:32.527] SENT ACK
[2014-04-17 08:06:32.527] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:32.528] SETDATA devices.11.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:37.472] RECEIVED: ( 01 05 00 13 F2 01 1A )
[2014-04-17 08:06:37.473] SENT ACK
[2014-04-17 08:06:37.474] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:06:37.474] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:37.474] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:06:37.475] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5323 (0x000014cb)
[2014-04-17 08:06:37.475] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:06:37.486] SENDING (cb 0xf3): ( 01 0D 00 13 03 06 60 0D 01 01 26 02 25 F3 7B )
[2014-04-17 08:06:37.498] RECEIVED ACK
[2014-04-17 08:06:37.510] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:37.511] SENT ACK
[2014-04-17 08:06:37.511] Delivered to Z-Wave stack
[2014-04-17 08:06:42.943] RECEIVED: ( 01 05 00 13 F3 01 1B )
[2014-04-17 08:06:42.950] SENT ACK
[2014-04-17 08:06:42.951] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:06:42.951] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:42.951] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:06:42.951] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5439 (0x0000153f)
[2014-04-17 08:06:42.952] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:06:42.952] Job 0x13 (MultiChannel encapsulation): Removing job due to too much retransmitions
[2014-04-17 08:06:42.952] SETDATA devices.3.data.failureCount = 2 (0x00000002)
[2014-04-17 08:06:42.952] SETDATA devices.3.data.lastSend = 21819021 (0x014cee8d)
[2014-04-17 08:06:42.953] Job 0x13 (MultiChannel encapsulation): fail
[2014-04-17 08:06:42.953] Removing job: MultiChannel encapsulation
[2014-04-17 08:06:42.965] SENDING (cb 0xf4): ( 01 09 00 13 0C 02 25 02 25 F4 1D )
[2014-04-17 08:06:42.976] RECEIVED ACK
[2014-04-17 08:06:42.988] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:42.989] SENT ACK
[2014-04-17 08:06:42.989] Delivered to Z-Wave stack
[2014-04-17 08:06:43.068] RECEIVED: ( 01 05 00 13 F4 00 1D )
[2014-04-17 08:06:43.069] SENT ACK
[2014-04-17 08:06:43.069] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:43.070] SETDATA devices.12.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:43.070] SETDATA devices.12.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:43.070] SETDATA devices.12.data.lastPacketInfo.deliveryTime = 80 (0x00000050)
[2014-04-17 08:06:43.070] SETDATA devices.12.data.lastPacketInfo = **********
[2014-04-17 08:06:43.070] SendData Response with callback 0xf4 received: received by recipient
[2014-04-17 08:06:43.071] SETDATA devices.12.data.lastSend = 21818031 (0x014ceaaf)
[2014-04-17 08:06:43.071] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:43.071] Removing job: SwitchBinary Get
[2014-04-17 08:06:43.083] SENDING (cb 0xf5): ( 01 09 00 13 0D 02 25 02 25 F5 1D )
[2014-04-17 08:06:43.095] RECEIVED ACK
[2014-04-17 08:06:43.106] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:43.107] SENT ACK
[2014-04-17 08:06:43.108] Delivered to Z-Wave stack
[2014-04-17 08:06:43.118] RECEIVED: ( 01 05 00 13 F5 00 1C )
[2014-04-17 08:06:43.119] SENT ACK
[2014-04-17 08:06:43.120] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:43.120] SETDATA devices.13.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:43.120] SETDATA devices.13.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:43.120] SETDATA devices.13.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-04-17 08:06:43.121] SETDATA devices.13.data.lastPacketInfo = **********
[2014-04-17 08:06:43.121] SendData Response with callback 0xf5 received: received by recipient
[2014-04-17 08:06:43.121] SETDATA devices.13.data.lastSend = 21818035 (0x014ceab3)
[2014-04-17 08:06:43.121] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:43.122] Removing job: SwitchBinary Get
[2014-04-17 08:06:43.132] RECEIVED: ( 01 09 00 04 00 0D 03 25 03 00 DA )
[2014-04-17 08:06:43.133] SENT ACK
[2014-04-17 08:06:43.133] SETDATA devices.13.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.134] SETDATA devices.13.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:43.147] SENDING (cb 0xf6): ( 01 09 00 13 0E 02 25 02 25 F6 1D )
[2014-04-17 08:06:43.158] RECEIVED ACK
[2014-04-17 08:06:43.170] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:43.171] SENT ACK
[2014-04-17 08:06:43.172] Delivered to Z-Wave stack
[2014-04-17 08:06:43.182] RECEIVED: ( 01 05 00 13 F6 00 1F )
[2014-04-17 08:06:43.183] SENT ACK
[2014-04-17 08:06:43.183] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:43.184] SETDATA devices.14.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:43.184] SETDATA devices.14.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:43.184] SETDATA devices.14.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2014-04-17 08:06:43.185] SETDATA devices.14.data.lastPacketInfo = **********
[2014-04-17 08:06:43.185] SendData Response with callback 0xf6 received: received by recipient
[2014-04-17 08:06:43.185] SETDATA devices.14.data.lastSend = 21818040 (0x014ceab8)
[2014-04-17 08:06:43.185] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:43.186] Removing job: SwitchBinary Get
[2014-04-17 08:06:43.196] RECEIVED: ( 01 09 00 04 00 0E 03 25 03 00 D9 )
[2014-04-17 08:06:43.197] SENT ACK
[2014-04-17 08:06:43.198] SETDATA devices.14.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.198] SETDATA devices.14.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:43.210] SENDING (cb 0xf7): ( 01 09 00 13 0F 02 25 02 25 F7 1D )
[2014-04-17 08:06:43.222] RECEIVED ACK
[2014-04-17 08:06:43.233] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:43.234] SENT ACK
[2014-04-17 08:06:43.234] Delivered to Z-Wave stack
[2014-04-17 08:06:43.437] RECEIVED: ( 01 05 00 13 F7 00 1E )
[2014-04-17 08:06:43.438] SENT ACK
[2014-04-17 08:06:43.439] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:43.439] SETDATA devices.15.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:43.439] SETDATA devices.15.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:43.440] SETDATA devices.15.data.lastPacketInfo.deliveryTime = 204 (0x000000cc)
[2014-04-17 08:06:43.440] SETDATA devices.15.data.lastPacketInfo = **********
[2014-04-17 08:06:43.440] SendData Response with callback 0xf7 received: received by recipient
[2014-04-17 08:06:43.440] SETDATA devices.15.data.lastSend = 21818061 (0x014ceacd)
[2014-04-17 08:06:43.440] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:43.441] Removing job: SwitchBinary Get
[2014-04-17 08:06:43.452] SENDING (cb 0xf8): ( 01 09 00 13 10 02 25 02 25 F8 0D )
[2014-04-17 08:06:43.464] RECEIVED ACK
[2014-04-17 08:06:43.476] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:43.477] SENT ACK
[2014-04-17 08:06:43.477] Delivered to Z-Wave stack
[2014-04-17 08:06:43.578] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:43.579] SENT ACK
[2014-04-17 08:06:43.580] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.580] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:43.637] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:43.638] SENT ACK
[2014-04-17 08:06:43.638] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.639] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:43.672] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:43.673] SENT ACK
[2014-04-17 08:06:43.673] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.673] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:43.785] RECEIVED: ( 01 05 00 13 F8 00 11 )
[2014-04-17 08:06:43.786] SENT ACK
[2014-04-17 08:06:43.786] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:43.786] SETDATA devices.16.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:43.787] SETDATA devices.16.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:43.787] SETDATA devices.16.data.lastPacketInfo.deliveryTime = 309 (0x00000135)
[2014-04-17 08:06:43.787] SETDATA devices.16.data.lastPacketInfo = **********
[2014-04-17 08:06:43.788] SendData Response with callback 0xf8 received: received by recipient
[2014-04-17 08:06:43.788] SETDATA devices.16.data.lastSend = 21818090 (0x014ceaea)
[2014-04-17 08:06:43.788] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:43.789] Removing job: SwitchBinary Get
[2014-04-17 08:06:43.800] SENDING (cb 0xf9): ( 01 09 00 13 11 02 25 02 25 F9 0D )
[2014-04-17 08:06:43.812] RECEIVED ACK
[2014-04-17 08:06:43.824] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:43.825] SENT ACK
[2014-04-17 08:06:43.825] Delivered to Z-Wave stack
[2014-04-17 08:06:43.870] RECEIVED: ( 01 09 00 04 00 10 03 25 03 00 C7 )
[2014-04-17 08:06:43.871] SENT ACK
[2014-04-17 08:06:43.871] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.871] SETDATA devices.16.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:43.893] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:43.894] SENT ACK
[2014-04-17 08:06:43.895] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.895] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:43.998] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:43.999] SENT ACK
[2014-04-17 08:06:43.999] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:43.999] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:44.181] RECEIVED: ( 01 09 00 04 00 0F 03 25 03 00 D8 )
[2014-04-17 08:06:44.182] SENT ACK
[2014-04-17 08:06:44.182] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.182] SETDATA devices.15.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:44.226] RECEIVED: ( 01 09 00 04 00 10 03 25 03 00 C7 )
[2014-04-17 08:06:44.227] SENT ACK
[2014-04-17 08:06:44.227] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.227] SETDATA devices.16.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:44.283] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:44.284] SENT ACK
[2014-04-17 08:06:44.285] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.285] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:44.330] RECEIVED: ( 01 09 00 04 00 10 03 25 03 00 C7 )
[2014-04-17 08:06:44.331] SENT ACK
[2014-04-17 08:06:44.331] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.331] SETDATA devices.16.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:44.432] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:44.433] SENT ACK
[2014-04-17 08:06:44.433] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.434] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:44.601] RECEIVED: ( 01 09 00 04 00 10 03 25 03 00 C7 )
[2014-04-17 08:06:44.602] SENT ACK
[2014-04-17 08:06:44.602] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.603] SETDATA devices.16.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:44.636] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:44.637] SENT ACK
[2014-04-17 08:06:44.637] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.638] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:44.705] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:44.706] SENT ACK
[2014-04-17 08:06:44.706] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.707] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:44.728] RECEIVED: ( 01 09 00 04 00 0C 03 25 03 FF 24 )
[2014-04-17 08:06:44.730] SENT ACK
[2014-04-17 08:06:44.730] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:44.730] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.160] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.162] SENT ACK
[2014-04-17 08:06:45.162] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.163] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.173] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.174] SENT ACK
[2014-04-17 08:06:45.175] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.175] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.196] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.197] SENT ACK
[2014-04-17 08:06:45.198] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.198] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.277] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.278] SENT ACK
[2014-04-17 08:06:45.278] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.279] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.335] RECEIVED: ( 01 09 00 04 10 0F 03 25 03 00 C8 )
[2014-04-17 08:06:45.336] SENT ACK
[2014-04-17 08:06:45.336] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.336] SETDATA devices.15.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:45.471] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.472] SENT ACK
[2014-04-17 08:06:45.473] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.473] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.506] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.507] SENT ACK
[2014-04-17 08:06:45.508] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.508] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.578] RECEIVED: ( 01 09 00 04 10 0F 03 25 03 00 C8 )
[2014-04-17 08:06:45.588] SENT ACK
[2014-04-17 08:06:45.589] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.589] SETDATA devices.15.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:45.613] RECEIVED: ( 01 09 00 04 00 11 03 25 03 FF 39 )
[2014-04-17 08:06:45.614] SENT ACK
[2014-04-17 08:06:45.614] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.614] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.670] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.671] SENT ACK
[2014-04-17 08:06:45.671] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.672] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.740] RECEIVED: ( 01 09 00 04 10 0F 03 25 03 00 C8 )
[2014-04-17 08:06:45.742] SENT ACK
[2014-04-17 08:06:45.742] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.742] SETDATA devices.15.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:45.818] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.819] SENT ACK
[2014-04-17 08:06:45.820] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.820] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:45.853] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:45.854] SENT ACK
[2014-04-17 08:06:45.855] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:45.855] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.012] RECEIVED: ( 01 09 00 04 10 0F 03 25 03 00 C8 )
[2014-04-17 08:06:46.013] SENT ACK
[2014-04-17 08:06:46.013] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.014] SETDATA devices.15.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:06:46.295] RECEIVED: ( 01 09 00 04 10 0C 03 25 03 FF 34 )
[2014-04-17 08:06:46.296] SENT ACK
[2014-04-17 08:06:46.296] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.297] SETDATA devices.12.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.580] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:46.581] SENT ACK
[2014-04-17 08:06:46.581] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.581] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.740] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:46.740] SENT ACK
[2014-04-17 08:06:46.741] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.741] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.763] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:46.764] SENT ACK
[2014-04-17 08:06:46.765] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.765] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.808] RECEIVED: ( 01 09 00 04 10 10 03 25 03 FF 28 )
[2014-04-17 08:06:46.810] SENT ACK
[2014-04-17 08:06:46.810] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.810] SETDATA devices.16.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.844] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:46.845] SENT ACK
[2014-04-17 08:06:46.845] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.845] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.934] RECEIVED: ( 01 09 00 04 10 10 03 25 03 FF 28 )
[2014-04-17 08:06:46.935] SENT ACK
[2014-04-17 08:06:46.936] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.936] SETDATA devices.16.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:46.970] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:46.971] SENT ACK
[2014-04-17 08:06:46.971] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:46.972] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:47.095] RECEIVED: ( 01 09 00 04 10 10 03 25 03 FF 28 )
[2014-04-17 08:06:47.096] SENT ACK
[2014-04-17 08:06:47.097] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:47.097] SETDATA devices.16.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:47.232] RECEIVED: ( 01 09 00 04 10 10 03 25 03 FF 28 )
[2014-04-17 08:06:47.233] SENT ACK
[2014-04-17 08:06:47.233] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:47.234] SETDATA devices.16.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:47.269] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:47.269] SENT ACK
[2014-04-17 08:06:47.269] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:47.270] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:47.281] Job 0x13: deleted from queue
[2014-04-17 08:06:47.294] Job 0x62: deleted from queue
[2014-04-17 08:06:47.305] Job 0x13: deleted from queue
[2014-04-17 08:06:47.317] Job 0x13: deleted from queue
[2014-04-17 08:06:47.329] Job 0x13: deleted from queue
[2014-04-17 08:06:47.341] Job 0x13: deleted from queue
[2014-04-17 08:06:47.353] Job 0x13: deleted from queue
[2014-04-17 08:06:47.388] Job 0x13: deleted from queue
[2014-04-17 08:06:47.400] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:47.401] SENT ACK
[2014-04-17 08:06:47.401] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:47.401] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:47.413] Job 0x13: deleted from queue
[2014-04-17 08:06:47.548] RECEIVED: ( 01 09 00 04 10 11 03 25 03 FF 29 )
[2014-04-17 08:06:47.549] SENT ACK
[2014-04-17 08:06:47.549] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:47.550] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:49.810] RECEIVED: ( 01 05 00 13 F9 01 11 )
[2014-04-17 08:06:49.810] SENT ACK
[2014-04-17 08:06:49.810] Job 0x13 (SwitchBinary Get): Not delivered to recipient
[2014-04-17 08:06:49.811] SETDATA devices.17.data.lastPacketInfo.delivered = False
[2014-04-17 08:06:49.811] SETDATA devices.17.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:49.811] SETDATA devices.17.data.lastPacketInfo.deliveryTime = 5986 (0x00001762)
[2014-04-17 08:06:49.811] SETDATA devices.17.data.lastPacketInfo = **********
[2014-04-17 08:06:49.823] SENDING (cb 0xfa): ( 01 09 00 13 11 02 25 02 25 FA 0E )
[2014-04-17 08:06:49.834] RECEIVED ACK
[2014-04-17 08:06:49.845] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:49.845] SENT ACK
[2014-04-17 08:06:49.845] Delivered to Z-Wave stack
[2014-04-17 08:06:50.325] RECEIVED: ( 01 05 00 13 FA 00 13 )
[2014-04-17 08:06:50.325] SENT ACK
[2014-04-17 08:06:50.326] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:06:50.326] SETDATA devices.17.data.lastPacketInfo.delivered = True
[2014-04-17 08:06:50.326] SETDATA devices.17.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:06:50.326] SETDATA devices.17.data.lastPacketInfo.deliveryTime = 481 (0x000001e1)
[2014-04-17 08:06:50.327] SETDATA devices.17.data.lastPacketInfo = **********
[2014-04-17 08:06:50.327] SendData Response with callback 0xfa received: received by recipient
[2014-04-17 08:06:50.327] SETDATA devices.17.data.lastSend = 21818647 (0x014ced17)
[2014-04-17 08:06:50.327] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:06:50.327] Removing job: SwitchBinary Get
[2014-04-17 08:06:50.379] Job 0x13: deleted from queue
[2014-04-17 08:06:50.481] RECEIVED: ( 01 09 00 04 00 11 03 25 03 FF 39 )
[2014-04-17 08:06:50.482] SENT ACK
[2014-04-17 08:06:50.482] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:50.482] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:50.640] RECEIVED: ( 01 09 00 04 00 11 03 25 03 FF 39 )
[2014-04-17 08:06:50.641] SENT ACK
[2014-04-17 08:06:50.641] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:50.642] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:50.868] RECEIVED: ( 01 09 00 04 00 11 03 25 03 FF 39 )
[2014-04-17 08:06:50.869] SENT ACK
[2014-04-17 08:06:50.870] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:06:50.870] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:06:54.738] SENDING (cb 0xfb): ( 01 0D 00 13 03 06 60 0D 01 03 26 02 25 FB 71 )
[2014-04-17 08:06:54.749] RECEIVED ACK
[2014-04-17 08:06:54.761] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:06:54.762] SENT ACK
[2014-04-17 08:06:54.763] Delivered to Z-Wave stack
sdh
Post by sdh »
Log Part 2:
[2014-04-17 08:07:00.262] RECEIVED: ( 01 05 00 13 FB 01 13 )
[2014-04-17 08:07:00.263] SENT ACK
[2014-04-17 08:07:00.263] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:07:00.263] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:07:00.264] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:07:00.264] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5501 (0x0000157d)
[2014-04-17 08:07:00.264] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:07:00.276] SENDING (cb 0xfc): ( 01 0D 00 13 03 06 60 0D 01 03 26 02 25 FC 76 )
[2014-04-17 08:07:00.287] RECEIVED ACK
[2014-04-17 08:07:00.297] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:00.298] SENT ACK
[2014-04-17 08:07:00.298] Delivered to Z-Wave stack
[2014-04-17 08:07:03.274] Job 0x13: deleted from queue
[2014-04-17 08:07:03.366] Job 0x13: deleted from queue
[2014-04-17 08:07:03.378] Job 0x13: deleted from queue
[2014-04-17 08:07:03.392] Job 0x13: deleted from queue
[2014-04-17 08:07:03.586] Job 0x13: deleted from queue
[2014-04-17 08:07:03.852] Job 0x13: deleted from queue
[2014-04-17 08:07:05.986] RECEIVED: ( 01 05 00 13 FC 01 14 )
[2014-04-17 08:07:05.992] SENT ACK
[2014-04-17 08:07:05.992] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:07:05.993] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:07:05.993] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:07:05.993] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5694 (0x0000163e)
[2014-04-17 08:07:05.993] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:07:06.005] SENDING (cb 0xfd): ( 01 0D 00 13 03 06 60 0D 01 03 26 02 25 FD 77 )
[2014-04-17 08:07:06.017] RECEIVED ACK
[2014-04-17 08:07:06.029] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:06.030] SENT ACK
[2014-04-17 08:07:06.030] Delivered to Z-Wave stack
[2014-04-17 08:07:08.617] Executing script: zway.devices[10].instances[0].commandClasses[0x25].Set(255)
[2014-04-17 08:07:08.620] Adding job: SwitchBinary Set
[2014-04-17 08:07:08.620] Adding job: SwitchBinary Get
[2014-04-17 08:07:09.762] Job 0x13: deleted from queue
[2014-04-17 08:07:11.583] RECEIVED: ( 01 05 00 13 FD 01 15 )
[2014-04-17 08:07:11.584] SENT ACK
[2014-04-17 08:07:11.585] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:07:11.585] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:07:11.586] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:07:11.586] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5554 (0x000015b2)
[2014-04-17 08:07:11.586] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:07:11.586] Job 0x13 (MultiChannel encapsulation): Removing job due to too much retransmitions
[2014-04-17 08:07:11.587] SETDATA devices.3.data.failureCount = 3 (0x00000003)
[2014-04-17 08:07:11.587] SETDATA devices.3.data.lastSend = 21826493 (0x014d0bbd)
[2014-04-17 08:07:11.587] Job 0x13 (MultiChannel encapsulation): fail
[2014-04-17 08:07:11.587] Removing job: MultiChannel encapsulation
[2014-04-17 08:07:11.599] SENDING (cb 0xfe): ( 01 0A 00 13 0A 03 25 01 FF 25 FE EF )
[2014-04-17 08:07:11.610] RECEIVED ACK
[2014-04-17 08:07:11.622] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:11.623] SENT ACK
[2014-04-17 08:07:11.623] Delivered to Z-Wave stack
[2014-04-17 08:07:11.883] RECEIVED: ( 01 05 00 13 FE 00 17 )
[2014-04-17 08:07:11.884] SENT ACK
[2014-04-17 08:07:11.884] Job 0x13 (SwitchBinary Set): Delivered
[2014-04-17 08:07:11.885] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2014-04-17 08:07:11.885] SETDATA devices.10.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-04-17 08:07:11.885] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 260 (0x00000104)
[2014-04-17 08:07:11.885] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:07:11.885] SendData Response with callback 0xfe received: received by recipient
[2014-04-17 08:07:11.886] SETDATA devices.10.data.lastSend = 21820519 (0x014cf467)
[2014-04-17 08:07:11.886] Job 0x13 (SwitchBinary Set): success
[2014-04-17 08:07:11.886] Removing job: SwitchBinary Set
[2014-04-17 08:07:11.959] SENDING (cb 0x01): ( 01 09 00 13 0A 02 25 02 25 01 EE )
[2014-04-17 08:07:11.971] RECEIVED ACK
[2014-04-17 08:07:11.982] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:11.983] SENT ACK
[2014-04-17 08:07:11.983] Delivered to Z-Wave stack
[2014-04-17 08:07:12.408] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:12.409] SENT ACK
[2014-04-17 08:07:12.409] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:12.410] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:12.720] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:12.720] SENT ACK
[2014-04-17 08:07:12.720] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:12.721] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:12.858] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:12.858] SENT ACK
[2014-04-17 08:07:12.860] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:12.860] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:12.882] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:12.882] SENT ACK
[2014-04-17 08:07:12.882] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:12.883] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:12.962] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:12.962] SENT ACK
[2014-04-17 08:07:12.963] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:12.963] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:12.996] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:12.997] SENT ACK
[2014-04-17 08:07:12.997] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:12.997] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:13.527] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:13.528] SENT ACK
[2014-04-17 08:07:13.529] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:13.529] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:13.633] RECEIVED: ( 01 09 00 04 00 0A 03 25 01 FF 20 )
[2014-04-17 08:07:13.634] SENT ACK
[2014-04-17 08:07:13.634] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:13.634] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:13.773] RECEIVED: ( 01 05 00 13 01 01 E9 )
[2014-04-17 08:07:13.775] SENT ACK
[2014-04-17 08:07:13.775] Job 0x13 (SwitchBinary Get): Not delivered to recipient
[2014-04-17 08:07:13.775] SETDATA devices.10.data.lastPacketInfo.delivered = False
[2014-04-17 08:07:13.776] SETDATA devices.10.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:07:13.776] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 1792 (0x00000700)
[2014-04-17 08:07:13.776] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:07:13.788] SENDING (cb 0x02): ( 01 09 00 13 0A 02 25 02 25 02 ED )
[2014-04-17 08:07:13.804] RECEIVED ACK
[2014-04-17 08:07:13.816] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:13.817] SENT ACK
[2014-04-17 08:07:13.817] Delivered to Z-Wave stack
[2014-04-17 08:07:13.974] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:13.976] SENT ACK
[2014-04-17 08:07:13.976] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:13.977] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.021] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 FF 30 )
[2014-04-17 08:07:14.022] SENT ACK
[2014-04-17 08:07:14.022] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.022] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:14.359] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 FF 30 )
[2014-04-17 08:07:14.360] SENT ACK
[2014-04-17 08:07:14.361] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.361] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:14.394] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 FF 30 )
[2014-04-17 08:07:14.395] SENT ACK
[2014-04-17 08:07:14.396] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.396] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:14.417] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 FF 30 )
[2014-04-17 08:07:14.418] SENT ACK
[2014-04-17 08:07:14.418] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.419] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:14.452] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:14.453] SENT ACK
[2014-04-17 08:07:14.453] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:14.453] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.602] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:14.603] SENT ACK
[2014-04-17 08:07:14.603] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.603] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:14.682] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:14.683] SENT ACK
[2014-04-17 08:07:14.683] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.684] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:14.728] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:14.729] SENT ACK
[2014-04-17 08:07:14.730] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.730] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:14.832] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 FF 30 )
[2014-04-17 08:07:14.833] SENT ACK
[2014-04-17 08:07:14.833] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:14.834] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:15.035] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.036] SENT ACK
[2014-04-17 08:07:15.037] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.037] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.150] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 FF 30 )
[2014-04-17 08:07:15.150] SENT ACK
[2014-04-17 08:07:15.151] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.151] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:15.240] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.242] SENT ACK
[2014-04-17 08:07:15.242] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.242] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.320] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.321] SENT ACK
[2014-04-17 08:07:15.321] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.322] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.355] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.356] SENT ACK
[2014-04-17 08:07:15.356] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.357] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.390] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.391] SENT ACK
[2014-04-17 08:07:15.392] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.392] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.448] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.449] SENT ACK
[2014-04-17 08:07:15.449] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.449] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.471] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.472] SENT ACK
[2014-04-17 08:07:15.473] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.473] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.719] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.719] SENT ACK
[2014-04-17 08:07:15.719] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.720] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.730] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:15.732] SENT ACK
[2014-04-17 08:07:15.732] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.733] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.819] RECEIVED: ( 01 09 00 04 10 0A 03 25 03 FF 32 )
[2014-04-17 08:07:15.820] SENT ACK
[2014-04-17 08:07:15.820] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:15.821] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:15.899] RECEIVED: ( 01 05 00 13 02 01 EA )
[2014-04-17 08:07:15.900] SENT ACK
[2014-04-17 08:07:15.901] Job 0x13 (SwitchBinary Get): Not delivered to recipient
[2014-04-17 08:07:15.901] SETDATA devices.10.data.lastPacketInfo.delivered = False
[2014-04-17 08:07:15.901] SETDATA devices.10.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:07:15.901] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 2083 (0x00000823)
[2014-04-17 08:07:15.902] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:07:15.913] SENDING (cb 0x03): ( 01 09 00 13 0A 02 25 02 25 03 EC )
[2014-04-17 08:07:15.925] RECEIVED ACK
[2014-04-17 08:07:15.936] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:15.937] SENT ACK
[2014-04-17 08:07:15.938] Delivered to Z-Wave stack
[2014-04-17 08:07:16.039] RECEIVED: ( 01 05 00 13 03 00 EA )
[2014-04-17 08:07:16.040] SENT ACK
[2014-04-17 08:07:16.040] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:07:16.041] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2014-04-17 08:07:16.041] SETDATA devices.10.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:07:16.041] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 103 (0x00000067)
[2014-04-17 08:07:16.041] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:07:16.042] SendData Response with callback 0x03 received: received by recipient
[2014-04-17 08:07:16.042] SETDATA devices.10.data.lastSend = 21820874 (0x014cf5ca)
[2014-04-17 08:07:16.042] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:07:16.042] Removing job: SwitchBinary Get
[2014-04-17 08:07:16.064] RECEIVED: ( 01 09 00 04 10 0A 03 25 03 FF 32 )
[2014-04-17 08:07:16.065] SENT ACK
[2014-04-17 08:07:16.066] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.066] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.190] RECEIVED: ( 01 09 00 04 10 0A 03 25 03 FF 32 )
[2014-04-17 08:07:16.191] SENT ACK
[2014-04-17 08:07:16.192] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.192] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.240] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:16.245] SENT ACK
[2014-04-17 08:07:16.245] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.245] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.266] RECEIVED: ( 01 09 00 04 10 0A 03 25 03 FF 32 )
[2014-04-17 08:07:16.267] SENT ACK
[2014-04-17 08:07:16.268] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.268] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.392] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:16.393] SENT ACK
[2014-04-17 08:07:16.394] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.394] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.529] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:16.530] SENT ACK
[2014-04-17 08:07:16.530] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.531] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.769] RECEIVED: ( 01 09 00 04 10 0A 03 25 03 FF 32 )
[2014-04-17 08:07:16.770] SENT ACK
[2014-04-17 08:07:16.770] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.771] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:16.827] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:16.829] SENT ACK
[2014-04-17 08:07:16.829] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:16.829] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:17.022] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:17.023] SENT ACK
[2014-04-17 08:07:17.023] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.023] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:17.045] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 FF 22 )
[2014-04-17 08:07:17.046] SENT ACK
[2014-04-17 08:07:17.046] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.047] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:17.080] RECEIVED: ( 01 09 00 04 10 0A 03 25 03 FF 32 )
[2014-04-17 08:07:17.081] SENT ACK
[2014-04-17 08:07:17.081] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.082] SETDATA devices.10.instances.0.commandClasses.37.data.level = True
[2014-04-17 08:07:17.172] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.173] SENT ACK
[2014-04-17 08:07:17.174] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.174] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.175] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.177] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.177] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.179] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.179] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.191] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.192] SENT ACK
[2014-04-17 08:07:17.192] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.192] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.193] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.194] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.194] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.196] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.196] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.296] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.296] SENT ACK
[2014-04-17 08:07:17.297] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.297] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.297] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.299] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.299] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.301] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.301] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.470] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.471] SENT ACK
[2014-04-17 08:07:17.472] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.472] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.472] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.474] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.475] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.476] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.477] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.669] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.670] SENT ACK
[2014-04-17 08:07:17.670] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.671] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.671] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.672] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.673] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.675] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.675] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.820] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.821] SENT ACK
[2014-04-17 08:07:17.822] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.822] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.822] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.827] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.828] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.830] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.830] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.870] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.871] SENT ACK
[2014-04-17 08:07:17.871] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.871] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.872] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.873] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.873] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.875] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.875] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:17.944] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:17.945] SENT ACK
[2014-04-17 08:07:17.945] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:17.946] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:17.946] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:17.948] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:17.948] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:17.950] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:17.951] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.040] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E C4 A1 E9 )
[2014-04-17 08:07:18.041] SENT ACK
[2014-04-17 08:07:18.042] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.042] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.043] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.044] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.044] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.046] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.047] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.172] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E C4 A1 F9 )
[2014-04-17 08:07:18.173] SENT ACK
[2014-04-17 08:07:18.173] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.174] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.174] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.176] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.176] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.177] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.178] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.223] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E C4 A1 F9 )
[2014-04-17 08:07:18.224] SENT ACK
[2014-04-17 08:07:18.225] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.225] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.225] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.227] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.227] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.229] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.229] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.262] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E C4 A1 F9 )
[2014-04-17 08:07:18.263] SENT ACK
[2014-04-17 08:07:18.264] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.264] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.264] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.265] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.266] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.268] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.269] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.369] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E C4 A1 F9 )
[2014-04-17 08:07:18.370] SENT ACK
[2014-04-17 08:07:18.371] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.371] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.371] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.373] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.374] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.375] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.376] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.414] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E C4 A1 F9 )
[2014-04-17 08:07:18.415] SENT ACK
[2014-04-17 08:07:18.416] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.416] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.416] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.417] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.418] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.420] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.421] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:18.579] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E C4 A1 F9 )
[2014-04-17 08:07:18.580] SENT ACK
[2014-04-17 08:07:18.580] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:18.580] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2016.416992
[2014-04-17 08:07:18.581] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:18.583] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:18.583] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:18.585] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:18.585] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:19.998] Executing script: zway.devices[10].instances[0].commandClasses[0x25].Set(0)
[2014-04-17 08:07:20.000] Adding job: SwitchBinary Set
[2014-04-17 08:07:20.001] Adding job: SwitchBinary Get
[2014-04-17 08:07:20.009] SENDING (cb 0x04): ( 01 0A 00 13 0A 03 25 01 00 25 04 EA )
[2014-04-17 08:07:20.021] RECEIVED ACK
[2014-04-17 08:07:20.033] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:20.034] SENT ACK
[2014-04-17 08:07:20.034] Delivered to Z-Wave stack
[2014-04-17 08:07:20.550] RECEIVED: ( 01 05 00 13 04 00 ED )
[2014-04-17 08:07:20.550] SENT ACK
[2014-04-17 08:07:20.551] Job 0x13 (SwitchBinary Set): Delivered
[2014-04-17 08:07:20.551] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2014-04-17 08:07:20.551] SETDATA devices.10.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-04-17 08:07:20.552] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 517 (0x00000205)
[2014-04-17 08:07:20.552] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:07:20.552] SendData Response with callback 0x04 received: received by recipient
[2014-04-17 08:07:20.552] SETDATA devices.10.data.lastSend = 21821251 (0x014cf743)
[2014-04-17 08:07:20.553] Job 0x13 (SwitchBinary Set): success
[2014-04-17 08:07:20.553] Removing job: SwitchBinary Set
[2014-04-17 08:07:20.598] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:20.599] SENT ACK
[2014-04-17 08:07:20.599] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:20.599] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:20.634] SENDING (cb 0x05): ( 01 09 00 13 0A 02 25 02 25 05 EA )
[2014-04-17 08:07:20.645] RECEIVED ACK
[2014-04-17 08:07:20.657] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:07:20.658] SENT ACK
[2014-04-17 08:07:20.658] Delivered to Z-Wave stack
[2014-04-17 08:07:20.849] RECEIVED: ( 01 0C 00 04 00 06 06 31 05 04 22 07 AD 4F )
[2014-04-17 08:07:20.850] SENT ACK
[2014-04-17 08:07:20.851] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:20.851] SETDATA devices.6.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2014-04-17 08:07:20.851] SETDATA devices.6.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2014-04-17 08:07:20.852] SETDATA devices.6.instances.0.commandClasses.49.data.4.val = 196.500000
[2014-04-17 08:07:20.855] SETDATA devices.6.instances.0.commandClasses.49.data.4.scaleString = "W"
[2014-04-17 08:07:20.855] SETDATA devices.6.instances.0.commandClasses.49.data.4 = Empty
[2014-04-17 08:07:21.186] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.187] SENT ACK
[2014-04-17 08:07:21.187] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.188] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.225] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.226] SENT ACK
[2014-04-17 08:07:21.227] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.227] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.272] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.272] SENT ACK
[2014-04-17 08:07:21.273] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.273] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.295] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 00 CF )
[2014-04-17 08:07:21.296] SENT ACK
[2014-04-17 08:07:21.297] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.297] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:21.329] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.330] SENT ACK
[2014-04-17 08:07:21.330] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.331] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.409] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.411] SENT ACK
[2014-04-17 08:07:21.411] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.411] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.422] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 00 CF )
[2014-04-17 08:07:21.423] SENT ACK
[2014-04-17 08:07:21.423] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.424] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:21.457] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 00 CF )
[2014-04-17 08:07:21.458] SENT ACK
[2014-04-17 08:07:21.458] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.458] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:21.503] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.504] SENT ACK
[2014-04-17 08:07:21.505] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.505] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.538] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 00 CF )
[2014-04-17 08:07:21.539] SENT ACK
[2014-04-17 08:07:21.540] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.540] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:21.573] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.574] SENT ACK
[2014-04-17 08:07:21.574] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.574] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.807] RECEIVED: ( 01 09 00 04 10 0A 03 25 01 00 CF )
[2014-04-17 08:07:21.813] SENT ACK
[2014-04-17 08:07:21.814] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.814] Received a command to Command Class 0x25 of controller, but it isn't registered
[2014-04-17 08:07:21.881] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.882] SENT ACK
[2014-04-17 08:07:21.882] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.883] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.961] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:21.962] SENT ACK
[2014-04-17 08:07:21.962] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.963] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:21.985] RECEIVED: ( 01 0C 00 04 00 06 06 31 05 04 22 03 E3 05 )
[2014-04-17 08:07:21.986] SENT ACK
[2014-04-17 08:07:21.986] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:21.986] SETDATA devices.6.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2014-04-17 08:07:21.987] SETDATA devices.6.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2014-04-17 08:07:21.987] SETDATA devices.6.instances.0.commandClasses.49.data.4.val = 99.500000
[2014-04-17 08:07:21.989] SETDATA devices.6.instances.0.commandClasses.49.data.4.scaleString = "W"
[2014-04-17 08:07:21.990] SETDATA devices.6.instances.0.commandClasses.49.data.4 = Empty
[2014-04-17 08:07:22.113] RECEIVED: ( 01 05 00 13 05 00 EC )
[2014-04-17 08:07:22.114] SENT ACK
[2014-04-17 08:07:22.115] Job 0x13 (SwitchBinary Get): Delivered
[2014-04-17 08:07:22.115] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2014-04-17 08:07:22.116] SETDATA devices.10.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-04-17 08:07:22.116] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 1457 (0x000005b1)
[2014-04-17 08:07:22.116] SETDATA devices.10.data.lastPacketInfo = **********
[2014-04-17 08:07:22.116] SendData Response with callback 0x05 received: received by recipient
[2014-04-17 08:07:22.117] SETDATA devices.10.data.lastSend = 21821382 (0x014cf7c6)
[2014-04-17 08:07:22.117] Job 0x13 (SwitchBinary Get): success
[2014-04-17 08:07:22.117] Removing job: SwitchBinary Get
[2014-04-17 08:07:22.317] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:22.318] SENT ACK
[2014-04-17 08:07:22.318] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:22.319] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:22.352] RECEIVED: ( 01 09 00 04 00 0A 03 25 03 00 DD )
[2014-04-17 08:07:22.353] SENT ACK
[2014-04-17 08:07:22.353] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:22.354] SETDATA devices.10.instances.0.commandClasses.37.data.level = False
[2014-04-17 08:07:23.341] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 00 00 00 92 )
[2014-04-17 08:07:23.346] SENT ACK
[2014-04-17 08:07:23.346] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:23.347] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 0.000000
[2014-04-17 08:07:23.347] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:23.348] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:23.349] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:23.354] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:23.359] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:30.826] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:30.827] SENT ACK
[2014-04-17 08:07:30.827] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:30.828] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:30.997] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:30.998] SENT ACK
[2014-04-17 08:07:30.999] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:30.999] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.123] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.123] SENT ACK
[2014-04-17 08:07:31.124] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.124] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.172] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.173] SENT ACK
[2014-04-17 08:07:31.174] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.174] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.343] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.344] SENT ACK
[2014-04-17 08:07:31.345] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.345] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.424] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.425] SENT ACK
[2014-04-17 08:07:31.425] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.425] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.526] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.527] SENT ACK
[2014-04-17 08:07:31.528] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.528] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.652] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.653] SENT ACK
[2014-04-17 08:07:31.654] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.654] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.675] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:07:31.676] SENT ACK
[2014-04-17 08:07:31.677] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.677] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.760] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:31.761] SENT ACK
[2014-04-17 08:07:31.761] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.761] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:31.811] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:31.812] SENT ACK
[2014-04-17 08:07:31.812] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:31.813] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:32.016] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:32.017] SENT ACK
[2014-04-17 08:07:32.017] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:32.018] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:32.163] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:32.164] SENT ACK
[2014-04-17 08:07:32.165] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:32.165] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:32.188] RECEIVED: ( 01 08 00 04 10 0A 02 82 01 68 )
[2014-04-17 08:07:32.189] SENT ACK
[2014-04-17 08:07:32.189] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:07:32.190] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:32.473] Job 0x13: deleted from queue
[2014-04-17 08:07:32.745] Job 0x13: deleted from queue
[2014-04-17 08:07:35.730] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:35.735] SENT ACK
[2014-04-17 08:07:35.735] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:35.736] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:35.736] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:35.738] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:35.739] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:35.740] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:35.740] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:35.951] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:35.953] SENT ACK
[2014-04-17 08:07:35.953] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:35.954] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:35.954] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:35.955] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:35.955] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:35.957] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:35.957] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.126] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:36.127] SENT ACK
[2014-04-17 08:07:36.127] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.128] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.129] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.130] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.130] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.132] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.132] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.291] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:36.292] SENT ACK
[2014-04-17 08:07:36.292] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.293] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.293] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.295] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.295] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.297] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.297] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.438] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:36.439] SENT ACK
[2014-04-17 08:07:36.440] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.440] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.441] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.442] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.442] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.444] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.445] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.525] Job 0x13: deleted from queue
[2014-04-17 08:07:36.537] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:36.538] SENT ACK
[2014-04-17 08:07:36.538] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.539] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.539] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.540] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.541] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.542] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.543] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.598] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 1E A9 83 A6 )
[2014-04-17 08:07:36.599] SENT ACK
[2014-04-17 08:07:36.600] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.600] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.601] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.602] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.603] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.604] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.605] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.762] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E A9 83 B6 )
[2014-04-17 08:07:36.763] SENT ACK
[2014-04-17 08:07:36.763] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.764] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.764] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.766] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.767] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.769] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.769] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.781] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E A9 83 B6 )
[2014-04-17 08:07:36.782] SENT ACK
[2014-04-17 08:07:36.783] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.783] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.784] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.785] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.785] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.787] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.787] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.927] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E A9 83 B6 )
[2014-04-17 08:07:36.927] SENT ACK
[2014-04-17 08:07:36.928] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.929] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.929] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.930] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.931] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.932] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.932] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:36.966] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E A9 83 B6 )
[2014-04-17 08:07:36.967] SENT ACK
[2014-04-17 08:07:36.967] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:36.967] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:36.968] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:36.969] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:36.970] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:36.972] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:36.972] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:37.051] RECEIVED: ( 01 0E 00 04 10 0A 08 32 02 21 74 00 1E A9 83 B6 )
[2014-04-17 08:07:37.052] SENT ACK
[2014-04-17 08:07:37.053] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:37.053] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 2009.474976
[2014-04-17 08:07:37.054] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:07:37.055] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:07:37.056] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:07:37.057] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:07:37.058] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:07:40.686] Job 0x13: deleted from queue
[2014-04-17 08:07:41.963] Job 0x13: deleted from queue
[2014-04-17 08:07:46.675] RECEIVED: ( 01 0C 00 04 00 07 06 31 05 04 22 01 9F 7A )
[2014-04-17 08:07:46.676] SENT ACK
[2014-04-17 08:07:46.677] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:07:46.677] SETDATA devices.7.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2014-04-17 08:07:46.677] SETDATA devices.7.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2014-04-17 08:07:46.678] SETDATA devices.7.instances.0.commandClasses.49.data.4.val = 41.500000
[2014-04-17 08:07:46.680] SETDATA devices.7.instances.0.commandClasses.49.data.4.scaleString = "W"
[2014-04-17 08:07:46.681] SETDATA devices.7.instances.0.commandClasses.49.data.4 = Empty
[2014-04-17 08:08:09.721] RECEIVED: ( 01 08 00 04 00 0A 02 82 01 78 )
[2014-04-17 08:08:09.722] SENT ACK
[2014-04-17 08:08:09.723] Got frame from device 10 to controller, but command class 0x82 is not implemented
[2014-04-17 08:08:09.723] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:11.348] RECEIVED: ( 01 0E 00 04 00 0A 08 32 02 21 74 00 00 00 00 92 )
[2014-04-17 08:08:11.349] SENT ACK
[2014-04-17 08:08:11.349] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:11.349] SETDATA devices.10.instances.0.commandClasses.50.data.2.val = 0.000000
[2014-04-17 08:08:11.350] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:08:11.351] SETDATA devices.10.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:08:11.351] SETDATA devices.10.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:08:11.353] SETDATA devices.10.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:08:11.353] SETDATA devices.10.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:08:19.686] RECEIVED: ( 01 0C 00 04 00 07 06 31 05 04 22 00 F0 14 )
[2014-04-17 08:08:19.687] SENT ACK
[2014-04-17 08:08:19.687] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:19.687] SETDATA devices.7.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2014-04-17 08:08:19.687] SETDATA devices.7.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2014-04-17 08:08:19.688] SETDATA devices.7.instances.0.commandClasses.49.data.4.val = 24.000000
[2014-04-17 08:08:19.690] SETDATA devices.7.instances.0.commandClasses.49.data.4.scaleString = "W"
[2014-04-17 08:08:19.690] SETDATA devices.7.instances.0.commandClasses.49.data.4 = Empty
[2014-04-17 08:08:20.680] RECEIVED: ( 01 0C 00 04 00 07 06 31 05 04 22 01 72 97 )
[2014-04-17 08:08:20.681] SENT ACK
[2014-04-17 08:08:20.682] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:20.682] SETDATA devices.7.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2014-04-17 08:08:20.682] SETDATA devices.7.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2014-04-17 08:08:20.682] SETDATA devices.7.instances.0.commandClasses.49.data.4.val = 37.000000
[2014-04-17 08:08:20.685] SETDATA devices.7.instances.0.commandClasses.49.data.4.scaleString = "W"
[2014-04-17 08:08:20.685] SETDATA devices.7.instances.0.commandClasses.49.data.4 = Empty
sdh
Re: UI not updating when wall switch operated
Post by sdh »
Log Part 3:
[2014-04-17 08:08:21.209] SENDING (cb 0x06): ( 01 0D 00 13 03 06 60 0D 01 04 26 02 25 06 8B )
[2014-04-17 08:08:21.221] RECEIVED ACK
[2014-04-17 08:08:21.233] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:08:21.234] SENT ACK
[2014-04-17 08:08:21.234] Delivered to Z-Wave stack
[2014-04-17 08:08:27.009] RECEIVED: ( 01 05 00 13 06 01 EE )
[2014-04-17 08:08:27.010] SENT ACK
[2014-04-17 08:08:27.010] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:08:27.011] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:08:27.011] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:08:27.011] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5777 (0x00001691)
[2014-04-17 08:08:27.011] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:08:27.023] SENDING (cb 0x07): ( 01 0D 00 13 03 06 60 0D 01 04 26 02 25 07 8A )
[2014-04-17 08:08:27.034] RECEIVED ACK
[2014-04-17 08:08:27.045] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:08:27.045] SENT ACK
[2014-04-17 08:08:27.046] Delivered to Z-Wave stack
[2014-04-17 08:08:32.609] RECEIVED: ( 01 05 00 13 07 01 EF )
[2014-04-17 08:08:32.610] SENT ACK
[2014-04-17 08:08:32.610] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:08:32.610] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:08:32.611] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:08:32.611] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5564 (0x000015bc)
[2014-04-17 08:08:32.611] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:08:32.623] SENDING (cb 0x08): ( 01 0D 00 13 03 06 60 0D 01 04 26 02 25 08 85 )
[2014-04-17 08:08:32.634] RECEIVED ACK
[2014-04-17 08:08:32.646] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-04-17 08:08:32.647] SENT ACK
[2014-04-17 08:08:32.647] Delivered to Z-Wave stack
[2014-04-17 08:08:38.184] RECEIVED: ( 01 05 00 13 08 01 E0 )
[2014-04-17 08:08:38.185] SENT ACK
[2014-04-17 08:08:38.185] Job 0x13 (MultiChannel encapsulation): Not delivered to recipient
[2014-04-17 08:08:38.185] SETDATA devices.3.data.lastPacketInfo.delivered = False
[2014-04-17 08:08:38.185] SETDATA devices.3.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2014-04-17 08:08:38.186] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 5538 (0x000015a2)
[2014-04-17 08:08:38.186] SETDATA devices.3.data.lastPacketInfo = **********
[2014-04-17 08:08:38.186] Job 0x13 (MultiChannel encapsulation): Removing job due to too much retransmitions
[2014-04-17 08:08:38.187] SETDATA devices.3.data.failureCount = 4 (0x00000004)
[2014-04-17 08:08:38.187] SETDATA devices.3.data.lastSend = 22187975 (0x01528fc7)
[2014-04-17 08:08:38.187] Job 0x13 (MultiChannel encapsulation): fail
[2014-04-17 08:08:38.187] Removing job: MultiChannel encapsulation
[2014-04-17 08:08:47.761] RECEIVED: ( 01 0E 00 04 00 0B 08 32 02 21 74 00 01 8E 04 18 )
[2014-04-17 08:08:47.762] SENT ACK
[2014-04-17 08:08:47.762] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:47.762] SETDATA devices.11.instances.0.commandClasses.50.data.2.val = 101.891998
[2014-04-17 08:08:47.763] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:08:47.764] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:08:47.764] SETDATA devices.11.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:08:47.767] SETDATA devices.11.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:08:47.767] SETDATA devices.11.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:08:50.851] RECEIVED: ( 01 0E 00 04 00 0B 08 32 02 21 74 00 01 AB 69 50 )
[2014-04-17 08:08:50.851] SENT ACK
[2014-04-17 08:08:50.851] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:50.852] SETDATA devices.11.instances.0.commandClasses.50.data.2.val = 109.417000
[2014-04-17 08:08:50.852] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:08:50.854] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:08:50.855] SETDATA devices.11.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:08:50.856] SETDATA devices.11.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:08:50.857] SETDATA devices.11.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:08:51.259] RECEIVED: ( 01 0E 00 04 00 0B 08 32 02 21 74 00 01 AB 69 50 )
[2014-04-17 08:08:51.259] SENT ACK
[2014-04-17 08:08:51.260] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:51.260] SETDATA devices.11.instances.0.commandClasses.50.data.2.val = 109.417000
[2014-04-17 08:08:51.260] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:08:51.263] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:08:51.263] SETDATA devices.11.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:08:51.265] SETDATA devices.11.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:08:51.265] SETDATA devices.11.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:08:53.758] RECEIVED: ( 01 0E 00 04 00 0B 08 32 02 21 74 00 01 94 B2 B4 )
[2014-04-17 08:08:53.759] SENT ACK
[2014-04-17 08:08:53.759] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:53.759] SETDATA devices.11.instances.0.commandClasses.50.data.2.val = 103.601997
[2014-04-17 08:08:53.760] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorType = 1 (0x00000001)
[2014-04-17 08:08:53.761] SETDATA devices.11.instances.0.commandClasses.50.data.2.sensorTypeString = "Electric "
[2014-04-17 08:08:53.761] SETDATA devices.11.instances.0.commandClasses.50.data.2.scale = 2 (0x00000002)
[2014-04-17 08:08:53.763] SETDATA devices.11.instances.0.commandClasses.50.data.2.scaleString = "W"
[2014-04-17 08:08:53.763] SETDATA devices.11.instances.0.commandClasses.50.data.2 = Empty
[2014-04-17 08:08:57.539] Job 0x13: deleted from queue
[2014-04-17 08:08:57.740] RECEIVED: ( 01 09 00 04 00 02 03 20 01 FF 2D )
[2014-04-17 08:08:57.741] SENT ACK
[2014-04-17 08:08:57.741] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:08:57.742] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2014-04-17 08:08:57.742] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2014-04-17 08:08:57.742] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2014-04-17 08:08:57.742] SETDATA devices.2.instances.0.commandClasses.48.data.1.level = True
[2014-04-17 08:08:57.743] SETDATA devices.2.instances.0.commandClasses.48.data.1 = Empty
[2014-04-17 08:09:04.441] RECEIVED: ( 01 14 00 04 00 09 0E 32 02 21 64 00 05 19 B2 02 58 00 05 19 B2 C7 )
[2014-04-17 08:09:04.442] SENT ACK
[2014-04-17 08:09:04.442] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:04.443] SETDATA devices.9.instances.0.commandClasses.50.data.0.val = 334.257996
[2014-04-17 08:09:04.443] SETDATA devices.9.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:04.443] SETDATA devices.9.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:04.444] SETDATA devices.9.instances.0.commandClasses.50.data.0.previous = 334.257996
[2014-04-17 08:09:04.444] SETDATA devices.9.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:04.713] RECEIVED: ( 01 14 00 04 00 09 0E 32 02 21 64 00 05 19 B2 02 58 00 05 19 B2 C7 )
[2014-04-17 08:09:04.714] SENT ACK
[2014-04-17 08:09:04.714] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:04.714] SETDATA devices.9.instances.0.commandClasses.50.data.0.val = 334.257996
[2014-04-17 08:09:04.715] SETDATA devices.9.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:04.715] SETDATA devices.9.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:04.715] SETDATA devices.9.instances.0.commandClasses.50.data.0.previous = 334.257996
[2014-04-17 08:09:04.716] SETDATA devices.9.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:05.360] RECEIVED: ( 01 14 00 04 00 0A 0E 32 02 21 64 00 01 C3 06 02 58 00 01 C2 EC 2F )
[2014-04-17 08:09:05.367] SENT ACK
[2014-04-17 08:09:05.368] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:05.368] SETDATA devices.10.instances.0.commandClasses.50.data.0.val = 115.461998
[2014-04-17 08:09:05.369] SETDATA devices.10.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:05.369] SETDATA devices.10.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:05.369] SETDATA devices.10.instances.0.commandClasses.50.data.0.previous = 115.435997
[2014-04-17 08:09:05.370] SETDATA devices.10.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:05.448] RECEIVED: ( 01 14 00 04 00 0A 0E 32 02 21 64 00 01 C3 06 02 58 00 01 C2 EC 2F )
[2014-04-17 08:09:05.449] SENT ACK
[2014-04-17 08:09:05.450] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:05.450] SETDATA devices.10.instances.0.commandClasses.50.data.0.val = 115.461998
[2014-04-17 08:09:05.450] SETDATA devices.10.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:05.451] SETDATA devices.10.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:05.451] SETDATA devices.10.instances.0.commandClasses.50.data.0.previous = 115.435997
[2014-04-17 08:09:05.451] SETDATA devices.10.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:05.474] RECEIVED: ( 01 14 00 04 00 0E 0E 32 02 21 64 00 00 1A 57 02 58 00 00 1A 57 C0 )
[2014-04-17 08:09:05.475] SENT ACK
[2014-04-17 08:09:05.475] SETDATA devices.14.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:05.475] SETDATA devices.14.instances.0.commandClasses.50.data.0.val = 6.743000
[2014-04-17 08:09:05.476] SETDATA devices.14.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:05.476] SETDATA devices.14.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:05.476] SETDATA devices.14.instances.0.commandClasses.50.data.0.previous = 6.743000
[2014-04-17 08:09:05.477] SETDATA devices.14.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:05.544] RECEIVED: ( 01 14 00 04 00 0A 0E 32 02 21 64 00 01 C3 06 02 58 00 01 C2 EC 2F )
[2014-04-17 08:09:05.545] SENT ACK
[2014-04-17 08:09:05.545] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:05.546] SETDATA devices.10.instances.0.commandClasses.50.data.0.val = 115.461998
[2014-04-17 08:09:05.546] SETDATA devices.10.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:05.546] SETDATA devices.10.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:05.546] SETDATA devices.10.instances.0.commandClasses.50.data.0.previous = 115.435997
[2014-04-17 08:09:05.547] SETDATA devices.10.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:05.602] RECEIVED: ( 01 14 00 04 00 11 0E 32 02 21 64 00 00 10 CD 02 58 00 00 10 CC DE )
[2014-04-17 08:09:05.606] SENT ACK
[2014-04-17 08:09:05.606] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:05.606] SETDATA devices.17.instances.0.commandClasses.50.data.0.val = 4.301000
[2014-04-17 08:09:05.607] SETDATA devices.17.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:05.607] SETDATA devices.17.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2014-04-17 08:09:05.607] SETDATA devices.17.instances.0.commandClasses.50.data.0.previous = 4.300000
[2014-04-17 08:09:05.607] SETDATA devices.17.instances.0.commandClasses.50.data.0 = Empty
[2014-04-17 08:09:05.773] RECEIVED: ( 01 14 00 04 00 0B 0E 32 02 21 64 00 02 2B 6F 02 58 00 02 2B 5D F7 )
[2014-04-17 08:09:05.774] SENT ACK
[2014-04-17 08:09:05.774] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2014-04-17 08:09:05.774] SETDATA devices.11.instances.0.commandClasses.50.data.0.val = 142.190994
[2014-04-17 08:09:05.775] SETDATA devices.11.instances.0.commandClasses.50.data.0.delta = 598 (0x00000256)
[2014-04-17 08:09:05.775] SETDATA devices.11.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
I'm not sure it is a good idea to post tons of logs on the forum. Hard to read, will not help other users, impossible to analyse with text tools like grep and awk.
Anyway, your log contains a lot of duplicate packets and this is very strange. Is it same with other devices? If not, may be yours is broken and it is not worth to dig more into it?
sdh
Post by sdh »
Sorry about that, was not sure how to post the log. I saw others pasting the log, so did the same. Will take care next time.
What duplicate data are you referring. What I saw is that it said Hail command in not supported from the logs. Can that be the reason for UI not updating. Devices 9 to 17 are Aeon MSES G2, 4 to 8 are Fibaro Wall Plugs, 3 Is Fibaro RGBW controller and 2 is Aeon 4in1 multi sensor. Are you seeing duplicate data for all Aeon switches.
