Problem with lock from locstar
domatech
Post by domatech »
I got a trouble with the lock from Locstar. Device is included on my network, but interview is not completed.
I got all interview element working, except the security one (i've try to wakeup device and reask for this interview, not working as well)
So i can't user DOOR_LOCK fonction (which is secure) with the RaZberry.
I've plugged this lock on a Vera and it work well.
Any help would be appreciated
Re: Problem with lock from locstar
The interview can be done only in first 10 or 20 seconds, so if it does not work initially, it will never - need to reinclude. We need to see the secure interview to gie more details (only the part of the log from Version interview till Manufacturer Specific interview).
The lock is not certified yet, so it might be a problem in it. We have never tried it.
domatech
Post by domatech »
Hello Poltos, thanks for your help.
I have try to exclude/reinclude the lock and do interview just after this, it's the same problem : Security interview don't respond.(i've try 5 times)
Lock respond to other interview everywhen, i mean i can excluse/reinclude the lock, wait for let's said 10 minute then do interview. Everything respond, except security.
I don't see how i can see the log about this process.
The Security interview MUST be done in first 20 seconds. Otherwise it will not pass.
domatech
Post by domatech »
I have try 10 times now : exclude device, reinclude device, go to interview detail and ask for Security Interview. It fail every time.
Also,
Thanks for your help
pofs
Post by pofs »
The log is located in /var/log/z-way.log
May be this can help you not only locating logfiles but also gather other information:
http://razberry.z-wave.me/index.php?id=27
domatech
Post by domatech »
Hello, sorry for the delay but there is the logs :
[2014-06-02 14:40:34.274] Executing script: zway.controller.AddNodeToNetwork(1)
[2014-06-02 14:40:34.280] Adding job: Add/re-include node to network
[2014-06-02 14:40:34.292] SENDING (cb 0x01): ( 01 05 00 4A C1 01 70 )
[2014-06-02 14:40:34.304] RECEIVED ACK
[2014-06-02 14:40:34.316] RECEIVED: ( 01 07 00 4A 01 01 00 00 B2 )
[2014-06-02 14:40:34.322] SENT ACK
[2014-06-02 14:40:34.323] SETDATA controller.data.lastIncludedDevice = Empty
[2014-06-02 14:40:34.324] SETDATA controller.data.lastExcludedDevice = Empty
[2014-06-02 14:40:34.327] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2014-06-02 14:40:34.329] SETDATA controller.data.controllerState = 1 (0x00000001)
[2014-06-02 14:40:44.338] RECEIVED: ( 01 07 00 4A 01 02 00 00 B1 )
[2014-06-02 14:40:44.339] SENT ACK
[2014-06-02 14:40:44.341] Job 0x4a (Add/re-include node to network): Node found: #0
[2014-06-02 14:40:44.342] SETDATA controller.data.controllerState = 2 (0x00000002)
[2014-06-02 14:40:44.582] RECEIVED: ( 01 14 00 4A 01 03 03 0D 04 40 03 22 5D 85 80 70 4C 77 72 86 98 B7 )
[2014-06-02 14:40:44.583] SENT ACK
[2014-06-02 14:40:44.585] Job 0x4a (Add/re-include node to network): Adding slave: #3
[2014-06-02 14:40:44.586] SETDATA controller.data.controllerState = 3 (0x00000003)
[2014-06-02 14:40:44.587] SETDATA controller.data.lastIncludedDevice = 3 (0x00000003)
[2014-06-02 14:40:44.589] SETDATA devices.3.data = Empty
[2014-06-02 14:40:44.590] SETDATA devices.3.instances.0.data = Empty
[2014-06-02 14:40:44.591] SETDATA devices.3.instances.0.data.dynamic = Empty
[2014-06-02 14:40:44.593] SETDATA devices.3.instances.0.data.dynamic = False
[2014-06-02 14:40:44.594] SETDATA devices.3.instances.0.data.genericType = Empty
[2014-06-02 14:40:44.595] SETDATA devices.3.instances.0.data.genericType = 0 (0x00000000)
[2014-06-02 14:40:44.596] SETDATA devices.3.instances.0.data.specificType = Empty
[2014-06-02 14:40:44.597] SETDATA devices.3.instances.0.data.specificType = 0 (0x00000000)
[2014-06-02 14:40:44.598] SETDATA devices.3.data.basicType = Empty
[2014-06-02 14:40:44.600] SETDATA devices.3.data.genericType = Empty
[2014-06-02 14:40:44.601] SETDATA devices.3.data.specificType = Empty
[2014-06-02 14:40:44.602] SETDATA devices.3.data.infoProtocolSpecific = Empty
[2014-06-02 14:40:44.604] SETDATA devices.3.data.deviceTypeString = Empty
[2014-06-02 14:40:44.605] SETDATA devices.3.data.isVirtual = Empty
[2014-06-02 14:40:44.606] SETDATA devices.3.data.isListening = Empty
[2014-06-02 14:40:44.608] SETDATA devices.3.data.isRouting = Empty
[2014-06-02 14:40:44.609] SETDATA devices.3.data.isAwake = Empty
[2014-06-02 14:40:44.611] SETDATA devices.3.data.optional = Empty
[2014-06-02 14:40:44.612] SETDATA devices.3.data.isFailed = Empty
[2014-06-02 14:40:44.613] SETDATA devices.3.data.beam = Empty
[2014-06-02 14:40:44.614] SETDATA devices.3.data.sensor250 = Empty
[2014-06-02 14:40:44.615] SETDATA devices.3.data.sensor1000 = Empty
[2014-06-02 14:40:44.616] SETDATA devices.3.data.neighbours = Empty
[2014-06-02 14:40:44.622] SETDATA devices.3.data.manufacturerId = Empty
[2014-06-02 14:40:44.624] SETDATA devices.3.data.vendorString = Empty
[2014-06-02 14:40:44.626] SETDATA devices.3.data.manufacturerProductType = Empty
[2014-06-02 14:40:44.628] SETDATA devices.3.data.manufacturerProductId = Empty
[2014-06-02 14:40:44.630] SETDATA devices.3.data.ZWLib = Empty
[2014-06-02 14:40:44.631] SETDATA devices.3.data.ZWProtocolMajor = Empty
[2014-06-02 14:40:44.634] SETDATA devices.3.data.ZWProtocolMinor = Empty
[2014-06-02 14:40:44.635] SETDATA devices.3.data.SDK = Empty
[2014-06-02 14:40:44.636] SETDATA devices.3.data.applicationMajor = Empty
[2014-06-02 14:40:44.638] SETDATA devices.3.data.applicationMinor = Empty
[2014-06-02 14:40:44.639] SETDATA devices.3.data.nodeInfoFrame = Empty
[2014-06-02 14:40:44.641] SETDATA devices.3.data.ZDDXMLFile = Empty
[2014-06-02 14:40:44.643] SETDATA devices.3.data.lastSend = Empty
[2014-06-02 14:40:44.644] SETDATA devices.3.data.lastNonceGet = Empty
[2014-06-02 14:40:44.645] SETDATA devices.3.data.lastReceived = Empty
[2014-06-02 14:40:44.647] SETDATA devices.3.data.failureCount = Empty
[2014-06-02 14:40:44.648] SETDATA devices.3.data.keepAwake = Empty
[2014-06-02 14:40:44.650] SETDATA devices.3.data.countSuccess = Empty
[2014-06-02 14:40:44.651] SETDATA devices.3.data.countFailed = Empty
[2014-06-02 14:40:44.652] SETDATA devices.3.data.queueLength = Empty
[2014-06-02 14:40:44.655] SETDATA devices.3.data.lastPacketInfo = Empty
[2014-06-02 14:40:44.657] SETDATA devices.3.data.lastPacketInfo.deliveryTime = Empty
[2014-06-02 14:40:44.658] SETDATA devices.3.data.lastPacketInfo.delivered = Empty
[2014-06-02 14:40:44.660] SETDATA devices.3.data.lastPacketInfo.packetLength = Empty
[2014-06-02 14:40:44.661] SETDATA devices.3.data.basicType = 0 (0x00000000)
[2014-06-02 14:40:44.662] SETDATA devices.3.data.genericType = 0 (0x00000000)
[2014-06-02 14:40:44.664] SETDATA devices.3.data.specificType = 0 (0x00000000)
[2014-06-02 14:40:44.666] SETDATA devices.3.data.infoProtocolSpecific = 0 (0x00000000)
[2014-06-02 14:40:44.667] SETDATA devices.3.data.deviceTypeString = ""
[2014-06-02 14:40:44.669] SETDATA devices.3.data.isVirtual = False
[2014-06-02 14:40:44.670] SETDATA devices.3.data.isListening = True
[2014-06-02 14:40:44.672] SETDATA devices.3.data.isRouting = False
[2014-06-02 14:40:44.673] SETDATA devices.3.data.isAwake = False
[2014-06-02 14:40:44.675] SETDATA devices.3.data.optional = False
[2014-06-02 14:40:44.675] SETDATA devices.3.data.isFailed = False
[2014-06-02 14:40:44.677] SETDATA devices.3.data.beam = False
[2014-06-02 14:40:44.679] SETDATA devices.3.data.sensor250 = False
[2014-06-02 14:40:44.680] SETDATA devices.3.data.sensor1000 = False
[2014-06-02 14:40:44.682] SETDATA devices.3.data.neighbours = Empty
[2014-06-02 14:40:44.683] SETDATA devices.3.data.manufacturerId = 0 (0x00000000)
[2014-06-02 14:40:44.684] SETDATA devices.3.data.manufacturerProductType = 0 (0x00000000)
[2014-06-02 14:40:44.685] SETDATA devices.3.data.manufacturerProductId = 0 (0x00000000)
[2014-06-02 14:40:44.687] SETDATA devices.3.data.applicationMajor = 0 (0x00000000)
[2014-06-02 14:40:44.688] SETDATA devices.3.data.applicationMinor = 0 (0x00000000)
[2014-06-02 14:40:44.689] SETDATA devices.3.data.ZWProtocolMajor = 0 (0x00000000)
[2014-06-02 14:40:44.691] SETDATA devices.3.data.ZWProtocolMinor = 0 (0x00000000)
[2014-06-02 14:40:44.692] SETDATA devices.3.data.ZWLib = 0 (0x00000000)
[2014-06-02 14:40:44.693] SETDATA devices.3.data.SDK = ""
[2014-06-02 14:40:44.694] SETDATA devices.3.data.vendorString = ""
[2014-06-02 14:40:44.696] SETDATA devices.3.data.nodeInfoFrame = Empty
[2014-06-02 14:40:44.698] SETDATA devices.3.data.ZDDXMLFile = ""
[2014-06-02 14:40:44.700] SETDATA devices.3.data.keepAwake = False
[2014-06-02 14:40:44.701] SETDATA devices.3.data.countSuccess = 0 (0x00000000)
[2014-06-02 14:40:44.702] SETDATA devices.3.data.countFailed = 0 (0x00000000)
[2014-06-02 14:40:44.703] SETDATA devices.3.data.queueLength = 0 (0x00000000)
[2014-06-02 14:40:44.704] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:44.705] SETDATA devices.3.data.lastSend = 0 (0x00000000)
[2014-06-02 14:40:44.707] SETDATA devices.3.data.failureCount = 0 (0x00000000)
[2014-06-02 14:40:44.707] Adding job: Get node protocol information
[2014-06-02 14:40:44.709] Adding job: Get routing table line
[2014-06-02 14:40:44.711] Adding job: Check if node is failed
[2014-06-02 14:40:44.712] Adding job: Get routing table line
[2014-06-02 14:40:44.714] Job 0x80 (Get routing table line): removing duplicate
[2014-06-02 14:40:44.716] SETDATA devices.3.data.basicType = 4 (0x00000004)
[2014-06-02 14:40:44.717] SETDATA devices.3.data.genericType = 64 (0x00000040)
[2014-06-02 14:40:44.718] SETDATA devices.3.instances.0.data.genericType = 64 (0x00000040)
[2014-06-02 14:40:44.720] SETDATA devices.3.data.specificType = 3 (0x00000003)
[2014-06-02 14:40:44.722] SETDATA devices.3.instances.0.data.specificType = 3 (0x00000003)
[2014-06-02 14:40:44.727] SETDATA devices.3.data.deviceTypeString = "Secure Keypad"
[2014-06-02 14:40:44.733] SETDATA devices.3.data.nodeInfoFrame = byte[10]
( 22 5D 85 80 70 4C 77 72 86 98 )
[2014-06-02 14:40:44.746] SENDING (cb 0x03): ( 01 04 00 62 03 9A )
[2014-06-02 14:40:44.758] RECEIVED ACK
[2014-06-02 14:40:44.770] RECEIVED: ( 01 04 01 62 00 98 )
[2014-06-02 14:40:44.771] SENT ACK
[2014-06-02 14:40:44.773] SETDATA devices.3.data.isFailed = False
[2014-06-02 14:40:44.774] Job 0x62 (Check if node is failed): Node 3 is operating
[2014-06-02 14:40:44.776] Job 0x62 (Check if node is failed): success
[2014-06-02 14:40:44.777] Removing job: Check if node is failed
[2014-06-02 14:40:44.868] RECEIVED: ( 01 07 00 4A 01 05 03 00 B5 )
[2014-06-02 14:40:44.870] SENT ACK
[2014-06-02 14:40:44.872] Job 0x4a (Add/re-include node to network): Protocol done
[2014-06-02 14:40:44.873] SETDATA controller.data.controllerState = 4 (0x00000004)
[2014-06-02 14:40:44.875] Adding job: Add/re-include node to network
[2014-06-02 14:40:44.876] Loading Command Classes for device 3
[2014-06-02 14:40:44.877] Node 3:0 supports CC ApplicationStatus
[2014-06-02 14:40:44.879] SETDATA devices.3.instances.0.commandClasses.34.data = Empty
[2014-06-02 14:40:44.881] SETDATA devices.3.instances.0.commandClasses.34.data.supported = Empty
[2014-06-02 14:40:44.883] SETDATA devices.3.instances.0.commandClasses.34.data.supported = True
[2014-06-02 14:40:44.884] SETDATA devices.3.instances.0.commandClasses.34.data.version = Empty
[2014-06-02 14:40:44.885] SETDATA devices.3.instances.0.commandClasses.34.data.version = 1 (0x00000001)
[2014-06-02 14:40:44.887] SETDATA devices.3.instances.0.commandClasses.34.data.security = Empty
[2014-06-02 14:40:44.888] SETDATA devices.3.instances.0.commandClasses.34.data.security = False
[2014-06-02 14:40:44.889] SETDATA devices.3.instances.0.commandClasses.34.data.interviewDone = Empty
[2014-06-02 14:40:44.891] SETDATA devices.3.instances.0.commandClasses.34.data.interviewCounter = Empty
[2014-06-02 14:40:44.892] SETDATA devices.3.instances.0.commandClasses.34.data.interviewDone = False
[2014-06-02 14:40:44.894] SETDATA devices.3.instances.0.commandClasses.34.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:44.896] Node 3:0 supports CC DoorLockLogging
[2014-06-02 14:40:44.897] SETDATA devices.3.instances.0.commandClasses.76.data = Empty
[2014-06-02 14:40:44.898] SETDATA devices.3.instances.0.commandClasses.76.data.supported = Empty
[2014-06-02 14:40:44.899] SETDATA devices.3.instances.0.commandClasses.76.data.supported = True
[2014-06-02 14:40:44.901] SETDATA devices.3.instances.0.commandClasses.76.data.version = Empty
[2014-06-02 14:40:44.902] SETDATA devices.3.instances.0.commandClasses.76.data.version = 1 (0x00000001)
[2014-06-02 14:40:44.908] SETDATA devices.3.instances.0.commandClasses.76.data.security = Empty
[2014-06-02 14:40:44.914] SETDATA devices.3.instances.0.commandClasses.76.data.security = False
[2014-06-02 14:40:44.919] SETDATA devices.3.instances.0.commandClasses.76.data.interviewDone = Empty
[2014-06-02 14:40:44.921] SETDATA devices.3.instances.0.commandClasses.76.data.interviewCounter = Empty
[2014-06-02 14:40:44.923] SETDATA devices.3.instances.0.commandClasses.76.data.interviewDone = False
[2014-06-02 14:40:44.924] SETDATA devices.3.instances.0.commandClasses.76.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:44.926] SETDATA devices.3.instances.0.commandClasses.76.data.maxRecords = Empty
[2014-06-02 14:40:44.927] Node 3:0 supports CC UNKNOWN 0x5d
[2014-06-02 14:40:44.931] Node 3:0 supports CC Configuration
[2014-06-02 14:40:44.933] SETDATA devices.3.instances.0.commandClasses.112.data = Empty
[2014-06-02 14:40:44.934] SETDATA devices.3.instances.0.commandClasses.112.data.supported = Empty
[2014-06-02 14:40:44.940] SETDATA devices.3.instances.0.commandClasses.112.data.supported = True
[2014-06-02 14:40:44.945] SETDATA devices.3.instances.0.commandClasses.112.data.version = Empty
[2014-06-02 14:40:44.947] SETDATA devices.3.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-06-02 14:40:44.949] SETDATA devices.3.instances.0.commandClasses.112.data.security = Empty
[2014-06-02 14:40:44.950] SETDATA devices.3.instances.0.commandClasses.112.data.security = False
[2014-06-02 14:40:44.952] SETDATA devices.3.instances.0.commandClasses.112.data.interviewDone = Empty
[2014-06-02 14:40:44.954] SETDATA devices.3.instances.0.commandClasses.112.data.interviewCounter = Empty
[2014-06-02 14:40:44.956] SETDATA devices.3.instances.0.commandClasses.112.data.interviewDone = False
[2014-06-02 14:40:44.958] SETDATA devices.3.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:44.960] Node 3:0 supports CC ManufacturerSpecific
[2014-06-02 14:40:44.961] SETDATA devices.3.instances.0.commandClasses.114.data = Empty
[2014-06-02 14:40:44.962] SETDATA devices.3.instances.0.commandClasses.114.data.supported = Empty
[2014-06-02 14:40:44.964] SETDATA devices.3.instances.0.commandClasses.114.data.supported = True
[2014-06-02 14:40:44.966] SETDATA devices.3.instances.0.commandClasses.114.data.version = Empty
[2014-06-02 14:40:44.967] SETDATA devices.3.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-06-02 14:40:44.969] SETDATA devices.3.instances.0.commandClasses.114.data.security = Empty
[2014-06-02 14:40:44.970] SETDATA devices.3.instances.0.commandClasses.114.data.security = False
[2014-06-02 14:40:44.972] SETDATA devices.3.instances.0.commandClasses.114.data.interviewDone = Empty
[2014-06-02 14:40:44.973] SETDATA devices.3.instances.0.commandClasses.114.data.interviewCounter = Empty
[2014-06-02 14:40:44.975] SETDATA devices.3.instances.0.commandClasses.114.data.interviewDone = False
[2014-06-02 14:40:44.976] SETDATA devices.3.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:44.978] SETDATA devices.3.instances.0.commandClasses.114.data.vendorId = Empty
[2014-06-02 14:40:44.979] SETDATA devices.3.instances.0.commandClasses.114.data.vendor = Empty
[2014-06-02 14:40:44.980] SETDATA devices.3.instances.0.commandClasses.114.data.productId = Empty
[2014-06-02 14:40:44.981] SETDATA devices.3.instances.0.commandClasses.114.data.productType = Empty
[2014-06-02 14:40:44.983] Node 3:0 supports CC NodeNaming
[2014-06-02 14:40:44.984] SETDATA devices.3.instances.0.commandClasses.119.data = Empty
[2014-06-02 14:40:44.985] SETDATA devices.3.instances.0.commandClasses.119.data.supported = Empty
[2014-06-02 14:40:44.987] SETDATA devices.3.instances.0.commandClasses.119.data.supported = True
[2014-06-02 14:40:44.988] SETDATA devices.3.instances.0.commandClasses.119.data.version = Empty
[2014-06-02 14:40:44.990] SETDATA devices.3.instances.0.commandClasses.119.data.version = 1 (0x00000001)
[2014-06-02 14:40:44.990] SETDATA devices.3.instances.0.commandClasses.119.data.security = Empty
[2014-06-02 14:40:44.992] SETDATA devices.3.instances.0.commandClasses.119.data.security = False
[2014-06-02 14:40:44.992] SETDATA devices.3.instances.0.commandClasses.119.data.interviewDone = Empty
[2014-06-02 14:40:44.994] SETDATA devices.3.instances.0.commandClasses.119.data.interviewCounter = Empty
[2014-06-02 14:40:44.994] SETDATA devices.3.instances.0.commandClasses.119.data.interviewDone = False
[2014-06-02 14:40:44.996] SETDATA devices.3.instances.0.commandClasses.119.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:44.996] SETDATA devices.3.instances.0.commandClasses.119.data.nodename = Empty
[2014-06-02 14:40:44.998] SETDATA devices.3.instances.0.commandClasses.119.data.location = Empty
[2014-06-02 14:40:44.999] SETDATA devices.3.instances.0.commandClasses.119.data.myname = Empty
[2014-06-02 14:40:45.000] SETDATA devices.3.instances.0.commandClasses.119.data.mylocation = Empty
[2014-06-02 14:40:45.002] Node 3:0 supports CC Battery
[2014-06-02 14:40:45.003] SETDATA devices.3.instances.0.commandClasses.128.data = Empty
[2014-06-02 14:40:45.005] SETDATA devices.3.instances.0.commandClasses.128.data.supported = Empty
[2014-06-02 14:40:45.006] SETDATA devices.3.instances.0.commandClasses.128.data.supported = True
[2014-06-02 14:40:45.007] SETDATA devices.3.instances.0.commandClasses.128.data.version = Empty
[2014-06-02 14:40:45.009] SETDATA devices.3.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2014-06-02 14:40:45.010] SETDATA devices.3.instances.0.commandClasses.128.data.security = Empty
[2014-06-02 14:40:45.012] SETDATA devices.3.instances.0.commandClasses.128.data.security = False
[2014-06-02 14:40:45.013] SETDATA devices.3.instances.0.commandClasses.128.data.interviewDone = Empty
[2014-06-02 14:40:45.015] SETDATA devices.3.instances.0.commandClasses.128.data.interviewCounter = Empty
[2014-06-02 14:40:45.017] SETDATA devices.3.instances.0.commandClasses.128.data.interviewDone = False
[2014-06-02 14:40:45.018] SETDATA devices.3.instances.0.commandClasses.128.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:45.020] SETDATA devices.3.instances.0.commandClasses.128.data.lastChange = Empty
[2014-06-02 14:40:45.021] SETDATA devices.3.instances.0.commandClasses.128.data.history = Empty
[2014-06-02 14:40:45.022] SETDATA devices.3.instances.0.commandClasses.128.data.last = Empty
[2014-06-02 14:40:45.023] SETDATA devices.3.instances.0.commandClasses.128.data.last = 0 (0x00000000)
[2014-06-02 14:40:45.024] Node 3:0 supports CC Association
[2014-06-02 14:40:45.026] SETDATA devices.3.instances.0.commandClasses.133.data = Empty
[2014-06-02 14:40:45.027] SETDATA devices.3.instances.0.commandClasses.133.data.supported = Empty
[2014-06-02 14:40:45.028] SETDATA devices.3.instances.0.commandClasses.133.data.supported = True
[2014-06-02 14:40:45.030] SETDATA devices.3.instances.0.commandClasses.133.data.version = Empty
[2014-06-02 14:40:45.031] SETDATA devices.3.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2014-06-02 14:40:45.032] SETDATA devices.3.instances.0.commandClasses.133.data.security = Empty
[2014-06-02 14:40:45.033] SETDATA devices.3.instances.0.commandClasses.133.data.security = False
[2014-06-02 14:40:45.034] SETDATA devices.3.instances.0.commandClasses.133.data.interviewDone = Empty
[2014-06-02 14:40:45.036] SETDATA devices.3.instances.0.commandClasses.133.data.interviewCounter = Empty
[2014-06-02 14:40:45.037] SETDATA devices.3.instances.0.commandClasses.133.data.interviewDone = False
[2014-06-02 14:40:45.038] SETDATA devices.3.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:45.040] SETDATA devices.3.instances.0.commandClasses.133.data.groups = Empty
[2014-06-02 14:40:45.041] Node 3:0 supports CC Version
[2014-06-02 14:40:45.043] SETDATA devices.3.instances.0.commandClasses.134.data = Empty
[2014-06-02 14:40:45.044] SETDATA devices.3.instances.0.commandClasses.134.data.supported = Empty
[2014-06-02 14:40:45.045] SETDATA devices.3.instances.0.commandClasses.134.data.supported = True
[2014-06-02 14:40:45.046] SETDATA devices.3.instances.0.commandClasses.134.data.version = Empty
[2014-06-02 14:40:45.052] SETDATA devices.3.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-06-02 14:40:45.054] SETDATA devices.3.instances.0.commandClasses.134.data.security = Empty
[2014-06-02 14:40:45.055] SETDATA devices.3.instances.0.commandClasses.134.data.security = False
[2014-06-02 14:40:45.057] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = Empty
[2014-06-02 14:40:45.058] SETDATA devices.3.instances.0.commandClasses.134.data.interviewCounter = Empty
[2014-06-02 14:40:45.060] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = False
[2014-06-02 14:40:45.061] SETDATA devices.3.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:45.063] SETDATA devices.3.instances.0.commandClasses.134.data.ZWLib = Empty
[2014-06-02 14:40:45.065] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMajor = Empty
[2014-06-02 14:40:45.066] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMinor = Empty
[2014-06-02 14:40:45.068] SETDATA devices.3.instances.0.commandClasses.134.data.SDK = Empty
[2014-06-02 14:40:45.068] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMajor = Empty
[2014-06-02 14:40:45.070] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMinor = Empty
[2014-06-02 14:40:45.071] SETDATA devices.3.instances.0.commandClasses.134.data.hardwareVersion = Empty
[2014-06-02 14:40:45.073] SETDATA devices.3.instances.0.commandClasses.134.data.firmwareCount = Empty
[2014-06-02 14:40:45.074] Node 3:0 supports CC Security
[2014-06-02 14:40:45.075] SETDATA devices.3.instances.0.commandClasses.152.data = Empty
[2014-06-02 14:40:45.077] SETDATA devices.3.instances.0.commandClasses.152.data.supported = Empty
[2014-06-02 14:40:45.078] SETDATA devices.3.instances.0.commandClasses.152.data.supported = True
[2014-06-02 14:40:45.080] SETDATA devices.3.instances.0.commandClasses.152.data.version = Empty
[2014-06-02 14:40:45.081] SETDATA devices.3.instances.0.commandClasses.152.data.version = 1 (0x00000001)
[2014-06-02 14:40:45.082] SETDATA devices.3.instances.0.commandClasses.152.data.security = Empty
[2014-06-02 14:40:45.083] SETDATA devices.3.instances.0.commandClasses.152.data.security = False
[2014-06-02 14:40:45.084] SETDATA devices.3.instances.0.commandClasses.152.data.interviewDone = Empty
[2014-06-02 14:40:45.085] SETDATA devices.3.instances.0.commandClasses.152.data.interviewCounter = Empty
[2014-06-02 14:40:45.086] SETDATA devices.3.instances.0.commandClasses.152.data.interviewDone = False
[2014-06-02 14:40:45.088] SETDATA devices.3.instances.0.commandClasses.152.data.interviewCounter = 10 (0x0000000a)
[2014-06-02 14:40:45.089] SETDATA devices.3.instances.0.commandClasses.152.data.scheme = Empty
[2014-06-02 14:40:45.090] SETDATA devices.3.instances.0.commandClasses.152.data.scheme = 0 (0x00000000)
[2014-06-02 14:40:45.092] SETDATA devices.3.instances.0.commandClasses.152.data.secureChannelEstablished = Empty
[2014-06-02 14:40:45.092] SETDATA devices.3.instances.0.commandClasses.152.data.secureChannelEstablished = False
[2014-06-02 14:40:45.094] SETDATA devices.3.instances.0.commandClasses.152.data.secureNodeInfoFrame = Empty
[2014-06-02 14:40:45.095] SETDATA devices.3.instances.0.commandClasses.152.data.secureNodeInfoFrame = byte[0]
( zero-length buffer )
[2014-06-02 14:40:45.096] SETDATA devices.3.instances.0.commandClasses.152.data.Ka = Empty
[2014-06-02 14:40:45.097] SETDATA devices.3.instances.0.commandClasses.152.data.Ke = Empty
[2014-06-02 14:40:45.098] SETDATA devices.3.instances.0.commandClasses.152.data.rNonce = Empty
[2014-06-02 14:40:45.099] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = Empty
[2014-06-02 14:40:45.101] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = Empty
[2014-06-02 14:40:45.102] SETDATA devices.3.instances.0.commandClasses.152.data.sequenceId = Empty
[2014-06-02 14:40:45.103] SETDATA devices.3.instances.0.commandClasses.152.data.toFollow = Empty
[2014-06-02 14:40:45.104] SETDATA devices.3.instances.0.commandClasses.152.data.Ka = **********
[2014-06-02 14:40:45.106] SETDATA devices.3.instances.0.commandClasses.152.data.Ke = **********
[2014-06-02 14:40:45.107] SETDATA devices.3.data.lastSend = 8045 (0x00001f6d)
[2014-06-02 14:40:45.109] SETDATA devices.3.data.isAwake = True
[2014-06-02 14:40:45.110] SETDATA devices.3.data.lastSend = 7945 (0x00001f09)
[2014-06-02 14:40:45.111] SETDATA devices.3.data.lastNonceGet = 6945 (0x00001b21)
[2014-06-02 14:40:45.112] Interview step 1
[2014-06-02 14:40:45.113] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = False
[2014-06-02 14:40:45.114] SETDATA devices.3.instances.0.commandClasses.134.data.interviewCounter = 9 (0x00000009)
[2014-06-02 14:40:45.116] Node 3:0 CC Version Interview started
[2014-06-02 14:40:45.118] Adding job: Version Get
[2014-06-02 14:40:45.119] Adding job: ApplicationStatus Version Get
[2014-06-02 14:40:45.121] Adding job: DoorLockLogging Version Get
[2014-06-02 14:40:45.122] Adding job: Configuration Version Get
[2014-06-02 14:40:45.124] Adding job: ManufacturerSpecific Version Get
[2014-06-02 14:40:45.126] Adding job: NodeNaming Version Get
[2014-06-02 14:40:45.128] Adding job: Battery Version Get
[2014-06-02 14:40:45.129] Adding job: Association Version Get
[2014-06-02 14:40:45.131] Adding job: Version Version Get
[2014-06-02 14:40:45.132] Adding job: Security Version Get
[2014-06-02 14:40:45.134] Running wakeup handler for node 3
[2014-06-02 14:40:45.396] SENDING (cb 0x05): ( 01 04 00 4A 05 B4 )
[2014-06-02 14:40:45.408] RECEIVED ACK
[2014-06-02 14:40:45.411] Removing job: Add/re-include node to network
[2014-06-02 14:40:45.457] RECEIVED: ( 01 07 00 4A 01 06 03 00 B6 )
[2014-06-02 14:40:45.459] SENT ACK
[2014-06-02 14:40:45.460] Job 0x4a (Add/re-include node to network): Done
[2014-06-02 14:40:45.462] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-06-02 14:40:45.463] Job 0x4a (Add/re-include node to network): success
[2014-06-02 14:40:45.465] Removing job: Add/re-include node to network
[2014-06-02 14:40:45.479] SENDING (cb 0x03): ( 01 04 00 41 03 B9 )
[2014-06-02 14:40:45.493] RECEIVED ACK
[2014-06-02 14:40:45.505] RECEIVED: ( 01 09 01 41 53 DC 00 04 40 03 7E )
[2014-06-02 14:40:45.506] SENT ACK
[2014-06-02 14:40:45.508] SETDATA devices.3.data.basicType = 4 (0x00000004)
[2014-06-02 14:40:45.509] SETDATA devices.3.data.genericType = 64 (0x00000040)
[2014-06-02 14:40:45.511] SETDATA devices.3.data.specificType = 3 (0x00000003)
[2014-06-02 14:40:45.517] SETDATA devices.3.data.deviceTypeString = "Secure Keypad"
[2014-06-02 14:40:45.519] SETDATA devices.3.data.isRouting = True
[2014-06-02 14:40:45.520] SETDATA devices.3.data.isListening = False
[2014-06-02 14:40:45.521] SETDATA devices.3.data.optional = True
[2014-06-02 14:40:45.523] SETDATA devices.3.data.sensor1000 = True
[2014-06-02 14:40:45.524] SETDATA devices.3.data.sensor250 = False
[2014-06-02 14:40:45.525] SETDATA devices.3.data.infoProtocolSpecific = 5495808 (0x0053dc00)
[2014-06-02 14:40:45.527] Job 0x41 (Get node protocol information): success
[2014-06-02 14:40:45.528] Removing job: Get node protocol information
[2014-06-02 14:40:45.546] SENDING (cb 0x00): ( 01 06 00 80 01 00 00 78 )
[2014-06-02 14:40:45.558] RECEIVED ACK
[2014-06-02 14:40:45.569] RECEIVED: ( 01 20 01 80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A )
[2014-06-02 14:40:45.571] SENT ACK
[2014-06-02 14:40:45.572] SETDATA devices.1.data.neighbours = byte[1]
( 03 )
[2014-06-02 14:40:45.574] Job 0x80 (Get routing table line): List of neighbours for node 1: [ 03 ]
[2014-06-02 14:40:45.575] Job 0x80 (Get routing table line): success
[2014-06-02 14:40:45.577] Removing job: Get routing table line
[2014-06-02 14:40:45.590] SENDING (cb 0x00): ( 01 06 00 80 03 00 00 7A )
[2014-06-02 14:40:45.603] RECEIVED ACK
[2014-06-02 14:40:45.614] RECEIVED: ( 01 20 01 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5F )
[2014-06-02 14:40:45.616] SENT ACK
[2014-06-02 14:40:45.617] SETDATA devices.3.data.neighbours = byte[1]
( 01 )
[2014-06-02 14:40:45.620] Job 0x80 (Get routing table line): List of neighbours for node 3: [ 01 ]
[2014-06-02 14:40:45.621] Job 0x80 (Get routing table line): success
[2014-06-02 14:40:45.623] Removing job: Get routing table line
[2014-06-02 14:40:45.635] SENDING (cb 0x02): ( 01 09 00 13 03 02 86 11 25 02 54 )
[2014-06-02 14:40:45.647] RECEIVED ACK
[2014-06-02 14:40:45.659] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:45.660] SENT ACK
[2014-06-02 14:40:45.662] Delivered to Z-Wave stack
[2014-06-02 14:40:46.809] RECEIVED: ( 01 05 00 13 02 00 EB )
[2014-06-02 14:40:46.810] SENT ACK
[2014-06-02 14:40:46.811] Job 0x13 (Version Get): Delivered
[2014-06-02 14:40:46.813] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:46.814] SETDATA devices.3.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2014-06-02 14:40:46.816] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1149 (0x0000047d)
[2014-06-02 14:40:46.817] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:46.819] SendData Response with callback 0x02 received: received by recipient
[2014-06-02 14:40:46.820] SETDATA devices.3.data.lastSend = 8063 (0x00001f7f)
[2014-06-02 14:40:46.822] Job 0x13 (Version Get): success
[2014-06-02 14:40:46.823] Removing job: Version Get
[2014-06-02 14:40:46.834] RECEIVED: ( 01 0D 00 04 00 03 07 86 12 03 03 43 01 47 63 )
[2014-06-02 14:40:46.836] SENT ACK
[2014-06-02 14:40:46.838] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:46.840] SETDATA devices.3.instances.0.commandClasses.134.data = Empty
[2014-06-02 14:40:46.841] SETDATA devices.3.instances.0.commandClasses.134.data.ZWLib = 3 (0x00000003)
[2014-06-02 14:40:46.844] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMajor = 3 (0x00000003)
[2014-06-02 14:40:46.846] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMinor = 67 (0x00000043)
[2014-06-02 14:40:46.851] SETDATA devices.3.instances.0.commandClasses.134.data.SDK = "4.55.00"
[2014-06-02 14:40:46.852] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMajor = 1 (0x00000001)
[2014-06-02 14:40:46.853] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMinor = 71 (0x00000047)
[2014-06-02 14:40:46.855] SETDATA devices.3.data.ZWLib = 3 (0x00000003)
[2014-06-02 14:40:46.856] SETDATA devices.3.data.ZWProtocolMajor = 3 (0x00000003)
[2014-06-02 14:40:46.858] SETDATA devices.3.data.ZWProtocolMinor = 67 (0x00000043)
[2014-06-02 14:40:46.863] SETDATA devices.3.data.SDK = "4.55.00"
[2014-06-02 14:40:46.864] SETDATA devices.3.data.applicationMajor = 1 (0x00000001)
[2014-06-02 14:40:46.870] SETDATA devices.3.data.applicationMinor = 71 (0x00000047)
[2014-06-02 14:40:46.871] SETDATA devices.3.instances.0.commandClasses.134.data.hardwareVersion = Empty
[2014-06-02 14:40:46.873] SETDATA devices.3.instances.0.commandClasses.134.data.firmwareCount = 0 (0x00000000)
[2014-06-02 14:40:46.947] SENDING (cb 0x03): ( 01 0A 00 13 03 03 86 13 22 25 03 77 )
[2014-06-02 14:40:46.959] RECEIVED ACK
[2014-06-02 14:40:46.970] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:46.979] SENT ACK
[2014-06-02 14:40:46.982] Delivered to Z-Wave stack
[2014-06-02 14:40:48.121] RECEIVED: ( 01 05 00 13 03 00 EA )
[2014-06-02 14:40:48.122] SENT ACK
[2014-06-02 14:40:48.124] Job 0x13 (ApplicationStatus Version Get): Delivered
[2014-06-02 14:40:48.125] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:48.126] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:48.128] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1142 (0x00000476)
[2014-06-02 14:40:48.129] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:48.131] SendData Response with callback 0x03 received: received by recipient
[2014-06-02 14:40:48.132] SETDATA devices.3.data.lastSend = 8170 (0x00001fea)
[2014-06-02 14:40:48.134] Job 0x13 (ApplicationStatus Version Get): success
[2014-06-02 14:40:48.135] Removing job: ApplicationStatus Version Get
[2014-06-02 14:40:48.148] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 22 01 47 )
[2014-06-02 14:40:48.149] SENT ACK
[2014-06-02 14:40:48.151] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:48.154] Node 3:0 CC Version: ApplicationStatus is v1
[2014-06-02 14:40:48.155] SETDATA devices.3.instances.0.commandClasses.34.data.version = 1 (0x00000001)
[2014-06-02 14:40:48.214] SENDING (cb 0x04): ( 01 0A 00 13 03 03 86 13 4C 25 04 1E )
[2014-06-02 14:40:48.226] RECEIVED ACK
[2014-06-02 14:40:48.237] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:48.239] SENT ACK
[2014-06-02 14:40:48.241] Delivered to Z-Wave stack
[2014-06-02 14:40:49.388] RECEIVED: ( 01 05 00 13 04 00 ED )
[2014-06-02 14:40:49.390] SENT ACK
[2014-06-02 14:40:49.391] Job 0x13 (DoorLockLogging Version Get): Delivered
[2014-06-02 14:40:49.392] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:49.394] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:49.395] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1150 (0x0000047e)
[2014-06-02 14:40:49.397] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:49.399] SendData Response with callback 0x04 received: received by recipient
[2014-06-02 14:40:49.400] SETDATA devices.3.data.lastSend = 8277 (0x00002055)
[2014-06-02 14:40:49.402] Job 0x13 (DoorLockLogging Version Get): success
[2014-06-02 14:40:49.403] Removing job: DoorLockLogging Version Get
[2014-06-02 14:40:49.415] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 4C 01 29 )
[2014-06-02 14:40:49.416] SENT ACK
[2014-06-02 14:40:49.418] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:49.420] Node 3:0 CC Version: DoorLockLogging is v1
[2014-06-02 14:40:49.422] SETDATA devices.3.instances.0.commandClasses.76.data.version = 1 (0x00000001)
[2014-06-02 14:40:49.480] SENDING (cb 0x05): ( 01 0A 00 13 03 03 86 13 70 25 05 23 )
[2014-06-02 14:40:49.492] RECEIVED ACK
[2014-06-02 14:40:49.504] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:49.505] SENT ACK
[2014-06-02 14:40:49.507] Delivered to Z-Wave stack
[2014-06-02 14:40:50.654] RECEIVED: ( 01 05 00 13 05 00 EC )
[2014-06-02 14:40:50.656] SENT ACK
[2014-06-02 14:40:50.657] Job 0x13 (Configuration Version Get): Delivered
[2014-06-02 14:40:50.659] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:50.661] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:50.662] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1151 (0x0000047f)
[2014-06-02 14:40:50.663] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:50.665] SendData Response with callback 0x05 received: received by recipient
[2014-06-02 14:40:50.666] SETDATA devices.3.data.lastSend = 8385 (0x000020c1)
[2014-06-02 14:40:50.672] Job 0x13 (Configuration Version Get): success
[2014-06-02 14:40:50.674] Removing job: Configuration Version Get
[2014-06-02 14:40:50.685] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 70 02 16 )
[2014-06-02 14:40:50.687] SENT ACK
[2014-06-02 14:40:50.688] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:50.689] Node 3:0 CC Version: Configuration is v2
[2014-06-02 14:40:50.691] SETDATA devices.3.instances.0.commandClasses.112.data.version = 2 (0x00000002)
[2014-06-02 14:40:50.750] SENDING (cb 0x06): ( 01 0A 00 13 03 03 86 13 72 25 06 22 )
[2014-06-02 14:40:50.762] RECEIVED ACK
[2014-06-02 14:40:50.774] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:50.775] SENT ACK
[2014-06-02 14:40:50.781] Delivered to Z-Wave stack
[2014-06-02 14:40:51.935] RECEIVED: ( 01 05 00 13 06 00 EF )
[2014-06-02 14:40:51.936] SENT ACK
[2014-06-02 14:40:51.938] Job 0x13 (ManufacturerSpecific Version Get): Delivered
[2014-06-02 14:40:51.941] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:51.943] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:51.944] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1158 (0x00000486)
[2014-06-02 14:40:51.946] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:51.948] SendData Response with callback 0x06 received: received by recipient
[2014-06-02 14:40:51.949] SETDATA devices.3.data.lastSend = 8493 (0x0000212d)
[2014-06-02 14:40:51.951] Job 0x13 (ManufacturerSpecific Version Get): success
[2014-06-02 14:40:51.952] Removing job: ManufacturerSpecific Version Get
[2014-06-02 14:40:51.964] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 72 01 17 )
[2014-06-02 14:40:51.964] SENT ACK
[2014-06-02 14:40:51.965] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:51.965] Node 3:0 CC Version: ManufacturerSpecific is v1
[2014-06-02 14:40:51.965] SETDATA devices.3.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-06-02 14:40:52.023] SENDING (cb 0x07): ( 01 0A 00 13 03 03 86 13 77 25 07 26 )
[2014-06-02 14:40:52.043] RECEIVED ACK
[2014-06-02 14:40:52.054] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:52.056] SENT ACK
[2014-06-02 14:40:52.057] Delivered to Z-Wave stack
[2014-06-02 14:40:53.212] RECEIVED: ( 01 05 00 13 07 00 EE )
[2014-06-02 14:40:53.213] SENT ACK
[2014-06-02 14:40:53.213] Job 0x13 (NodeNaming Version Get): Delivered
[2014-06-02 14:40:53.214] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:53.214] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:53.216] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1154 (0x00000482)
[2014-06-02 14:40:53.218] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:53.219] SendData Response with callback 0x07 received: received by recipient
[2014-06-02 14:40:53.222] SETDATA devices.3.data.lastSend = 8602 (0x0000219a)
[2014-06-02 14:40:53.224] Job 0x13 (NodeNaming Version Get): success
[2014-06-02 14:40:53.225] Removing job: NodeNaming Version Get
[2014-06-02 14:40:53.238] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 77 01 12 )
[2014-06-02 14:40:53.239] SENT ACK
[2014-06-02 14:40:53.241] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:53.242] Node 3:0 CC Version: NodeNaming is v1
[2014-06-02 14:40:53.243] SETDATA devices.3.instances.0.commandClasses.119.data.version = 1 (0x00000001)
[2014-06-02 14:40:53.306] SENDING (cb 0x08): ( 01 0A 00 13 03 03 86 13 80 25 08 DE )
[2014-06-02 14:40:53.317] RECEIVED ACK
[2014-06-02 14:40:53.329] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:53.332] SENT ACK
[2014-06-02 14:40:53.333] Delivered to Z-Wave stack
[2014-06-02 14:40:54.481] RECEIVED: ( 01 05 00 13 08 00 E1 )
[2014-06-02 14:40:54.481] SENT ACK
[2014-06-02 14:40:54.484] Job 0x13 (Battery Version Get): Delivered
[2014-06-02 14:40:54.485] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:54.486] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:54.489] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1150 (0x0000047e)
[2014-06-02 14:40:54.490] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:54.492] SendData Response with callback 0x08 received: received by recipient
[2014-06-02 14:40:54.493] SETDATA devices.3.data.lastSend = 8710 (0x00002206)
[2014-06-02 14:40:54.494] Job 0x13 (Battery Version Get): success
[2014-06-02 14:40:54.495] Removing job: Battery Version Get
[2014-06-02 14:40:54.507] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 80 01 E5 )
[2014-06-02 14:40:54.509] SENT ACK
[2014-06-02 14:40:54.510] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:54.511] Node 3:0 CC Version: Battery is v1
[2014-06-02 14:40:54.513] SETDATA devices.3.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2014-06-02 14:40:54.576] SENDING (cb 0x09): ( 01 0A 00 13 03 03 86 13 85 25 09 DA )
[2014-06-02 14:40:54.588] RECEIVED ACK
[2014-06-02 14:40:54.600] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:54.601] SENT ACK
[2014-06-02 14:40:54.603] Delivered to Z-Wave stack
[2014-06-02 14:40:55.753] RECEIVED: ( 01 05 00 13 09 00 E0 )
[2014-06-02 14:40:55.753] SENT ACK
[2014-06-02 14:40:55.753] Job 0x13 (Association Version Get): Delivered
[2014-06-02 14:40:55.754] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:55.754] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:55.754] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1149 (0x0000047d)
[2014-06-02 14:40:55.754] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:55.755] SendData Response with callback 0x09 received: received by recipient
[2014-06-02 14:40:55.755] SETDATA devices.3.data.lastSend = 8818 (0x00002272)
[2014-06-02 14:40:55.755] Job 0x13 (Association Version Get): success
[2014-06-02 14:40:55.755] Removing job: Association Version Get
[2014-06-02 14:40:55.766] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 85 01 E0 )
[2014-06-02 14:40:55.767] SENT ACK
[2014-06-02 14:40:55.769] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:55.771] Node 3:0 CC Version: Association is v1
[2014-06-02 14:40:55.772] SETDATA devices.3.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2014-06-02 14:40:55.834] SENDING (cb 0x0a): ( 01 0A 00 13 03 03 86 13 86 25 0A DA )
[2014-06-02 14:40:55.846] RECEIVED ACK
[2014-06-02 14:40:55.858] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:55.859] SENT ACK
[2014-06-02 14:40:55.860] Delivered to Z-Wave stack
[2014-06-02 14:40:57.009] RECEIVED: ( 01 05 00 13 0A 00 E3 )
[2014-06-02 14:40:57.011] SENT ACK
[2014-06-02 14:40:57.012] Job 0x13 (Version Version Get): Delivered
[2014-06-02 14:40:57.014] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:57.015] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:57.017] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1153 (0x00000481)
[2014-06-02 14:40:57.018] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:57.026] SendData Response with callback 0x0a received: received by recipient
[2014-06-02 14:40:57.028] SETDATA devices.3.data.lastSend = 8926 (0x000022de)
[2014-06-02 14:40:57.030] Job 0x13 (Version Version Get): success
[2014-06-02 14:40:57.031] Removing job: Version Version Get
[2014-06-02 14:40:57.043] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 86 01 E3 )
[2014-06-02 14:40:57.044] SENT ACK
[2014-06-02 14:40:57.046] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:57.047] Node 3:0 CC Version: Version is v1
[2014-06-02 14:40:57.049] SETDATA devices.3.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-06-02 14:40:57.107] SENDING (cb 0x0b): ( 01 0A 00 13 03 03 86 13 98 25 0B C5 )
[2014-06-02 14:40:57.119] RECEIVED ACK
[2014-06-02 14:40:57.130] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:57.130] SENT ACK
[2014-06-02 14:40:57.131] Delivered to Z-Wave stack
[2014-06-02 14:40:58.281] RECEIVED: ( 01 05 00 13 0B 00 E2 )
[2014-06-02 14:40:58.282] SENT ACK
[2014-06-02 14:40:58.283] Job 0x13 (Security Version Get): Delivered
[2014-06-02 14:40:58.285] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:40:58.287] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:40:58.288] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1154 (0x00000482)
[2014-06-02 14:40:58.290] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:40:58.291] SendData Response with callback 0x0b received: received by recipient
[2014-06-02 14:40:58.293] SETDATA devices.3.data.lastSend = 9035 (0x0000234b)
[2014-06-02 14:40:58.294] Job 0x13 (Security Version Get): success
[2014-06-02 14:40:58.296] Removing job: Security Version Get
[2014-06-02 14:40:58.307] RECEIVED: ( 01 0A 00 04 00 03 04 86 14 98 01 FD )
[2014-06-02 14:40:58.309] SENT ACK
[2014-06-02 14:40:58.311] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2014-06-02 14:40:58.312] Node 3:0 CC Version: Security is v1
[2014-06-02 14:40:58.314] SETDATA devices.3.instances.0.commandClasses.152.data.version = 1 (0x00000001)
[2014-06-02 14:40:58.315] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = True
[2014-06-02 14:40:58.317] Node 3:0 CC Version Interview done
[2014-06-02 14:40:58.320] Saving configuration data to ./config/zddx/ec0368fa-DevicesData.xml
[2014-06-02 14:40:58.875] Interview step 2S - Security
[2014-06-02 14:40:58.877] SETDATA devices.3.instances.0.commandClasses.152.data.interviewDone = False
[2014-06-02 14:40:58.879] SETDATA devices.3.instances.0.commandClasses.152.data.interviewCounter = 9 (0x00000009)
[2014-06-02 14:40:58.880] Node 3:0 CC Security Interview started
[2014-06-02 14:40:58.882] Node 3:0 CC Security: sending Scheme Get
[2014-06-02 14:40:58.884] Adding job: Scheme get
[2014-06-02 14:40:58.984] SENDING (cb 0x0c): ( 01 0A 00 13 03 03 98 04 00 05 0C 73 )
[2014-06-02 14:40:58.996] RECEIVED ACK
[2014-06-02 14:40:59.008] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-06-02 14:40:59.009] SENT ACK
[2014-06-02 14:40:59.009] Delivered to Z-Wave stack
[2014-06-02 14:41:00.159] RECEIVED: ( 01 05 00 13 0C 00 E5 )
[2014-06-02 14:41:00.159] SENT ACK
[2014-06-02 14:41:00.159] Job 0x13 (Scheme get): Delivered
[2014-06-02 14:41:00.160] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2014-06-02 14:41:00.160] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-06-02 14:41:00.160] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1150 (0x0000047e)
[2014-06-02 14:41:00.161] SETDATA devices.3.data.lastPacketInfo = **********
[2014-06-02 14:41:00.161] SendData Response with callback 0x0c received: received by recipient
[2014-06-02 14:41:00.161] SETDATA devices.3.data.lastSend = 9144 (0x000023b8)
[2014-06-02 14:41:00.161] Job 0x13 (Scheme get): success
[2014-06-02 14:41:00.161] Removing job: Scheme get
pofs
Post by pofs »
It is either your log is incomplete, or your lock doesn't respond with SECURITY_SCHEME_REPORT, so the network key exchange never happens.
domatech
Post by domatech »
Here is the answer from the lock supplier :
We checked but it is hard for us to change the encripted lock.Maybe the gateway sulllpier can test and updated to support uncripted lock.
Since it is not safe if the lock does not encript,otherwise somebody may control the lock for unlocking and locking easily.
