Thermostat Measurement Unit Question
Leaving Hope
Post by Leaving Hope »
I recently acquired an Evolve T100 Thermostat.
When looking at the physical thermostat display on the wall, the temperature is displayed in Fahrenheit (which is the desired behavior).
However, when I use Zway to query the temperature and to set the temperature programmatically, the units are in Celsius. E.g., /ZWaveAPI/Run/devices[8].instances[0].commandClasses[67].Set(2,25) instead of /ZWaveAPI/Run/devices[8].instances[0].commandClasses[67].Set(2,77)
1: Object
2: Object
deviceScale: Object
    invalidateTime: 1399227015
    type: "int"
    updateTime: 1399444200
    value: 1
scale: Object
    type: "int"
    value: 0
Should I be looking for a configuration setting in the device so that I can programmatically set and receive the temperature in Fahrenheit? Unfortunately there's no documentation on this, and the pepper1.net Zwave DB doesn't have this specific device.
When I look at this, it looks like scale (0 = Celsius) is the problem. But I'm not sure how to change that.
pofs
Re: Thermostat Measurement Unit Question
Post by pofs »
You need to edit config/Defaults.xml a bit. Look for
	<CommandClass id="0x31">
 		<Fahrenheit>0</Fahrenheit>
	</CommandClass>
	<CommandClass id="0x43">
	</CommandClass>
and change both settings from 0 to 1. After restarting z-way-server temperature will be presented in Fahrenheit.
