New release candidate of available now!
Dear all,
We are launching alpha version tests of our latest version of Z-Way with new UI and Home Automation engine.
Testers are apreciated!
To get the new version you need to run (as usually ;)
wget -q -O - razberry.z-wave.me/install/v1.7.0-rc2 | sudo bash
UPD: not it is rc2, not rc1
If you have tried previously our new UI, you will probably need to clean automation/storage/* If you had too much stuff configured, make sure to port it (we have changed some formats recently, so it might conflict with older version).
Also for new UI you might need to clear browser cache (consult help pages of your browser).
Changes are big:
New command classes, stability issues solved.
A lot of improvements in new UI and Home Automation modules (check viewtopic.php?f=3422&t=20282)
We will update the ChangeLog and documentation soon.
You can submit your issues here:
https://github.com/Z-Wave-Me/home-autom ... state=open
Please check that there are no same open issue yet. Also read this before submiting:
http://razberry.z-wave.me/index.php?id=27
funjy
Re: New release candidate of available now!
Post by funjy »
Did you change Blue UI in this release?
There're some new bugs in it after update.
pofs
Post by pofs »
funjy wrote:Did you change Blue UI in this release?
Just some minor updates. Feel free to report the bugs ;)
sdh
Post by sdh »
I upgraded the software as described, but the UI shows older version!
RaZberry Version
RaZberry Version
RaZberry Version.tiff (193.84 KiB) Viewed 23315 times
funjy
Post by funjy »
Yes, I have the same pictrure.
Ver 1.6.0-rc1
SolarFlor
Post by SolarFlor »
same
Z-Way version v1.6.0-rc1-80-gcb6e530
pofs
Post by pofs »
The revision ID is correct. Seems someone forgot to push the tag before building package :)
Don't mind this, it will be corrected soon.
SolarFlor
Post by SolarFlor »
Do you mean that we have now the new version installed even if it appears as the old one?
pofs
Post by pofs »
SolarFlor wrote:Do you mean that we have now the new version installed even if it appears as the old one?
Yes
SolarFlor
Post by SolarFlor »
should we see something different in the Z-Way Home Automation UI ?
