Home-Automation Configuration
SolarFlor
Post by SolarFlor »
Dear all,
I have discovered that in my config.xml I don't have the following directive:
<automation-file>automation/main.js</automation-file>
Below how it appears now
<config>
    <device>/dev/ttyAMA0</device>
    <config-dir></config-dir>
    <translations-dir></translations-dir>
    <zddx-dir></zddx-dir>
    <port>8083</port>
    <http-root-dir>./htdocs</http-root-dir>
    <automation-dir>automation</automation-dir>
    <shell-script-on-save-xml>sync</shell-script-on-save-xml>
    <shell-script-on-save-http>sync</shell-script-on-save-http>
    <log-file>/var/log/z-way-server.log</log-file>
    <log-level>0</log-level>
    <http-log-file>/var/log/z-way-server.log</http-log-file>
    <http-log-level>0</http-log-level>
</config>
Should I add the above directive as well?
Also I cannot find any config.json in my raspberry.
Maybe the instructions are not update?
pofs
Re: Home-Automation Configuration
Post by pofs »
There's no automation-file parameter anymore, it is now replaced with automation-dir. It only existed before Home Automation UI was introduced.
config.json actually resides in automation/storage/configjson-06b2d3b23dce96e1619d2b53d6c947ec.json, and not intended for manual editing.
SolarFlor
Post by SolarFlor »
how we can personalise our Home-Automation? More specifically:
1) how we can add a photo of our rooms?
2) can we change the icons? I have tried to rename the icon in the widget but without success
SolarFlor
Post by SolarFlor »
Any help on the above questions?
Icons can be changed if you use one of predefined (see here: https://github.com/Z-Wave-Me/home-autom ... Icon-types). Also you can specify an url (starting with http://).
In future we will add icons selector.
Background image is not yet changable, but will be.
