HTTP command to discover a device(s) supported classes
skiv71
Post by skiv71 »
Does anyone know if i can issue a HTTP command to the z-way server to discover a devices instance and supported command class values?
I've checked the Z-way dev reference but not turned anything up.
I suppose it would be a little bit like, show interview results?
Neil
skiv71
Re: HTTP command to discover a device(s) supported classes
Post by skiv71 »
Got it.... :)
http://<ip>:8083/ZWaveAPI/Run/devices[<node>].data.nodeInfoFrame.value
skiv71
Post by skiv71 »
oops, need to differentiate between multiple instances :-/
not found the answer to this yet
/JS/Run/zway.devices[<node>] will give you a big tree. You can see instances in it and all CCs on each instance. Then .data.supported.value will give you knowledge if it is supported.
skiv71
Post by skiv71 »
Hi PoltoS,
Thanks for that...
It's a pity not contained inside a single field entry like the nodeInfoFrame.value :-/
