Hi All,
I bought RaZberry daughter card and associated Raspberry PI board and install Z-Way Software according to the manufacturer's instructions.
Then I visit the address: http://IP_OF_RASPBERRY:8083, then I choose the "(Re-) include device" to include device "Door Sensor".
Everything worked fine until I accidentally click on the "Reset Controller" on Web UI then I could not Re-Include "Door Sensor" back in to Network again.
I tried Format the SDCard, Reinstall Raspbian OS, and Reinstall the software Z-Way. Then I tried "(Re-) include device" but still does not include the device "sensor Door" on my Zwave Network.
How can I include "Door Sensor" Zwave network through software Z-Way.
Help me please!
Thanks!
LeeNguyen.
Help me..., Can't Re-Include Door sensor into WZave Network
Re: Help me..., Can't Re-Include Door sensor into WZave Netw
Exclude the device before including it again.
I tried Exclude the device before including, but still does not include the device "sensor door" on my Zwave Network
Have resolved any other way?
Thanks!
Thanks!
Please check your RaZberry manufacture date first (it is written on it under the antenna). You may have got a broken one.
This is my Razberry manufacture date first: 30.12.13
what is the problem with my Razberry ?
- IMAG1375(3).jpg (30.89 KiB) Viewed 13412 times
No, this one should be okay.
Please double-check your device manual about inclusion. It may be a bit tricky sometimes. For example, you're pressing inclusion button not fast enough, or you should wake device up first before pressing inclusion button.
Also look into the log (with "tail -f" to see real-time updates) after you press inclusion button. Is there any incoming data there?
Thanks Pofs!
I did as what you had guided, and then look at the web UI, still not seen my device is added..../
First, I plugged the battery into the device "door sensor", then I see the LED on the "door sensors" bright red and stand still.
And
Here is the log file contents obtained when I press the button "(Re-)include device" on the Web UI and then push the button on the "door sensor" 3 consecutive times :
[2014-07-30 10:38:18.080] Executing script: zway.controller.AddNodeToNetwork(1)
[2014-07-30 10:38:18.082] Adding job: Add/re-include node to network
[2014-07-30 10:38:18.090] SENDING (cb 0x07): ( 01 05 00 4A C1 07 76 )
[2014-07-30 10:38:18.102] RECEIVED ACK
[2014-07-30 10:38:18.113] RECEIVED: ( 01 07 00 4A 07 01 00 00 B4 )
[2014-07-30 10:38:18.114] SENT ACK
[2014-07-30 10:38:18.115] SETDATA controller.data.lastIncludedDevice = Empty
[2014-07-30 10:38:18.116] SETDATA controller.data.lastExcludedDevice = Empty
[2014-07-30 10:38:18.117] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2014-07-30 10:38:18.119] SETDATA controller.data.controllerState = 1 (0x00000001)
[2014-07-30 10:42:22.365] Job 0x4a (Add/re-include node to network): Job not removed before timeout (awaiting for more callbacks?)
[2014-07-30 10:42:22.366] Job 0x4a (Add/re-include node to network): Cancelling
[2014-07-30 10:42:22.367] Job 0x4a (Add/re-include node to network): fail
[2014-07-30 10:42:22.369] Adding job: Add/re-include node to network
[2014-07-30 10:42:22.381] SENDING (cb 0x05): ( 01 04 00 4A 05 B4 )
[2014-07-30 10:42:22.392] RECEIVED ACK
[2014-07-30 10:42:22.394] Removing job: Add/re-include node to network
[2014-07-30 10:42:22.439] RECEIVED: ( 01 07 00 4A 07 06 00 00 B3 )
[2014-07-30 10:42:22.441] SENT ACK
[2014-07-30 10:42:22.442] Job 0x4a (Add/re-include node to network): Done
[2014-07-30 10:42:22.443] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-07-30 10:42:22.444] Removing job: Add/re-include node to network
[2014-07-30 10:42:41.300] Job 0x4a: deleted from queue
[2014-07-30 10:42:41.335] Job 0x4a: deleted from queue
And
If seems there's no physical response from the device. Assuming the both devices are working, there could be 3 reasons why it happens:
1) you don't actually initiate pairing on device;
2) device and controller are using different radio frequency (not your case);
3) device uses low power mode for pairing, so it should be placed rather close to controller.
