Catch events and store data
Devour
Post by Devour »
Hello everyone :D
I'm from Switzerland and it's my first time here on the forum.
In the near future, I will have 60 multisensors (from Aeon Labs) and just would like to catch events when values change and then store them somewhere. I can already test ZWay with 1 multisensor. A script or custom file could be nice. Do you know how I can do it ?
Even after reading the manual of ZWay Developper, I don't understand all.
First of all, I tried, without success, to put the bind function into the URL with the JS API (like in the zWayDev manual page 42). By the way, I don’t see where to write commands in what the manual calls « the server side » .
Can you show me an example how to bind the value of a multisensor and where to write it ? (URL, script or custom file)
Thanks in advance ;)
n0ahg
Re: Catch events and store data
Post by n0ahg »
You could use Sensor values logging in automation
Devour
Post by Devour »
Z-Wave HA ?
Yes
Devour
Post by Devour »
I don't know for you, but when I launch the Z-Way HA interface, there are almost nothing inside... So I don't see what n0ahg means by logging in automation. There are no login for me. Image
Thanks again ;)
What version are you using? 1.7.2 is the latest and most stable of the official rleases.
Look at -Preferences-Automation
Click the + sign in the lower left corner. That will bring up a screen where you van select a module
In your case Sensors logging, and fill in similar to the below screen.
The logged data are stored in directory: /opt/z-way-server/automation/storage
Devour
Post by Devour »
Oh yes I see these features and I can do it now. But I don't know which version I use and how to find it. I updated Z-Way less than 2 weeks ago.
I'm not near the RaZberry so I don't see where the JSONfile is stored inside the controller. Do you know ?
Use http://Raspberry_IP:8084/ to get at the Z-Way Configuration Interface. Look there under Advanced/Firmware.
The storage directory is /opt/z-way-server/automation/storage
Devour
Post by Devour »
That function is so perfect.
Is there a way to make logging for other parameters in sensors ? Something like manufacturer, model or a specific name or any other things ?
Thanks again
Devour
Post by Devour »
If I should store more informations for any reasons or to be more flexible, what do you advise me to do ?
To use the ZAutomation API and add some UserModules or develop something with the JS API ? I'm a little bit confused with all these technologies (zDev, vDev, ZAutomation, etc..) inside the Z-Way.
Thank you for your replies
