Hello
Secure the SWM301 module (Consumption water) is compatible with the Razberry ?
thank you
Compatibility
Compatibility
Re: Compatibility
Looking at the command classes supported by device, it shouldn't have any problems working with RaZberry.
The only thing, there's no configuration xml in pepper1 db for this device yet, so you might be needed to setup configuration parameters in a hard way (expert commands)
Re: Compatibility
on pepper1 I saw that there was this module that could match but I'm not on
http://www.pepper1.net/zwavedb/device/431
Thank you
Thank you
Re: Compatibility
IIRC the Horstman devices have been renamed to Secure. So you could give it a try
Re: Compatibility
ok thank you I'll keep you posted
