I'm trying to use a ZME_ITEMP device, that should have a multilevel sensor (Temperature) and a binary sensor, but on expert GUI (z-way, with Razberry) it only shows Temperature Sensor. Also, on "Interview Results" window doesn't have a Command Class named "Binary Sensor".
I appreciate if someone can help me on this.
TIA
ZME_ITEMP don't show binary sensor
Re: ZME_ITEMP don't show binary sensor
What is the App version? and manufacturer version?
For the device ZME_ITEMP, App version is 1.0 and SDK Version is 4.54.01, I don't know what means manufacturer version.
I'm using it with a Razberry controller.
Thank you for your help.
This is an old version, it was only temperature sensor. New versions 2.0 and 2.1 are Temperature, Dry Contacts and Thermostat 3 in 1.
Ok, thank you for your answer. I understand it, but can you explain why in the photo there are a green terminal?
TIA
TIA
- 20141117_234036.jpg (436.64 KiB) Viewed 13087 times
Because it is same h/w.
Initially we made of it the cheapest temp sensor available. Then we added more functionality by adding binary sensor and thermostat. On the same h/w.
