Remote KFOB2
LAN-Opfer
Remote KFOB2
Post by LAN-Opfer »
...Hi,
I want to use the KFOB2 for switching a Fibaro FGS221 (device 2) - it is installed in the garden and to the heater control in the car.
I have the result of the interview:
Device Description
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<ZWaveDevice xmlns="http://www.pepper1.net/zwavedb/xml-schemata/z-wave" schemaVersion="2">
<descriptorVersion>1</descriptorVersion>
<deviceData>
<manufacturerId value="0115"/>
<productType value="0100"/>
<productId value="0001"/>
<libType value="03"/>
<protoVersion value="03"/>
<protoSubVersion value="43"/>
<appVersion value="01"/>
<appSubVersion value="04"/>
<basicClass value="04"/>
<genericClass value="12"/>
<specificClass value="02"/>
<optional value="true"/>
<listening value="false"/>
<routing value="true"/>
<beamSensor>0</beamSensor>
</deviceData>
<deviceDescription>
<description>
<lang xml:lang="en"/>
</description>
<wakeupNote>
</wakeupNote>
<inclusionNote>
</inclusionNote>
<productName/>
<brandName/>
<productVersion>1.4</productVersion>
</deviceDescription>
<commandClasses>
<commandClass id="002d" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0070" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0072" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0075" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0077" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0080" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0084" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0085" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0086" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="008e" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0060" version="3" supported="false" controlled="true" secure="false" inNIF="false"/>
<commandClass id="0026" version="1" supported="false" controlled="true" secure="false" inNIF="false"/>
</commandClasses>
<assocGroups>
<assocGroup number="1" maxNodes="8">
<description>
<lang xml:lang="en">Group 1</lang>
</description>
</assocGroup>
<assocGroup number="2" maxNodes="8">
<description>
<lang xml:lang="en">Group 2</lang>
</description>
</assocGroup>
<assocGroup number="3" maxNodes="8">
<description>
<lang xml:lang="en">Group 3</lang>
</description>
</assocGroup>
<assocGroup number="4" maxNodes="8">
<description>
<lang xml:lang="en">Group 4</lang>
</description>
</assocGroup>
</assocGroups>
</ZWaveDevice>
I hoped, to include a custom JavaScript code
code:
if (zway.devices[8].SensorBinary.Get(0) == 1) then
zway.devices[2].instances[0].Basic.Set(1)
elseif (zway.devices[8].SensorBinary.Get(0) == 2) then
zway.devices[2].instances[0].Basic.Set(0)
end
would switch on with key "1" and off with key "2".
But it seems to be much complicated :-(
I think, I can see it in the log, when I press a key - but I dont know, how to use it :-(
log:
[2014-11-01 17:44:18.559] RECEIVED: ( 01 0E 00 04 00 08 08 60 0D 00 01 26 04 20 00 9B )
[2014-11-01 17:44:18.560] SENT ACK
[2014-11-01 17:44:18.560] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2014-11-01 17:44:18.560] SETDATA devices.1.instances.1.commandClasses.38.data.srcNodeId = 8 (0x00000008)
[2014-11-01 17:44:18.560] SETDATA devices.1.instances.1.commandClasses.38.data.srcInstanceId = 0 (0x00000000)
[2014-11-01 17:44:18.560] SETDATA devices.1.instances.1.commandClasses.38.data.startChange = True
[2014-11-01 17:44:18.651] RECEIVED: ( 01 0C 00 04 00 08 06 60 0D 00 01 26 05 B6 )
[2014-11-01 17:44:18.651] SENT ACK
[2014-11-01 17:44:18.651] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2014-11-01 17:44:18.652] SETDATA devices.1.instances.1.commandClasses.38.data.srcNodeId = 8 (0x00000008)
[2014-11-01 17:44:18.652] SETDATA devices.1.instances.1.commandClasses.38.data.srcInstanceId = 0 (0x00000000)
[2014-11-01 17:44:18.652] SETDATA devices.1.instances.1.commandClasses.38.data.stopChange = Empty
[2014-11-01 17:57:00.855] Executing script: api("/v1/devices", { ...
[2014-11-01 17:57:03.265] RECEIVED: ( 01 0E 00 04 00 08 08 60 0D 00 02 26 04 20 00 98 )
[2014-11-01 17:57:03.265] SENT ACK
[2014-11-01 17:57:03.265] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2014-11-01 17:57:03.265] SETDATA devices.1.instances.2.commandClasses.38.data.srcNodeId = 8 (0x00000008)
[2014-11-01 17:57:03.266] SETDATA devices.1.instances.2.commandClasses.38.data.srcInstanceId = 0 (0x00000000)
[2014-11-01 17:57:03.266] SETDATA devices.1.instances.2.commandClasses.38.data.startChange = True
[2014-11-01 17:57:03.311] RECEIVED: ( 01 0C 00 04 00 08 06 60 0D 00 02 26 05 B5 )
[2014-11-01 17:57:03.311] SENT ACK
[2014-11-01 17:57:03.311] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
Could someone help me?
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
LAN-Opfer
Re: Remote KFOB2
Post by LAN-Opfer »
...is it possible, that I need to add Associations (see attached file)? How could I do this?
hardcopy
hardcopy
Uwe
LAN-Opfer
Re: Remote KFOB2
Post by LAN-Opfer »
I find out, that could send a
...8083/ZWaveAPI/Run/devices[10].Association.Set(2,3)
which do a association from remote control ("FB" Id 10) to Everspring Binary Power Switch ("Zw_Steckdose1" Id 3) with group 2 (key No. 2 + 4).
hardcopy2
hardcopy2
I would now like to add a custom JavaScript code with
zway.devices[3].SwitchBinary.data[1].val.bind
function()
zway.devices[2].instances[2].SwitchBinary.Set(this.value);
It shold create the second channel from Fibaro FGS221 ("Außensteckdosen" Id 2) as slave from Everspring Binary Power Switch ("Zw_Steckdose1" Id 3). But the code soes not work :-( I need help to correct it :D
Uwe
LAN-Opfer
Re: Remote KFOB2
Post by LAN-Opfer »
...I did it :-))
zway.devices[3].instances[0].SwitchBinary.data.level.bind
function()
Uwe
