Could somebody clarify how to use Wakeup to node parameter?
From my view battery operated node should send notification to the nearest main powered node if there are no direct route to controller. Am i right? Or it does not make sense, and i can leave default value for Wakeup to node parameter (by default it's Razberry controller)
Wakeup to node
Re: Wakeup to node
I think it ultimately has to go to RaZberry. So leave it like that as it is. The network communication organises itself.
