Virgin installation not working
dlemmink
Post by dlemmink »
service doesn't seem to start
running LD_LIBRARY_PATH=libs ./z-way-server gives the following:
failed to discover ZWay: Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
Is the hardware defective?
pofs
Re: Virgin installation not working
Post by pofs »
The log provided is too short, could be anything. Probably the console was not successfully removed from /dev/ttyAMA0.
