[HowTo] Send status updates as UDP messages
Re: [HowTo] Send status updates as UDP messages
I don't see how and why I should iterate. These bindings work perfectly for weeks from the moment they got started properly. To me it seems that the unpredicatble startup behaviour of modules is the core problem.
Anyhow it is at yet unclear to me how I should iterate the bindings. Does it have to go forever, or is there a stop criterion
As said before, I did elaborate on the code for individual devices I got from PoltoS:
this.bindFunc1 = function(zwayName)
  if (zwayName != "zway") return; // you want to bind to default zway instance
  global.ZWave[zwayName].zway.devices[2].instances[0].SwitchBinary.data.level.bind(function()
      var status = (this.value) ? "on" : "off";
      system("/opt/z-way-server/automation/storage/status.sh", "ZWay_2," + status ) ;
global.controller.on("ZWave.register", this.bindFunc1);
// UserCode module have not stop destructor, so this is commented...
// global.controller.off("ZWave.register", this.bindFunc1);
* note: this is older code that worked well under previous versions for a long time. Here I do make system calls to a script that uses netcat to send UDP messages
pofs
Post by pofs »
pz1 wrote:Anyhow it is at yet unclear to me how I should iterate the bindings. Does it have to go forever, or is there a stop criterion
Just once, before subscribing to future notifications. If zway is created before your code executes, it will be processed during iteration, otherwise you'll receive notification and handle it.
First few lines is what is missing in your code:
// process all active bindings
if (global.ZWave) {
  global.ZWave().forEach(this.bindFunc1);
// and listen for future ones
Now I got it. Initially I thought this had to go to the beginning of the file. Now I understood I had to add it just before the last line.
Both machines now got it right after the reboot. Thanks for your patience
UPDATE: I have updated the recipe in the first post. Successfully performed several restarts of both my Raspberries. So I consider the code now as stable
Successfully tested this morning with Openremote Pro 2.6 Alpha, which contains Drools 6.4. This release should work with Java 8 now.
