rc29 - Fibaro Switches - Configuration not possible
hpd
Post by hpd »
I am trying to configure fibaro FGS211 switches using expert ui. But changes will not be stored into the device. whatever parameter I change. it will be reset to origianl state after pressing "send to device" button.
zway-server.log shows nothing particular.
Z-Way 2.0.0-final on Raspberry Pi
hpd
Re: rc29 - Fibaro Switches - Configuration not possible
Post by hpd »
I continued troubleshooting with following result:
in v1.7.2 the parameters for FGS-211 in 336-010f-0400-0103-03-03-14-01-03.xml are mostly misconfigured. I sent several posts in to this forum stating this. But I never got a reply. It is really enoying to fiddle around in the ZDDX fIles for changing values from constant to rangemapped or whateverever. But once this has been done the paramters made editable can be changed and saved to the device.
in rc29 we have again the misconfigured FGS-211 in 336-010f-0400-0103-03-03-14-01-03.xml. But even changing from "constant" to "rangemapped" will not fix the problem. SOme parameters appears editable but CAN NOT be saved to the device.
Do you use new Expert UI or old Blue UI?
In 2.0 there is no "constant" problem anymore
