rc30: no update possible
LAN-Opfer
Post by LAN-Opfer »
Neither "update to lastest (v2.0.0)" or "update to v2.0.0" or "update to v2.0.0-RC31" are possible (http://xxx.xxx.xxx.xx:8084/cgi-bin/main.cgi). After clicking on "update" he responds and changes after a few seconds in the tab "general", but also after reboot is always v2.0.0-rc30 to see :-(
Disk Space on the SD card is still available. What can I do?
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
LAN-Opfer
Re: rc30: no update possible
Post by LAN-Opfer »
...here is the log
started update [2014-12-09 20:49:00.000]
  • 014-12-09 20:48:36.023] [D] [zway] SENT ACK
    [2014-12-09 20:48:36.024] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:48:36.024] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-09 20:48:36.024] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-09 20:48:36.025] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-09 20:48:36.025] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-09 20:49:09.356] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-09 20:49:09.356] [D] [zway] SENT ACK
    [2014-12-09 20:49:09.356] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:49:09.357] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-09 20:49:09.357] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-09 20:49:09.357] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-09 20:49:09.358] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-09 20:49:42.689] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-09 20:49:42.689] [D] [zway] SENT ACK
    [2014-12-09 20:49:42.689] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:49:42.690] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-09 20:49:42.690] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-09 20:49:42.690] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-09 20:49:42.691] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-09 20:50:00.395] [core] --- ZWayVDev_zway_5-0-49-1 performCommand processing: {"0":"update"}
    [2014-12-09 20:50:00.396] [zway] Adding job: SensorMultilevel V1-4 Get
    [2014-12-09 20:50:00.396] [core] --- ZWayVDev_zway_3-0-50-0 performCommand processing: {"0":"update"}
    [2014-12-09 20:50:00.397] [zway] Adding job: Meter Get (v2)
    [2014-12-09 20:50:00.398] [D] [zway] SENDING (cb 0x0d): ( 01 0A 00 13 03 03 32 01 00 25 0D FD )
    [2014-12-09 20:50:00.399] [core] --- ZWayVDev_zway_3-0-50-0 performCommand processing: {"0":"update"}
    [2014-12-09 20:50:00.401] [D] [zway] RECEIVED ACK
    [2014-12-09 20:50:00.401] [zway] Adding job: Meter Get (v2)
    [2014-12-09 20:50:00.402] [core] --- OpenWeather_4 performCommand processing: {"0":"update"}
    [2014-12-09 20:50:00.403] [core] --- ZWayVDev_zway_9-0-49-1 performCommand processing: {"0":"update"}
    [2014-12-09 20:50:00.403] [zway] Adding job: SensorMultilevel V1-4 Get
    [2014-12-09 20:50:00.403] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
    [2014-12-09 20:50:00.404] [D] [zway] SENT ACK
    [2014-12-09 20:50:00.404] [D] [zway] Delivered to Z-Wave stack
    [2014-12-09 20:50:00.417] [D] [zway] RECEIVED: ( 01 05 00 13 0D 00 E4 )
    [2014-12-09 20:50:00.417] [D] [zway] SENT ACK
    [2014-12-09 20:50:00.417] [zway] Job 0x13 (Meter Get (v2)): Delivered
    [2014-12-09 20:50:00.417] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
    [2014-12-09 20:50:00.418] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
    [2014-12-09 20:50:00.418] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
    [2014-12-09 20:50:00.418] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
    [2014-12-09 20:50:00.418] [D] [zway] SendData Response with callback 0x0d received: received by recipient
    [2014-12-09 20:50:00.419] [D] [zway] SETDATA devices.3.data.lastSend = 8000656 (0x007a1490)
    [2014-12-09 20:50:00.419] [D] [zway] Job 0x13 (Meter Get (v2)): success
    [2014-12-09 20:50:00.419] [I] [zway] Removing job: Meter Get (v2)
    [2014-12-09 20:50:00.426] [D] [zway] RECEIVED: ( 01 14 00 04 00 03 0E 32 02 21 24 00 00 00 00 00 00 00 00 00 00 D7 )
    [2014-12-09 20:50:00.427] [D] [zway] SENT ACK
    [2014-12-09 20:50:00.427] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:50:00.427] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.val = 0.000000
    [2014-12-09 20:50:00.428] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
    [2014-12-09 20:50:00.428] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
    [2014-12-09 20:50:00.428] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.previous = 0.000000
    [2014-12-09 20:50:00.429] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0 = Empty
    [2014-12-09 20:50:00.519] [D] [zway] SENDING (cb 0x0e): ( 01 0A 00 13 03 03 32 01 00 25 0E FE )
    [2014-12-09 20:50:00.521] [D] [zway] RECEIVED ACK
    [2014-12-09 20:50:00.524] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
    [2014-12-09 20:50:00.524] [D] [zway] SENT ACK
    [2014-12-09 20:50:00.525] [D] [zway] Delivered to Z-Wave stack
    [2014-12-09 20:50:00.537] [D] [zway] RECEIVED: ( 01 05 00 13 0E 00 E7 )
    [2014-12-09 20:50:00.538] [D] [zway] SENT ACK
    [2014-12-09 20:50:00.538] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
    [2014-12-09 20:50:00.538] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
    [2014-12-09 20:50:00.538] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 6 (0x00000006)
    [2014-12-09 20:50:00.539] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
    [2014-12-09 20:50:00.539] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
    [2014-12-09 20:50:00.539] [D] [zway] SendData Response with callback 0x0e received: received by recipient
    [2014-12-09 20:50:00.539] [D] [zway] SETDATA devices.3.data.lastSend = 8000664 (0x007a1498)
    [2014-12-09 20:50:00.539] [D] [zway] Job 0x13 (Meter Get (v2)): success
    [2014-12-09 20:50:00.540] [I] [zway] Removing job: Meter Get (v2)
    [2014-12-09 20:50:00.548] [D] [zway] RECEIVED: ( 01 14 00 04 00 03 0E 32 02 21 24 00 00 00 00 00 00 00 00 00 00 D7 )
    [2014-12-09 20:50:00.548] [D] [zway] SENT ACK
    [2014-12-09 20:50:00.549] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:50:00.549] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.val = 0.000000
    [2014-12-09 20:50:00.549] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
    [2014-12-09 20:50:00.550] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
    [2014-12-09 20:50:00.550] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0.previous = 0.000000
    [2014-12-09 20:50:00.550] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.0 = Empty
    [2014-12-09 20:50:16.022] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-09 20:50:16.022] [D] [zway] SENT ACK
    [2014-12-09 20:50:16.022] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:50:16.023] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-09 20:50:16.023] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-09 20:50:16.024] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-09 20:50:16.024] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-09 20:50:20.545] [D] [zway] Job 0x13: deleted from queue
    [2014-12-09 20:50:20.650] [D] [zway] Job 0x13: deleted from queue
    [2014-12-09 20:50:39.753] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
    [2014-12-09 20:50:39.753] [D] [zway] SENT ACK
    [2014-12-09 20:50:39.754] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:50:39.754] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
    [2014-12-09 20:50:39.754] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1418154639 (0x5487528f)
    [2014-12-09 20:50:39.755] [D] [zway] SETDATA devices.9.data.isAwake = True
    [2014-12-09 20:50:39.755] [D] [zway] SETDATA devices.9.data.lastSend = 8004492 (0x007a238c)
    [2014-12-09 20:50:39.755] [D] [zway] SETDATA devices.9.data.lastNonceGet = 8003492 (0x007a1fa4)
    [2014-12-09 20:50:39.755] [D] [zway] Running wakeup handler for node 9
    [2014-12-09 20:50:39.756] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1418154639 (0x5487528f)
    [2014-12-09 20:50:39.756] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
    [2014-12-09 20:50:39.756] [I] [zway] Adding job: Wakeup Sleep
    [2014-12-09 20:50:39.829] [D] [zway] SENDING (cb 0x0f): ( 01 09 00 13 09 02 31 04 05 0F D1 )
    [2014-12-09 20:50:39.831] [D] [zway] RECEIVED ACK
    [2014-12-09 20:50:39.834] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
    [2014-12-09 20:50:39.835] [D] [zway] SENT ACK
    [2014-12-09 20:50:39.835] [D] [zway] Delivered to Z-Wave stack
    [2014-12-09 20:50:39.847] [D] [zway] RECEIVED: ( 01 05 00 13 0F 00 E6 )
    [2014-12-09 20:50:39.847] [D] [zway] SENT ACK
    [2014-12-09 20:50:39.847] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): Delivered
    [2014-12-09 20:50:39.848] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
    [2014-12-09 20:50:39.848] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
    [2014-12-09 20:50:39.848] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 12 (0x0000000c)
    [2014-12-09 20:50:39.849] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
    [2014-12-09 20:50:39.849] [D] [zway] SendData Response with callback 0x0f received: received by recipient
    [2014-12-09 20:50:39.849] [D] [zway] SETDATA devices.9.data.lastSend = 8004500 (0x007a2394)
    [2014-12-09 20:50:39.850] [D] [zway] Job 0x13 (SensorMultilevel V1-4 Get): success
    [2014-12-09 20:50:39.850] [I] [zway] Removing job: SensorMultilevel V1-4 Get
    [2014-12-09 20:50:39.862] [D] [zway] RECEIVED: ( 01 0C 00 04 00 09 06 31 05 01 22 00 CD 22 )
    [2014-12-09 20:50:39.862] [D] [zway] SENT ACK
    [2014-12-09 20:50:39.863] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
    [2014-12-09 20:50:39.863] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
    [2014-12-09 20:50:39.864] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
    [2014-12-09 20:50:39.864] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.1.val = 20.500000
    [2014-12-09 20:50:39.867] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.1.scaleString = "°C"
    [2014-12-09 20:50:39.868] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.1 = Empty
    [2014-12-09 20:50:39.916] [D] [zway] SETDATA devices.9.instances.0.commandClasses.67.data.1.setVal = 23.600000
    [2014-12-09 20:50:39.917] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
    [2014-12-09 20:50:39.917] [I] [zway] Removing job: Wakeup Sleep
    [2014-12-09 20:50:39.917] [I] [zway] Adding job: ThermostatSetPoint Set
    [2014-12-09 20:50:39.917] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1418154639 (0x5487528f)
    [2014-12-09 20:50:39.918] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
    [2014-12-09 20:50:39.918] [I] [zway] Adding job: Wakeup Sleep
    [2014-12-09 20:50:39.918] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
    [2014-12-09 20:50:39.918] [I] [zway] Removing job: Wakeup Sleep
    [2014-12-09 20:50:39.919] [I] [zway] Adding job: ThermostatSetPoint Get
    [2014-12-09 20:50:39.927] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1418154639 (0x5487528f)
    [2014-12-09 20:50:39.928] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
    [2014-12-09 20:50:39.928] [I] [zway] Adding job: Wakeup Sleep
    [2014-12-09 20:50:39.945] [D] [zway] SENDING (cb 0x10): ( 01 0D 00 13 09 06 43 01 01 22 00 EC 05 10 76 )
    [2014-12-09 20:50:39.956] [D] [zway] RECEIVED ACK
    [2014-12-09 20:50:39.957] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
    [2014-12-09 20:50:39.957] [D] [zway] SENT ACK
    [2014-12-09 20:50:39.957] [D] [zway] Delivered to Z-Wave stack
    [2014-12-09 20:50:39.964] [D] [zway] RECEIVED: ( 01 05 00 13 10 00 F9 )
    [2014-12-09 20:50:39.964] [D] [zway] SENT ACK
    [2014-12-09 20:50:39.964] [I] [zway] Job 0x13 (ThermostatSetPoint Set): Delivered
    [2014-12-09 20:50:39.964] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
    [2014-12-09 20:50:39.965] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 9 (0x00000009)
    [2014-12-09 20:50:39.965] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 7 (0x00000007)
    [2014-12-09 20:50:39.965] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
    [2014-12-09 20:50:39.965] [D] [zway] SendData Response with callback 0x10 received: received by recipient
    [2014-12-09 20:50:39.965] [D] [zway] SETDATA devices.9.data.lastSend = 8004509 (0x007a239d)
    [2014-12-09 20:50:39.965] [D] [zway] Job 0x13 (ThermostatSetPoint Set): success
    [2014-12-09 20:50:39.966] [I] [zway] Removing job: ThermostatSetPoint Set
Please run install script from the shell (like you did on the very first install) and show us the output
LAN-Opfer
Post by LAN-Opfer »
... used my backup-image from v1.7.2 and then the update to v2.0.0 worked
Uwe
It is always good for the WAF* to make an image of the latest stable installation. Even better to write it to a spare ID card, so can quickly get your installation up and running after disaster :D
*) wife admiration factor
