Cannot Start Z-Way
neonemo
Cannot Start Z-Way
Post by neonemo »
In the export UI, I received: Error handling data from server
<IP>:8083/ZWaveAPI/Data/0 results in a 404
Interesting thing is it worked... and then stopped working. I removed the whole z-way-server directory and reran the install script.
Any next steps? Z-way-server logs below.
[2014-12-09 19:37:33.040] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2014-12-09 19:37:33.124] [I] [core] Executing script: // This script transforms old formats to new ...
[2014-12-09 19:37:33.245] [I] [core] Executing script: ;!function(exports, undefined) { ...
[2014-12-09 19:37:33.362] [I] [core] Executing script: //     Underscore.js 1.6.0 ...
[2014-12-09 19:37:33.466] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2014-12-09 19:37:33.484] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2014-12-09 19:37:33.616] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2014-12-09 19:37:33.642] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2014-12-09 19:37:33.653] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2014-12-09 19:37:33.675] [I] [core] Executing script: /*** Main Automation webserver module ***************************************** ...
[2014-12-09 19:37:33.681] [I] [core] Executing script: // Make this testable by pulling in underscore from the parent module ...
[2014-12-09 19:37:33.693] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2014-12-09 19:37:33.766] [I] [core] --- Loading ZAutomation classes
[2014-12-09 19:37:33.913] [I] [core] Starting ZWay Automation webserver
[2014-12-09 19:37:33.919] [I] [core] Loading modules...
[2014-12-09 19:37:33.941] [I] [core] Loading module GroupDevices from modules/GroupDevices
[2014-12-09 19:37:33.946] [I] [core] Executing script: /*** GroupDevices Z-Way HA module ******************************************* ...
[2014-12-09 19:37:33.959] [I] [core] Loading module OpenWeather from modules/OpenWeather
[2014-12-09 19:37:33.964] [I] [core] Executing script: /*** OpenWeather Z-Way HA module ******************************************* ...
[2014-12-09 19:37:33.972] [I] [core] Loading module NotificationSMSru from modules/NotificationSMSru
[2014-12-09 19:37:33.976] [I] [core] Executing script: /*** NotificationSMSru Z-Way HA module ******************************************* ...
[2014-12-09 19:37:33.979] [I] [core] Loading module SensorValueLogging from modules/SensorValueLogging
[2014-12-09 19:37:33.983] [I] [core] Executing script: /*** SensorValueLogging Z-Way Home Automation module ************************************* ...
[2014-12-09 19:37:33.985] [I] [core] Loading module RGB from modules/RGB
[2014-12-09 19:37:33.992] [I] [core] Executing script: /*** RGB Z-Way HA module ******************************************* ...
[2014-12-09 19:37:33.997] [I] [core] Loading module YandexProbki from modules/YandexProbki
[2014-12-09 19:37:34.001] [I] [core] Executing script: /*** YandexProbki Z-Way HA module ******************************************* ...
[2014-12-09 19:37:34.005] [I] [core] Loading module AutoOff from modules/AutoOff
[2014-12-09 19:37:34.009] [I] [core] Executing script: /*** AutoOff Z-Way Home Automation module ************************************* ...
[2014-12-09 19:37:34.011] [I] [core] Loading module AutoLock from modules/AutoLock
[2014-12-09 19:37:34.015] [I] [core] Executing script: /*** AutoLock Z-Way Home Automation module ************************************* ...
[2014-12-09 19:37:34.017] [I] [core] Loading module SwitchControlGenerator from modules/SwitchControlGenerator
[2014-12-09 19:37:34.025] [I] [core] Executing script: /*** SwitchControlGenerator Z-Way HA module ******************************************* ...
[2014-12-09 19:37:34.028] [I] [core] Loading module LightScene from modules/LightScene
[2014-12-09 19:37:34.032] [I] [core] Executing script: /*** LightScene Z-Way HA module ******************************************* ...
[2014-12-09 19:37:34.035] [I] [core] Loading module ThermostatDevice from modules/ThermostatDevice
[2014-12-09 19:37:34.039] [I] [core] Executing script: /*** ThermostatDevice Z-Way HA module ******************************************* ...
[2014-12-09 19:37:34.042] [I] [core] Loading module SmartLight from modules/SmartLight
[2014-12-09 19:37:34.047] [I] [core] Executing script: /*** SmartLight Z-Way Home Automation module ************************************* ...
[2014-12-09 19:37:34.049] [I] [core] Loading module ZWave from modules/ZWave
[2014-12-09 19:37:34.078] [I] [core] Executing script: /*** Z-Wave Binding module ******************************************************** ...
[2014-12-09 19:37:34.117] [I] [core] Instantiating module 2 from class ZWave
[2014-12-09 19:37:34.122] [I] [core] --- Starting module Z-Wave binding
[2014-12-09 19:37:34.390] [D] [zway] SETDATA controller.data = Empty
[2014-12-09 19:37:34.390] [D] [zway] SETDATA controller.data.nodeId = Empty
[2014-12-09 19:37:34.391] [D] [zway] SETDATA controller.data.homeId = Empty
[2014-12-09 19:37:34.391] [D] [zway] SETDATA controller.data.SUCNodeId = Empty
[2014-12-09 19:37:34.391] [D] [zway] SETDATA controller.data.isPrimary = Empty
[2014-12-09 19:37:34.391] [D] [zway] SETDATA controller.data.isInOthersNetwork = Empty
[2014-12-09 19:37:34.391] [D] [zway] SETDATA controller.data.isRealPrimary = Empty
[2014-12-09 19:37:34.391] [D] [zway] SETDATA controller.data.isSUC = Empty
[2014-12-09 19:37:34.392] [D] [zway] SETDATA controller.data.SISPresent = Empty
[2014-12-09 19:37:34.392] [D] [zway] SETDATA controller.data.libType = Empty
[2014-12-09 19:37:34.392] [D] [zway] SETDATA controller.data.SDK = Empty
[2014-12-09 19:37:34.392] [D] [zway] SETDATA controller.data.ZWlibMajor = Empty
[2014-12-09 19:37:34.392] [D] [zway] SETDATA controller.data.ZWlibMinor = Empty
[2014-12-09 19:37:34.393] [D] [zway] SETDATA controller.data.ZWLib = Empty
[2014-12-09 19:37:34.393] [D] [zway] SETDATA controller.data.ZWVersion = Empty
[2014-12-09 19:37:34.393] [D] [zway] SETDATA controller.data.ZWaveChip = Empty
[2014-12-09 19:37:34.393] [D] [zway] SETDATA controller.data.APIVersion = Empty
[2014-12-09 19:37:34.393] [D] [zway] SETDATA controller.data.manufacturerId = Empty
[2014-12-09 19:37:34.393] [D] [zway] SETDATA controller.data.vendor = Empty
[2014-12-09 19:37:34.394] [D] [zway] SETDATA controller.data.manufacturerProductType = Empty
[2014-12-09 19:37:34.394] [D] [zway] SETDATA controller.data.manufacturerProductId = Empty
[2014-12-09 19:37:34.394] [D] [zway] SETDATA controller.data.capabilities = Empty
[2014-12-09 19:37:34.394] [D] [zway] SETDATA controller.data.controllerState = Empty
[2014-12-09 19:37:34.395] [D] [zway] SETDATA controller.data.nonManagmentJobs = Empty
[2014-12-09 19:37:34.395] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2014-12-09 19:37:34.395] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2014-12-09 19:37:34.395] [D] [zway] SETDATA controller.data.secureInclusion = Empty
[2014-12-09 19:37:34.395] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = Empty
[2014-12-09 19:37:34.395] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = Empty
[2014-12-09 19:37:34.396] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = Empty
[2014-12-09 19:37:34.396] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = Empty
[2014-12-09 19:37:34.396] [D] [zway] SETDATA controller.data.countJobs = Empty
[2014-12-09 19:37:34.396] [D] [zway] SETDATA controller.data.memoryGetAddress = Empty
[2014-12-09 19:37:34.396] [D] [zway] SETDATA controller.data.memoryGetData = Empty
[2014-12-09 19:37:34.396] [D] [zway] SETDATA controller.data.functionClasses = Empty
[2014-12-09 19:37:34.397] [D] [zway] SETDATA controller.data.functionClassesNames = Empty
[2014-12-09 19:37:34.397] [D] [zway] SETDATA controller.data.softwareRevisionVersion = Empty
[2014-12-09 19:37:34.397] [D] [zway] SETDATA controller.data.softwareRevisionId = Empty
[2014-12-09 19:37:34.397] [D] [zway] SETDATA controller.data.softwareRevisionDate = Empty
[2014-12-09 19:37:34.397] [D] [zway] SETDATA controller.data.uuid = Empty
[2014-12-09 19:37:34.398] [D] [zway] SETDATA controller.data.nodeId = 0 (0x00000000)
[2014-12-09 19:37:34.398] [D] [zway] SETDATA controller.data.homeId = 0 (0x00000000)
[2014-12-09 19:37:34.398] [D] [zway] SETDATA controller.data.SUCNodeId = 0 (0x00000000)
[2014-12-09 19:37:34.398] [D] [zway] SETDATA controller.data.isPrimary = False
[2014-12-09 19:37:34.398] [D] [zway] SETDATA controller.data.isInOthersNetwork = False
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.isRealPrimary = False
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.isSUC = False
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.SISPresent = False
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.ZWLib = 0 (0x00000000)
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.ZWlibMajor = 0 (0x00000000)
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.ZWlibMinor = 0 (0x00000000)
[2014-12-09 19:37:34.399] [D] [zway] SETDATA controller.data.ZWVersion = 0 (0x00000000)
[2014-12-09 19:37:34.400] [D] [zway] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2014-12-09 19:37:34.400] [D] [zway] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2014-12-09 19:37:34.400] [D] [zway] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2014-12-09 19:37:34.400] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-12-09 19:37:34.400] [D] [zway] SETDATA controller.data.nonManagmentJobs = 0 (0x00000000)
[2014-12-09 19:37:34.400] [D] [zway] SETDATA controller.data.secureInclusion = True
[2014-12-09 19:37:34.401] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:34.401] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:34.401] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:34.401] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:34.401] [D] [zway] SETDATA controller.data.countJobs = False
[2014-12-09 19:37:34.401] [D] [zway] SETDATA controller.data.softwareRevisionVersion = "v2.0.0"
[2014-12-09 19:37:34.402] [D] [zway] SETDATA controller.data.softwareRevisionId = "a064f5408850947aed035bc9170e1fa04f0fd2ec"
[2014-12-09 19:37:34.402] [D] [zway] SETDATA controller.data.softwareRevisionDate = "2014-12-08 19:54:26 +0300"
[2014-12-09 19:37:34.402] [D] [zway] SETDATA controller.data.functionClasses = int[55]
[2014-12-09 19:37:34.403] [D] [zway]   [00] 2
[2014-12-09 19:37:34.403] [D] [zway]   [01] 3
[2014-12-09 19:37:34.403] [D] [zway]   [02] 4
[2014-12-09 19:37:34.403] [D] [zway]   [03] 5
[2014-12-09 19:37:34.403] [D] [zway]   [04] 6
[2014-12-09 19:37:34.403] [D] [zway]   [05] 7
[2014-12-09 19:37:34.404] [D] [zway]   [06] 8
[2014-12-09 19:37:34.404] [D] [zway]   [07] 18
[2014-12-09 19:37:34.404] [D] [zway]   [08] 19
[2014-12-09 19:37:34.404] [D] [zway]   [09] 21
[2014-12-09 19:37:34.404] [D] [zway]   [10] 22
[2014-12-09 19:37:34.404] [D] [zway]   [11] 23
[2014-12-09 19:37:34.405] [D] [zway]   [12] 32
[2014-12-09 19:37:34.405] [D] [zway]   [13] 33
[2014-12-09 19:37:34.405] [D] [zway]   [14] 34
[2014-12-09 19:37:34.405] [D] [zway]   [15] 35
[2014-12-09 19:37:34.405] [D] [zway]   [16] 36
[2014-12-09 19:37:34.405] [D] [zway]   [17] 39
[2014-12-09 19:37:34.405] [D] [zway]   [18] 41
[2014-12-09 19:37:34.406] [D] [zway]   [19] 42
[2014-12-09 19:37:34.406] [D] [zway]   [20] 43
[2014-12-09 19:37:34.406] [D] [zway]   [21] 44
[2014-12-09 19:37:34.406] [D] [zway]   [22] 45
[2014-12-09 19:37:34.406] [D] [zway]   [23] 65
[2014-12-09 19:37:34.406] [D] [zway]   [24] 66
[2014-12-09 19:37:34.406] [D] [zway]   [25] 68
[2014-12-09 19:37:34.406] [D] [zway]   [26] 70
[2014-12-09 19:37:34.407] [D] [zway]   [27] 71
[2014-12-09 19:37:34.407] [D] [zway]   [28] 72
[2014-12-09 19:37:34.407] [D] [zway]   [29] 73
[2014-12-09 19:37:34.407] [D] [zway]   [30] 74
[2014-12-09 19:37:34.407] [D] [zway]   [31] 75
[2014-12-09 19:37:34.407] [D] [zway]   [32] 76
[2014-12-09 19:37:34.407] [D] [zway]   [33] 77
[2014-12-09 19:37:34.408] [D] [zway]   [34] 80
[2014-12-09 19:37:34.408] [D] [zway]   [35] 81
[2014-12-09 19:37:34.408] [D] [zway]   [36] 82
[2014-12-09 19:37:34.408] [D] [zway]   [37] 83
[2014-12-09 19:37:34.408] [D] [zway]   [38] 84
[2014-12-09 19:37:34.408] [D] [zway]   [39] 85
[2014-12-09 19:37:34.409] [D] [zway]   [40] 86
[2014-12-09 19:37:34.409] [D] [zway]   [41] 87
[2014-12-09 19:37:34.409] [D] [zway]   [42] 96
[2014-12-09 19:37:34.409] [D] [zway]   [43] 97
[2014-12-09 19:37:34.409] [D] [zway]   [44] 98
[2014-12-09 19:37:34.409] [D] [zway]   [45] 99
[2014-12-09 19:37:34.409] [D] [zway]   [46] 128
[2014-12-09 19:37:34.410] [D] [zway]   [47] 186
[2014-12-09 19:37:34.410] [D] [zway]   [48] 190
[2014-12-09 19:37:34.410] [D] [zway]   [49] 210
[2014-12-09 19:37:34.410] [D] [zway]   [50] 211
[2014-12-09 19:37:34.410] [D] [zway]   [51] 242
[2014-12-09 19:37:34.410] [D] [zway]   [52] 243
[2014-12-09 19:37:34.410] [D] [zway]   [53] 244
[2014-12-09 19:37:34.410] [D] [zway]   [54] 245
[2014-12-09 19:37:34.411] [D] [zway] SETDATA controller.data.functionClassesNames = string[55]
[2014-12-09 19:37:34.411] [D] [zway]   [00] "SerialAPIGetInitData"
[2014-12-09 19:37:34.411] [D] [zway]   [01] "SerialAPIApplicationNodeInformation"
[2014-12-09 19:37:34.411] [D] [zway]   [02] "ApplicationCommandHandler"
[2014-12-09 19:37:34.412] [D] [zway]   [03] "GetControllerCapabilities"
[2014-12-09 19:37:34.412] [D] [zway]   [04] "SerialAPISetTimeouts"
[2014-12-09 19:37:34.412] [D] [zway]   [05] "GetSerialAPICapabilities"
[2014-12-09 19:37:34.412] [D] [zway]   [06] "SerialAPISoftReset"
[2014-12-09 19:37:34.412] [D] [zway]   [07] "SendNodeInformation"
[2014-12-09 19:37:34.412] [D] [zway]   [08] "SendData"
[2014-12-09 19:37:34.412] [D] [zway]   [09] "GetVersion"
[2014-12-09 19:37:34.412] [D] [zway]   [10] "SendDataAbort"
[2014-12-09 19:37:34.413] [D] [zway]   [11] "RFPowerLevelSet"
[2014-12-09 19:37:34.413] [D] [zway]   [12] "GetHomeId"
[2014-12-09 19:37:34.413] [D] [zway]   [13] "MemoryGetByte"
[2014-12-09 19:37:34.413] [D] [zway]   [14] "MemoryPutByte"
[2014-12-09 19:37:34.413] [D] [zway]   [15] "MemoryGetBuffer"
[2014-12-09 19:37:34.413] [D] [zway]   [16] "MemoryPutBuffer"
[2014-12-09 19:37:34.413] [D] [zway]   [17] "FlashAutoProgSet"
[2014-12-09 19:37:34.414] [D] [zway]   [18] "NVMGetId"
[2014-12-09 19:37:34.414] [D] [zway]   [19] "NVMExtReadLongBuffer"
[2014-12-09 19:37:34.414] [D] [zway]   [20] "NVMExtWriteLongBuffer"
[2014-12-09 19:37:34.414] [D] [zway]   [21] "NVMExtReadLongByte"
[2014-12-09 19:37:34.414] [D] [zway]   [22] "NVMExtWriteLongByte"
[2014-12-09 19:37:34.415] [D] [zway]   [23] "GetNodeProtocolInformation"
[2014-12-09 19:37:34.415] [D] [zway]   [24] "SetDefault"
[2014-12-09 19:37:34.415] [D] [zway]   [25] "ReplicationReceiveComplete"
[2014-12-09 19:37:34.415] [D] [zway]   [26] "AssignReturnRoute"
[2014-12-09 19:37:34.415] [D] [zway]   [27] "DeleteReturnRoute"
[2014-12-09 19:37:34.415] [D] [zway]   [28] "RequestNodeNeighbourUpdate"
[2014-12-09 19:37:34.415] [D] [zway]   [29] "ApplicationNodeUpdate"
[2014-12-09 19:37:34.415] [D] [zway]   [30] "AddNodeToNetwork"
[2014-12-09 19:37:34.416] [D] [zway]   [31] "RemoveNodeFromNetwork"
[2014-12-09 19:37:34.416] [D] [zway]   [32] "CreateNewPrimary"
[2014-12-09 19:37:34.416] [D] [zway]   [33] "ControllerChange"
[2014-12-09 19:37:34.416] [D] [zway]   [34] "SetLearnMode"
[2014-12-09 19:37:34.416] [D] [zway]   [35] "AssignSUCReturnRoute"
[2014-12-09 19:37:34.416] [D] [zway]   [36] "EnableSUC"
[2014-12-09 19:37:34.416] [D] [zway]   [37] "RequestNetworkUpdate"
[2014-12-09 19:37:34.417] [D] [zway]   [38] "SetSUCNodeId"
[2014-12-09 19:37:34.417] [D] [zway]   [39] "DeleteSUCReturnRoute"
[2014-12-09 19:37:34.417] [D] [zway]   [40] "GetSUCNodeId"
[2014-12-09 19:37:34.417] [D] [zway]   [41] "SendSUCNodeId"
[2014-12-09 19:37:34.417] [D] [zway]   [42] "RequestNodeInformation"
[2014-12-09 19:37:34.417] [D] [zway]   [43] "RemoveFailedNode"
[2014-12-09 19:37:34.417] [D] [zway]   [44] "IsFailedNode"
[2014-12-09 19:37:34.418] [D] [zway]   [45] "ReplaceFailedNode"
[2014-12-09 19:37:34.418] [D] [zway]   [46] "GetRoutingTableLine"
[2014-12-09 19:37:34.418] [D] [zway]   [47] "RFPowerLevelGet"
[2014-12-09 19:37:34.418] [D] [zway]   [48] "SendTestFrame"
[2014-12-09 19:37:34.418] [D] [zway]   [49] "WatchDogStart"
[2014-12-09 19:37:34.418] [D] [zway]   [50] "WatchDogStop"
[2014-12-09 19:37:34.419] [D] [zway]   [51] "ZMEFreqChange"
[2014-12-09 19:37:34.419] [D] [zway]   [52] "ZMERestore"
[2014-12-09 19:37:34.419] [D] [zway]   [53] "ZMEBootloaderFlash"
[2014-12-09 19:37:34.419] [D] [zway]   [54] "ZMECapabilities"
[2014-12-09 19:37:34.419] [D] [zway] Opened device: /dev/ttyAMA0
[2014-12-09 19:37:34.420] [D] [zway] Worker thread successfully created
[2014-12-09 19:37:34.424] [D] [zway] Worker thread entry point
[2014-12-09 19:37:34.441] [I] [zway] Adding job: Get controller info and supported function classes
[2014-12-09 19:37:34.445] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-09 19:37:34.651] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-09 19:37:34.651] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-09 19:37:34.855] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-09 19:37:34.855] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-09 19:37:35.060] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-09 19:37:35.060] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-12-09 19:37:35.060] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2014-12-09 19:37:35.060] [C] [zway] Get Serial API Capabilities returned zero.
[2014-12-09 19:37:35.061] [I] [zway] Removing job: Get controller info and supported function classes
[2014-12-09 19:37:35.071] [D] [zway] Worker thread exit point
[2014-12-09 19:37:35.072] [D] [zway] Worker thread successfully finished
[2014-12-09 19:37:35.132] [I] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
[2014-12-09 19:37:35.136] [I] [core] Loading module Camera from modules/Camera
[2014-12-09 19:37:35.141] [I] [core] Executing script: /*** Camera Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.162] [I] [core] Loading module ScheduledScene from modules/ScheduledScene
[2014-12-09 19:37:35.166] [I] [core] Executing script: /*** ScheduledScene Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.168] [I] [core] Loading module TagOnOff from modules/TagOnOff
[2014-12-09 19:37:35.172] [I] [core] Executing script: /*** TagOnOff Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.175] [I] [core] Loading module RoundRobinScenes from modules/RoundRobinScenes
[2014-12-09 19:37:35.179] [I] [core] Executing script: /*** RoundRobinScenes Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.181] [I] [core] Loading module HTTPDevice from modules/HTTPDevice
[2014-12-09 19:37:35.188] [I] [core] Executing script: /*** HTTPDevice Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.191] [I] [core] Loading module CustomUserCodeLoader from modules/CustomUserCodeLoader
[2014-12-09 19:37:35.195] [I] [core] Executing script:   /*** CustomUserCodeLoader ZAutomation module **************************************** ...
[2014-12-09 19:37:35.200] [I] [core] Loading module Cron from modules/Cron
[2014-12-09 19:37:35.206] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2014-12-09 19:37:35.223] [I] [core] Instantiating module 1 from class Cron
[2014-12-09 19:37:35.231] [I] [core] --- Starting module Cron scheduler
[2014-12-09 19:37:35.266] [I] [core] Loading module SensorsPolling from modules/SensorsPolling
[2014-12-09 19:37:35.270] [I] [core] Executing script: /*** SensorsPolling Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.273] [I] [core] Loading module Notification from modules/Notification
[2014-12-09 19:37:35.277] [I] [core] Executing script: /*** Notification Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.280] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2014-12-09 19:37:35.286] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.289] [I] [core] Loading module OpenRemoteHelpers from modules/OpenRemoteHelpers
[2014-12-09 19:37:35.329] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2014-12-09 19:37:35.367] [I] [core] Executing script: /* RaZOR ...
[2014-12-09 19:37:35.370] [I] [core] Loading module ImportRemoteHA from modules/ImportRemoteHA
[2014-12-09 19:37:35.377] [I] [core] Executing script: /*** ImportRemoteHA Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.380] [I] [core] Loading module CustomUserCode from modules/CustomUserCode
[2014-12-09 19:37:35.383] [I] [core] Executing script:   /*** CustomUserCode ZAutomation module **************************************** ...
[2014-12-09 19:37:35.388] [I] [core] Loading module SensorsPollingLogging from modules/SensorsPollingLogging
[2014-12-09 19:37:35.393] [I] [core] Executing script: /*** SensorsPollingLogging Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.396] [I] [core] Loading module DelayedScene from modules/DelayedScene
[2014-12-09 19:37:35.400] [I] [core] Executing script: /*** DelayedScene Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.403] [I] [core] Loading module SecurityMode from modules/SecurityMode
[2014-12-09 19:37:35.410] [I] [core] Executing script: /*** SecurityMode Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.413] [I] [core] Loading module HomeKitGate from modules/HomeKitGate
[2014-12-09 19:37:35.420] [I] [core] Executing script: /* ...
[2014-12-09 19:37:35.424] [I] [core] Loading module BatteryPolling from modules/BatteryPolling
[2014-12-09 19:37:35.429] [I] [core] Executing script: /*** BatteryPolling Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.432] [I] [core] Loading module LogicalRules from modules/LogicalRules
[2014-12-09 19:37:35.440] [I] [core] Executing script: /*** LogicalRules Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.443] [I] [core] Loading module DummyDevice from modules/DummyDevice
[2014-12-09 19:37:35.447] [I] [core] Executing script: /*** DummyDevice Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.450] [I] [core] Loading module BindDevices from modules/BindDevices
[2014-12-09 19:37:35.454] [I] [core] Executing script: /*** BindDevices Z-Way HA module ******************************************* ...
[2014-12-09 19:37:35.457] [I] [core] Starting automation...
[2014-12-09 19:37:35.571] [I] [core] Starting storage...
[2014-12-09 19:37:35.576] [I] [core] ZWay Automation started
[2014-12-09 19:37:35.590] [I] [core] Terminating Z-Wave binding
[2014-12-09 19:37:40.598] [I] [core] Restarting Z-Wave binding
[2014-12-09 19:37:40.835] [D] [zway] SETDATA controller.data = Empty
[2014-12-09 19:37:40.836] [D] [zway] SETDATA controller.data.nodeId = Empty
[2014-12-09 19:37:40.836] [D] [zway] SETDATA controller.data.homeId = Empty
[2014-12-09 19:37:40.836] [D] [zway] SETDATA controller.data.SUCNodeId = Empty
[2014-12-09 19:37:40.836] [D] [zway] SETDATA controller.data.isPrimary = Empty
[2014-12-09 19:37:40.836] [D] [zway] SETDATA controller.data.isInOthersNetwork = Empty
[2014-12-09 19:37:40.836] [D] [zway] SETDATA controller.data.isRealPrimary = Empty
[2014-12-09 19:37:40.837] [D] [zway] SETDATA controller.data.isSUC = Empty
[2014-12-09 19:37:40.837] [D] [zway] SETDATA controller.data.SISPresent = Empty
[2014-12-09 19:37:40.837] [D] [zway] SETDATA controller.data.libType = Empty
[2014-12-09 19:37:40.837] [D] [zway] SETDATA controller.data.SDK = Empty
[2014-12-09 19:37:40.837] [D] [zway] SETDATA controller.data.ZWlibMajor = Empty
[2014-12-09 19:37:40.838] [D] [zway] SETDATA controller.data.ZWlibMinor = Empty
[2014-12-09 19:37:40.838] [D] [zway] SETDATA controller.data.ZWLib = Empty
[2014-12-09 19:37:40.838] [D] [zway] SETDATA controller.data.ZWVersion = Empty
[2014-12-09 19:37:40.838] [D] [zway] SETDATA controller.data.ZWaveChip = Empty
[2014-12-09 19:37:40.838] [D] [zway] SETDATA controller.data.APIVersion = Empty
[2014-12-09 19:37:40.839] [D] [zway] SETDATA controller.data.manufacturerId = Empty
[2014-12-09 19:37:40.839] [D] [zway] SETDATA controller.data.vendor = Empty
[2014-12-09 19:37:40.839] [D] [zway] SETDATA controller.data.manufacturerProductType = Empty
[2014-12-09 19:37:40.839] [D] [zway] SETDATA controller.data.manufacturerProductId = Empty
[2014-12-09 19:37:40.839] [D] [zway] SETDATA controller.data.capabilities = Empty
[2014-12-09 19:37:40.840] [D] [zway] SETDATA controller.data.controllerState = Empty
[2014-12-09 19:37:40.840] [D] [zway] SETDATA controller.data.nonManagmentJobs = Empty
[2014-12-09 19:37:40.840] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2014-12-09 19:37:40.840] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2014-12-09 19:37:40.840] [D] [zway] SETDATA controller.data.secureInclusion = Empty
[2014-12-09 19:37:40.840] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = Empty
[2014-12-09 19:37:40.841] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = Empty
[2014-12-09 19:37:40.841] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = Empty
[2014-12-09 19:37:40.841] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = Empty
[2014-12-09 19:37:40.841] [D] [zway] SETDATA controller.data.countJobs = Empty
[2014-12-09 19:37:40.841] [D] [zway] SETDATA controller.data.memoryGetAddress = Empty
[2014-12-09 19:37:40.842] [D] [zway] SETDATA controller.data.memoryGetData = Empty
[2014-12-09 19:37:40.842] [D] [zway] SETDATA controller.data.functionClasses = Empty
[2014-12-09 19:37:40.842] [D] [zway] SETDATA controller.data.functionClassesNames = Empty
[2014-12-09 19:37:40.842] [D] [zway] SETDATA controller.data.softwareRevisionVersion = Empty
[2014-12-09 19:37:40.842] [D] [zway] SETDATA controller.data.softwareRevisionId = Empty
[2014-12-09 19:37:40.843] [D] [zway] SETDATA controller.data.softwareRevisionDate = Empty
[2014-12-09 19:37:40.843] [D] [zway] SETDATA controller.data.uuid = Empty
[2014-12-09 19:37:40.843] [D] [zway] SETDATA controller.data.nodeId = 0 (0x00000000)
[2014-12-09 19:37:40.843] [D] [zway] SETDATA controller.data.homeId = 0 (0x00000000)
[2014-12-09 19:37:40.843] [D] [zway] SETDATA controller.data.SUCNodeId = 0 (0x00000000)
[2014-12-09 19:37:40.843] [D] [zway] SETDATA controller.data.isPrimary = False
[2014-12-09 19:37:40.844] [D] [zway] SETDATA controller.data.isInOthersNetwork = False
[2014-12-09 19:37:40.844] [D] [zway] SETDATA controller.data.isRealPrimary = False
[2014-12-09 19:37:40.844] [D] [zway] SETDATA controller.data.isSUC = False
[2014-12-09 19:37:40.844] [D] [zway] SETDATA controller.data.SISPresent = False
[2014-12-09 19:37:40.845] [D] [zway] SETDATA controller.data.ZWLib = 0 (0x00000000)
[2014-12-09 19:37:40.845] [D] [zway] SETDATA controller.data.ZWlibMajor = 0 (0x00000000)
[2014-12-09 19:37:40.845] [D] [zway] SETDATA controller.data.ZWlibMinor = 0 (0x00000000)
[2014-12-09 19:37:40.845] [D] [zway] SETDATA controller.data.ZWVersion = 0 (0x00000000)
[2014-12-09 19:37:40.845] [D] [zway] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2014-12-09 19:37:40.845] [D] [zway] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2014-12-09 19:37:40.846] [D] [zway] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2014-12-09 19:37:40.846] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-12-09 19:37:40.846] [D] [zway] SETDATA controller.data.nonManagmentJobs = 0 (0x00000000)
[2014-12-09 19:37:40.846] [D] [zway] SETDATA controller.data.secureInclusion = True
[2014-12-09 19:37:40.846] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:40.846] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:40.847] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:40.847] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-12-09 19:37:40.847] [D] [zway] SETDATA controller.data.countJobs = False
[2014-12-09 19:37:40.847] [D] [zway] SETDATA controller.data.softwareRevisionVersion = "v2.0.0"
[2014-12-09 19:37:40.848] [D] [zway] SETDATA controller.data.softwareRevisionId = "a064f5408850947aed035bc9170e1fa04f0fd2ec"
[2014-12-09 19:37:40.848] [D] [zway] SETDATA controller.data.softwareRevisionDate = "2014-12-08 19:54:26 +0300"
[2014-12-09 19:37:40.848] [D] [zway] SETDATA controller.data.functionClasses = int[55]
[2014-12-09 19:37:40.849] [D] [zway]   [00] 2
[2014-12-09 19:37:40.849] [D] [zway]   [01] 3
[2014-12-09 19:37:40.849] [D] [zway]   [02] 4
[2014-12-09 19:37:40.849] [D] [zway]   [03] 5
[2014-12-09 19:37:40.849] [D] [zway]   [04] 6
[2014-12-09 19:37:40.849] [D] [zway]   [05] 7
[2014-12-09 19:37:40.850] [D] [zway]   [06] 8
[2014-12-09 19:37:40.850] [D] [zway]   [07] 18
[2014-12-09 19:37:40.850] [D] [zway]   [08] 19
[2014-12-09 19:37:40.850] [D] [zway]   [09] 21
[2014-12-09 19:37:40.850] [D] [zway]   [10] 22
[2014-12-09 19:37:40.850] [D] [zway]   [11] 23
[2014-12-09 19:37:40.850] [D] [zway]   [12] 32
[2014-12-09 19:37:40.851] [D] [zway]   [13] 33
[2014-12-09 19:37:40.851] [D] [zway]   [14] 34
[2014-12-09 19:37:40.851] [D] [zway]   [15] 35
[2014-12-09 19:37:40.851] [D] [zway]   [16] 36
[2014-12-09 19:37:40.851] [D] [zway]   [17] 39
[2014-12-09 19:37:40.851] [D] [zway]   [18] 41
[2014-12-09 19:37:40.851] [D] [zway]   [19] 42
[2014-12-09 19:37:40.852] [D] [zway]   [20] 43
[2014-12-09 19:37:40.852] [D] [zway]   [21] 44
[2014-12-09 19:37:40.852] [D] [zway]   [22] 45
[2014-12-09 19:37:40.852] [D] [zway]   [23] 65
[2014-12-09 19:37:40.852] [D] [zway]   [24] 66
[2014-12-09 19:37:40.852] [D] [zway]   [25] 68
[2014-12-09 19:37:40.852] [D] [zway]   [26] 70
[2014-12-09 19:37:40.853] [D] [zway]   [27] 71
[2014-12-09 19:37:40.853] [D] [zway]   [28] 72
[2014-12-09 19:37:40.853] [D] [zway]   [29] 73
[2014-12-09 19:37:40.853] [D] [zway]   [30] 74
[2014-12-09 19:37:40.853] [D] [zway]   [31] 75
[2014-12-09 19:37:40.853] [D] [zway]   [32] 76
[2014-12-09 19:37:40.854] [D] [zway]   [33] 77
[2014-12-09 19:37:40.854] [D] [zway]   [34] 80
[2014-12-09 19:37:40.854] [D] [zway]   [35] 81
[2014-12-09 19:37:40.854] [D] [zway]   [36] 82
[2014-12-09 19:37:40.854] [D] [zway]   [37] 83
[2014-12-09 19:37:40.855] [D] [zway]   [38] 84
[2014-12-09 19:37:40.855] [D] [zway]   [39] 85
[2014-12-09 19:37:40.855] [D] [zway]   [40] 86
[2014-12-09 19:37:40.855] [D] [zway]   [41] 87
[2014-12-09 19:37:40.855] [D] [zway]   [42] 96
[2014-12-09 19:37:40.855] [D] [zway]   [43] 97
[2014-12-09 19:37:40.855] [D] [zway]   [44] 98
[2014-12-09 19:37:40.856] [D] [zway]   [45] 99
[2014-12-09 19:37:40.856] [D] [zway]   [46] 128
[2014-12-09 19:37:40.856] [D] [zway]   [47] 186
[2014-12-09 19:37:40.856] [D] [zway]   [48] 190
[2014-12-09 19:37:40.856] [D] [zway]   [49] 210
[2014-12-09 19:37:40.856] [D] [zway]   [50] 211
[2014-12-09 19:37:40.856] [D] [zway]   [51] 242
[2014-12-09 19:37:40.857] [D] [zway]   [52] 243
[2014-12-09 19:37:40.857] [D] [zway]   [53] 244
[2014-12-09 19:37:40.857] [D] [zway]   [54] 245
[2014-12-09 19:37:40.857] [D] [zway] SETDATA controller.data.functionClassesNames = string[55]
[2014-12-09 19:37:40.857] [D] [zway]   [00] "SerialAPIGetInitData"
[2014-12-09 19:37:40.857] [D] [zway]   [01] "SerialAPIApplicationNodeInformation"
[2014-12-09 19:37:40.858] [D] [zway]   [02] "ApplicationCommandHandler"
[2014-12-09 19:37:40.858] [D] [zway]   [03] "GetControllerCapabilities"
[2014-12-09 19:37:40.858] [D] [zway]   [04] "SerialAPISetTimeouts"
[2014-12-09 19:37:40.858] [D] [zway]   [05] "GetSerialAPICapabilities"
[2014-12-09 19:37:40.858] [D] [zway]   [06] "SerialAPISoftReset"
[2014-12-09 19:37:40.858] [D] [zway]   [07] "SendNodeInformation"
[2014-12-09 19:37:40.859] [D] [zway]   [08] "SendData"
[2014-12-09 19:37:40.859] [D] [zway]   [09] "GetVersion"
[2014-12-09 19:37:40.859] [D] [zway]   [10] "SendDataAbort"
[2014-12-09 19:37:40.859] [D] [zway]   [11] "RFPowerLevelSet"
[2014-12-09 19:37:40.859] [D] [zway]   [12] "GetHomeId"
[2014-12-09 19:37:40.859] [D] [zway]   [13] "MemoryGetByte"
[2014-12-09 19:37:40.860] [D] [zway]   [14] "MemoryPutByte"
[2014-12-09 19:37:40.860] [D] [zway]   [15] "MemoryGetBuffer"
[2014-12-09 19:37:40.860] [D] [zway]   [16] "MemoryPutBuffer"
[2014-12-09 19:37:40.860] [D] [zway]   [17] "FlashAutoProgSet"
[2014-12-09 19:37:40.860] [D] [zway]   [18] "NVMGetId"
[2014-12-09 19:37:40.860] [D] [zway]   [19] "NVMExtReadLongBuffer"
[2014-12-09 19:37:40.860] [D] [zway]   [20] "NVMExtWriteLongBuffer"
[2014-12-09 19:37:40.861] [D] [zway]   [21] "NVMExtReadLongByte"
[2014-12-09 19:37:40.861] [D] [zway]   [22] "NVMExtWriteLongByte"
[2014-12-09 19:37:40.861] [D] [zway]   [23] "GetNodeProtocolInformation"
[2014-12-09 19:37:40.861] [D] [zway]   [24] "SetDefault"
[2014-12-09 19:37:40.861] [D] [zway]   [25] "ReplicationReceiveComplete"
[2014-12-09 19:37:40.861] [D] [zway]   [26] "AssignReturnRoute"
[2014-12-09 19:37:40.861] [D] [zway]   [27] "DeleteReturnRoute"
[2014-12-09 19:37:40.862] [D] [zway]   [28] "RequestNodeNeighbourUpdate"
[2014-12-09 19:37:40.862] [D] [zway]   [29] "ApplicationNodeUpdate"
[2014-12-09 19:37:40.862] [D] [zway]   [30] "AddNodeToNetwork"
[2014-12-09 19:37:40.862] [D] [zway]   [31] "RemoveNodeFromNetwork"
[2014-12-09 19:37:40.862] [D] [zway]   [32] "CreateNewPrimary"
[2014-12-09 19:37:40.862] [D] [zway]   [33] "ControllerChange"
[2014-12-09 19:37:40.862] [D] [zway]   [34] "SetLearnMode"
[2014-12-09 19:37:40.863] [D] [zway]   [35] "AssignSUCReturnRoute"
[2014-12-09 19:37:40.863] [D] [zway]   [36] "EnableSUC"
[2014-12-09 19:37:40.863] [D] [zway]   [37] "RequestNetworkUpdate"
[2014-12-09 19:37:40.863] [D] [zway]   [38] "SetSUCNodeId"
[2014-12-09 19:37:40.863] [D] [zway]   [39] "DeleteSUCReturnRoute"
[2014-12-09 19:37:40.863] [D] [zway]   [40] "GetSUCNodeId"
[2014-12-09 19:37:40.864] [D] [zway]   [41] "SendSUCNodeId"
[2014-12-09 19:37:40.864] [D] [zway]   [42] "RequestNodeInformation"
[2014-12-09 19:37:40.864] [D] [zway]   [43] "RemoveFailedNode"
[2014-12-09 19:37:40.864] [D] [zway]   [44] "IsFailedNode"
[2014-12-09 19:37:40.864] [D] [zway]   [45] "ReplaceFailedNode"
[2014-12-09 19:37:40.864] [D] [zway]   [46] "GetRoutingTableLine"
[2014-12-09 19:37:40.865] [D] [zway]   [47] "RFPowerLevelGet"
[2014-12-09 19:37:40.865] [D] [zway]   [48] "SendTestFrame"
[2014-12-09 19:37:40.865] [D] [zway]   [49] "WatchDogStart"
[2014-12-09 19:37:40.865] [D] [zway]   [50] "WatchDogStop"
[2014-12-09 19:37:40.865] [D] [zway]   [51] "ZMEFreqChange"
[2014-12-09 19:37:40.865] [D] [zway]   [52] "ZMERestore"
[2014-12-09 19:37:40.865] [D] [zway]   [53] "ZMEBootloaderFlash"
[2014-12-09 19:37:40.866] [D] [zway]   [54] "ZMECapabilities"
[2014-12-09 19:37:40.866] [D] [zway] Opened device: /dev/ttyAMA0
[2014-12-09 19:37:40.867] [D] [zway] Worker thread successfully created
[2014-12-09 19:37:40.869] [D] [zway] Worker thread entry point
[2014-12-09 19:37:40.881] [I] [zway] Adding job: Get controller info and supported function classes
[2014-12-09 19:37:40.881] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-09 19:37:41.089] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-09 19:37:41.090] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-09 19:37:41.294] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-09 19:37:41.294] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-09 19:37:41.498] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-09 19:37:41.498] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-12-09 19:37:41.499] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2014-12-09 19:37:41.499] [C] [zway] Get Serial API Capabilities returned zero.
[2014-12-09 19:37:41.499] [I] [zway] Removing job: Get controller info and supported function classes
[2014-12-09 19:37:41.510] [D] [zway] Worker thread exit point
[2014-12-09 19:37:41.510] [D] [zway] Worker thread successfully finished
[2014-12-09 19:37:41.528] [I] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
neonemo
Re: Cannot Start Z-Way
Post by neonemo »
Physically power cycling fixed the issue
Your board does not reply..... ;( try to power off the RPi
