StellaZ in V2.0.0
LAN-Opfer
StellaZ in V2.0.0
Post by LAN-Opfer »
1) My StellaZ (Device_9) is in Expert UI shown as Switch - what can I switch there?
2) It is also shown as Thermostat - but there is nothing to set?
The illustration as Sensor data is ok.
Is the StellaZ not fully supported in V2.0.0? If yes, I hope it is on the todo-list ;)
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
Re: StellaZ in V2.0.0
StellaZ has four mode settings
Comfort, SaveHeat, Frost protect, and direct valve control.
The direct valve control is seen as a dimmer'type device, which by its nature you can swith on and off.
Before you can set the valve, the StellaZ must be placed in that direct control modus. Same aplies for setting temperature for Comfort/SaveHeat.
Unfortunately none of these are available yet in the scenes/rules modules.
LAN-Opfer
Post by LAN-Opfer »
...ah - ok. I think about, to use the direkt mode because I use for the same heating a extra Thermostat as remote control. It is not ideal, to use the sensor near the heating for temperature control. I will use a script as PI-controller - but that is a todo in future.
But what about Thermostat? Device_9 is not able to set as thermostat :(
...sorry - I see, that I did a mistake with the pictures...
I have now the right pictures in my first post.
Uwe
LAN-Opfer wrote: But what about Thermostat? Device_9 is not able to set as thermostat :(
Print in the images is to small for my old eyes.
The thermostat view in the new Expert UI seems still incomplete.
I do use the Old Expert UI for special manual thermostat settings.
In daily use it is controlled from OpenRemote Android client
LAN-Opfer
Post by LAN-Opfer »
pz1 wrote:Print in the images is to small for my old eyes.
...a Little small - that's true, but my eyes are already 50 years old :ugeek: and can recognize it yet - maybe I should write in Braille now :lol:
pz1 wrote:In daily use it is controlled from OpenRemote Android client
...that is very interesting - I will have a look to it!
Uwe
Created an issue: https://github.com/Z-Wave-Me/ExpertUI/issues/45
We hope to fix this within a week or two
LAN-Opfer
Post by LAN-Opfer »
Thx!
LAN-Opfer
Post by LAN-Opfer »
...I installed the Android-App - but I am not able to configure it :-( Do you have some tips, what I have to do?
Uwe
Add new profile and search for boxes in your network
