Command Class Meter Pulse (0x35) support
kozlow
Post by kozlow »
Hi, I'm discovering your plateform and I can't wait to develop on it, but:
"Got frame from device xx to controller, but command class 0x35 is not implemented"
I'm inspecting data sent by my MIMOLite (Fortrezz) device and it seems I have a problem. Do you expect to implement this little ;) command class? Or is there a way to hook frame processing and handle by myself this kind of class?
Thx, Mat
pofs
Re: Command Class Meter Pulse (0x35) support
Post by pofs »
Yes, I was bored and added it. Will be available in the next builds.
It is deprecated though :)
kozlow
Post by kozlow »
Excellent! Deprecated but useful in my case :-p
However, I'd like to renew my question: is there a JSApi-way to hook frame data I can see in log file? I've found this: "
Configuration Command Class can be managed using our UI, you do not need to trap frames to use it." as a response in this forum but it doesn't satisfy me ;-)
pofs
Post by pofs »
No, there's not.
Frames are handled on the much lower level than JS, and there's no way to hook in even with C API.
Handling frames require quite a knowledge of serial API (which is not available to public), and a lot of effort with dynamically creating JS functions, so we decided not to bother with it.
kozlow
Post by kozlow »
now (-rc9-3-...) I can effectively read commandClass[0x35] data but only through JS/Run/zway... API.
CommandClass 0x35 data are missing with Run/Data dump API (I've forked ExpertUI and would like to add meter pulses output to Meters page). Could you fix this please? Thx by advance.
pofs
Post by pofs »
That's strange, as it just walks the entire data tree without any filtering. Please compare outputs from "/JS/Run/zway" and "/ZWaveAPI/Data/0", and see if it is present there.
kozlow
Post by kozlow »
Strange indeed, see by yourself with attached (untouched) outputs. Device 22.
Comparison.zip
(75.07 KiB) Downloaded 811 times
it is because of "supported = false".
Can you re-interview the device? this is because Z-Way have not made interview of this Class yet.
kozlow
Post by kozlow »
Indeed, solved.
For info, I've submitted a pull request in GitHub ExpertUI repository to support MeterPulse display in Meters page.
Thanks, we are already evaluating it
