WALLC-S and unknown device type: 24
shiphrah
Post by shiphrah »
On "expert UI -> Type" info my WALLC-S shows up correctly but the device typs is shown as "unknown device type: 24"
How can I fix this? I am on z-way version v2.0.0
Re: WALLC-S and unknown device type: 24
This is not a problem. We have just forgot to add few description strings. But this does not affect functionality at all
shiphrah
Post by shiphrah »
Thanks!
rgroothuis
Post by rgroothuis »
My ZME-WALLC-S device show correctly from a naming point of view. But it is missing a configuration file and thus I cannot change my configuration parameters. See also screen dumps. Any idea on how to address this?
Screen Shot 2015-04-09 at 23.19.51.png (99.08 KiB) Viewed 20746 times
Screen Shot 2015-04-09 at 23.19.34.png (46.2 KiB) Viewed 20746 times
shiphrah
Post by shiphrah »
On the bottom of the "Interview" tab is a blue button "Select Device Description". Click on it. In the pop up there is a drop down list where you can select the WALLC-S.
Hope that helps.
rgroothuis
shiphrah wrote:On the bottom of the "Interview" tab is a blue button "Select Device Description". Click on it. In the pop up there is a drop down list where you can select the WALLC-S.
Hope that helps.
Excellent! That did the trick. Stupid that I overlooked that button. I was on this page many many times. Next is to get the scenes working :-)
fez
Post by fez »
Hi, I have a the same problem as above described, but "Select Device Description" doesn't seem to help.
I tried it several times, still I always get the " Device has no configuration".
I tried to wake the the wall switch also, but still no changes.
Do you have any advice?
@fez
Which software version do you use? There is a device description issue in v2.0.1. That was fixed in v2.0.2-rc1
fivehundred
Post by fivehundred »
Hi, i tried to upgrade to 2.0.2 rc1 but the device is always seen as unknwon. I have a razperry with a fibaro FGS-221 and an eversping AN145 and i would like to use the WALLC to control them.. i'm become crazy with configuration of association groups, but i'm not able to get it working with neither of them.
can anyone helps me to fix it?
thanks a lot,
Francesco
